Author Topic: Post your LightSaver keyboard photos!  (Read 236784 times)
Offline Invaderevan
Re: Post your LightSaver keyboard photos!
« Reply #250 on: Thu, 22 October 2015, 12:35:00 »
Glad I could help :D
I actually have another question, if you'll indulge me. On your Mac, can you turn the Num Lock on and off so that that former position types numbers and the latter has arrow keys at 2-4-6-8?
I would love to help but my LS does not have a numlock mapped :/ sorry
WTTF Ribbits, Ashen V2 MX, Bronins
Offline Photoelectric
« Reply #251 on: Thu, 22 October 2015, 14:00:26 »
That would be something you'd program into the keyboard directly as part of the keymap, independent of the operating system.  (The short answer is yes if that is how you have it set up on the keyboard itself).
Offline limitz
  • "the old gods stir and will not let me sleep..."
« Reply #252 on: Fri, 27 November 2015, 23:02:43 »
Posting in this thread as it seems most of the troubleshooting has happened here.
I cannot program this keyboard. I've got the newest version of O2D keymapper (1.7.56), and I've gotten FLIP installed, but everytime I try to upload firmware I always get a "DFU Programmer is not found" error. I've downloaded DFU Programmer and extracted it, and it still does not work.
I've downloaded the Korean IME for 8.1, and even when I've switche to that before opening the keymapper, it still won't upload.
Mmm... machined aluminum
« Reply #253 on: Sat, 28 November 2015, 00:36:35 »
Did you install the Atmel USB drivers?  See this basic summary (but ignore the bit about magnets, that's for a different controller.  Plug in your keyboard while holding the FLIP key as noted on the diagram in the OP and look at the Device Manager list):
https://geekhack.org/index.php?topic=35065.msg949091#msg949091
The process for updating the firmware is the same as for a KMAC, listed here (steps 8-14):
https://geekhack.org/index.php?topic=49647.0
To clarify, the keymapper software only creates/modifies and saves a new keymap HEX file.  It does not upload the HEX file to the keyboard on its own--for that you need to use FLIP and load the HEX file you've saved.
Offline Steezus
  • Keeper of Facts
« Reply #254 on: Sat, 28 November 2015, 14:18:20 »
Looks like once the Orion GB has finished Duck will work on Octagon v2 and then finally Lightsaver v3. It's been posted in the Orion v2 group buy but I figured to share it here as well. I've been dying to get my hands on a Lightsaver, ended up grabbing a RS96 but I won't miss the next the LSv3 group buy.
Offline bianco
« Reply #255 on: Sat, 28 November 2015, 21:09:47 »
if you're using windows 8 and above though, you'll have to enable unsigned drivers.
http://www.makeuseof.com/tag/how-can-i-install-hardware-with-unsigned-drivers-in-windows-8/
Offline trenzafeeds
  • **** off
« Reply #256 on: Sat, 28 November 2015, 21:34:24 »
i have v1 and v2, both doesn't have the tabs.
must be a custom plate for the acrylic case
sharing my current lightsaber v2
I usually think that rows of multiple artisans look really gimmicky and overstated, but the color matching looks good on this one, pulls the thing together. Very nice job  :thumb:
demik will never leave.
Unless he gets banned.
Offline KushZEN
« Reply #257 on: Sun, 13 December 2015, 02:24:51 »
I've finally fulfilled my dreams of owning a LS, I'll post pictures when it arrives, but I'm glad I finally got one. ;D
« Reply #258 on: Sun, 13 December 2015, 20:58:22 »
Waiting for screws for blockers (from China so see ya guys in 2016)
No LEDs, need a new PCB for that.
Offline WinterIsle
« Reply #259 on: Sat, 19 December 2015, 02:21:05 »
I assemble mine two months ago after letting it collect dust for almost a year.
Build Log: http://imgur.com/a/pfbC0
JT Purple-White: http://imgur.com/a/KyNtH
Offline fknraiden
« Reply #260 on: Sat, 19 December 2015, 03:42:17 »
Nice Red Scarf  :confused:
Offline WinterIsle
« Reply #261 on: Sat, 19 December 2015, 20:08:20 »
Yup, Red Scarf case  :-[
Here's a typing test, please pardon me the 40wpm speed.
Offline 64rky
« Reply #262 on: Mon, 04 January 2016, 19:22:43 »
Hello all you Lightsaver lovers....
I have finally got my first lightsaver, and I think it has some default programming going on... I am not sure if this is the correct thread, if it isn't please could you point me to the correct one and I'll be on my way :)
I've linked to this picture for key reference (source: https://geekhack.org/index.php?topic=56877.msg1462227#msg1462227):
So all the keys seem to work, the problem is, the "pause" key (F13) and Scroll Lock (F15) keys seem to not show up on the key tester (Aqua). I am not sure if this is because these keys have not been programmed yet, and therefore not showing? Is this normal, I haven't even tried programming the board... the firmware looks scary... does anyone have the file to map the keys so they are like the above image?
