Author Topic: Post your LightSaver keyboard photos!  (Read 236774 times)
Offline bianco
Re: Post your LightSaver keyboard photos!
« Reply #100 on: Tue, 03 June 2014, 09:14:33 »
Those keycaps are GMK's ABS doubleshots from a WEY, with some doubleshots from an 1800, a few BSP Royal-Alpha typewriter PBT and ABS caps, and some CMYK.
The aqua and turquoise LEDs are from taobao, blue and red--from eBay.  The LED spec is pretty much nonexistent there (generally very few parameters listed, and sometimes you get a brightness value, which I've learned does not mean much...), so I got some SMD ones to experiment with in 3528 size: magenta and aqua-blue.  They are not as bright as the original red ones, but I like the watery shade.  Almost used magenta at first.
thank you sir!
i'll try to find a few in the local electronics shop.
Offline StylinGreymon
  • Keyboard Hipstar
« Reply #101 on: Wed, 04 June 2