Thanks so much, I am a n00b!  :-[
« Reply #263 on: Mon, 04 January 2016, 19:24:41 »
Use O2D's
http://duck0113.tistory.com/84
Offline 64rky
« Reply #264 on: Mon, 04 January 2016, 19:30:20 »
Use O2D's
Thank you for the advice, I have downloaded and will have a look. I just don't want to mess up what I have at the moment :|
« Reply #265 on: Mon, 04 January 2016, 20:10:15 »
That's a very nice arrow cluster and WASD you have there, not to mention the Esc :D
Offline 64rky
« Reply #266 on: Mon, 04 January 2016, 20:50:04 »
This is not my board, I took this picture from another user, I have credited them above.
Offline sircheddar
« Reply #267 on: Wed, 17 February 2016, 12:31:33 »
Does the lightsaver pcb itself have LEDs or just LED support ( for the bottom LEDs)
" I hope that when the world comes to an end, I can breathe a sigh of relief, because there will be so much to look forward to. "
Offline Steezus
  • Keeper of Facts
« Reply #268 on: Wed, 17 February 2016, 12:39:48 »
The SMD LEDs are presoldered.
Offline sircheddar
« Reply #269 on: Wed, 17 February 2016, 15:40:22 »
Cool thanks for the quiz response
« Reply #270 on: Fri, 19 February 2016, 11:21:09 »
Lightsaver v1.5 revived!
Offline sncbraxsc2
  • ⭐Domesticated Dweeb⭐
« Reply #271 on: Thu, 17 March 2016, 11:33:05 »
Project Name: Qui-Duck Jinn
Offline mrboovn
« Reply #272 on: Fri, 18 March 2016, 00:28:06 »
perfect matching  :eek: :eek:
« Reply #273 on: Sat, 19 March 2016, 14:45:00 »
perfect
« Reply #274 on: Sat, 26 March 2016, 05:25:59 »
Light green LEDs?
Very nice indeed!
Offline sncbraxsc2
« Reply #275 on: Wed, 30 March 2016, 01:51:35 »
sorry to respond terribly late:P
perfect
The size, layout, and weight have all been perfect for my needs:)
Light green LEDs?
Very nice indeed!
Thanks! I've always wanted a green lightsaber
« Reply #276 on: Sun, 03 April 2016, 00:02:41 »
Light green LEDs?
Very nice indeed!
A green LightSaver is probably as close as you'll get ;)
Offline vincentalpha
« Reply #277 on: Wed, 28 September 2016, 10:07:42 »
hey guys, I am not sure if this the right topic to ask but I am looking for someone who has experience with lightsaver keyboard.
I bought a keyboard that use the same layout as ZZ96 (not RS3 for sure, because it doesn't use remote control to control back light) and I just learnt about the spacefn feature from TMK. I am loving that features and want to use it with my 96keyboard.
Anyone can please help me to keymap spacefn? and what's software should I use?
I created a thread here and hope that you guys can answer me over there.
https://geekhack.org/index.php?topic=84914.0
Thanks.
« Last Edit: Wed, 28 September 2016, 10:11:43 by vincentalpha »
Offline PollandAkuma
« Reply #278 on: Thu, 29 September 2016, 05:54:37 »
Wow. That is so clean!
Where'd you get those beautiful LEDs ;-;
Offline dubious
  • 쏘쿨
« Reply #279 on: Thu, 02 March 2017, 21:43:31 »
If anyone happened to post more pictures of their lightsaver, I would not mind.. :))
« Reply #280 on: Fri, 03 March 2017, 00:11:16 »
Picture from 2014 when I still had my Lightsaver V1
161925-0
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #281 on: Fri, 03 March 2017, 00:19:34 »
Um seriously, where can i get some "lime green" LEDs?! That looks amazing.
-Dana
Offline dubious
  • 쏘쿨
« Reply #282 on: Fri, 03 March 2017, 16:13:45 »
looks good! Wish they were offering grey again tho
I can't ever decide if I like DSA hyperfuse or GMK better.... SA is just going to make things harder  :confused:
« Last Edit: Fri, 03 March 2017, 16:15:26 by dubious »
« Reply #283 on: Sat, 04 March 2017, 00:55:27 »
Those are perhaps regular green LEDs?  But there are yellow-green 1.8mm LEDs you can get here:
http://www.ebay.com/itm/1-8mm-Water-Clear-Diffused-Round-Top-Warm-White-Red-Blue-Light-LED-Diodes-/122100046749?var=&hash=item1c6dbadb9d:m:mXzKVI3VJPlEwcT9u0v7cOQ
(enter 572nm here  https://academo.org/demos/wavelength-to-colour-relationship/)
« Last Edit: Sat, 04 March 2017, 00:57:11 by Photoelectric »
Offline OfTheWild
« Reply #284 on: Sat, 04 March 2017, 03:48:33 »
Ah very nice! Thanks for the link to the wavelength tool as well. Thats kinda cool. You're right though, the 572nm wavelength looks to be really close to what that is in the photo.
-Dana
Offline Zombii
  • Let’s All Love Lain.
« Reply #285 on: Sat, 18 March 2017, 19:16:53 »
Finally got my dream board (LSv1)!
It got in from Korea about a month ago, and I recently finished converting it from MX Whites to Gateron Clears. Unfortunately, during resoldering, a couple traces got lifted (LED traces), does anyone know if its possible to jump these or otherwise make those LEDs functional? I installed SIP sockets in every switch before realizing that some traces were lifted, so currently only 3 of my LEDs are actually soldered -_-
Anyway, here's a picture, forgive the messy desk, I haven't gotten the chance to clean it recently and I spend most of my time here.
Really regretting selling my good camera...
Offline limitz
« Reply #286 on: Mon, 20 March 2017, 10:46:53 »
You can easily fix those by jumping the lifted trace with a wire.
Offline Zombii
« Reply #287 on: Mon, 20 March 2017, 14:37:22 »
Yep, I got some help in another subforum and I'll be soldering them tomorrow hopefully.
EDIT:
And it's fixed!
my camera, however, still sucks at low-light
« Last Edit: Wed, 22 March 2017, 23:46:05 by Zombii »
Offline Zombii
« Reply #288 on: Thu, 23 March 2017, 23:18:07 »
Apologies for the double post, but does anyone know the best way to shave LEDs? Also, is there a way to change which LED toggles with numlock?
« Reply #289 on: Fri, 24 March 2017, 13:35:21 »
Started general info thread on all duck kits here:
https://geekhack.org/index.php?topic=88454
Looks like image links to duck's site are all broken now due to a change in how they are hosted on duck's site.  Will have to try to revise.
Offline aaron6301
  • Pixel Pusher
« Reply #290 on: Fri, 24 March 2017, 14:37:09 »
Shave as in take off some of the excess height? Are you using 2x3x4mm?
I shaved portions off the top of my 2x3x4's to create an angle. This eliminated the rubbing interference between the LED and keycap underside. The technique I used was angling the led at 45 or so degrees and dragging it across some 320 grit sandpaper.
In hindsight it would have been easier to use 1.8mm but I couldn't find any in my desired color, sky blue.
« Last Edit: Sat, 25 March 2017, 09:51:13 by aaron6301 »
Offline Zombii
« Reply #291 on: Fri, 24 March 2017, 17:41:09 »
I shaved portions off the top of my 2x3x4's to create an angle. This eliminated the rubbing interference between the LED and keycap underside. The technique I used was angling the led at 45 or so degrees and dragging it some 320 grit sandpaper.
Yeah, 2x3x4. I'll try that
Offline ctzn_voyager
« Reply #292 on: Sat, 25 March 2017, 22:18:38 »
A few snaps of mine in various set ups
« Reply #293 on: Sat, 25 March 2017, 23:02:03 »
Offline dubious
  • 쏘쿨
« Reply #294 on: Sun, 26 March 2017, 14:59:57 »
Offline sncbraxsc2
« Reply #295 on: Mon, 23 October 2017, 09:39:29 »
I really think DSA looks so good on this board. Heres my favorite picture of my Lightsaver. Dat ass is fatttt ;D
Offline sncbraxsc2
« Reply #296 on: Fri, 02 February 2018, 10:05:08 »
Double posting  ^-^
Dressed my lightsaver up in some fancy DCS a while ago. I'm changing the layout and caps so will update with more pics soon
I'd like to see some v3 pictures in here!  :)
Offline Invaderevan
« Reply #297 on: Fri, 02 February 2018, 10:29:13 »
Double posting  ^-^
Looks great man!
My poor LSv3 has been in a drawer ready to solder with all the switches in, I really need to finish it and get some pics up.
Offline sncbraxsc2
« Reply #298 on: Fri, 02 February 2018, 11:16:30 »
Double posting  ^-^
Looks great man!
Thanks! Yes, get it together, man! ;D
« Reply #299 on: Fri, 02 February 2018, 11:28:22 »
LSv1 is my favorite for that huge monolithic rear end :D
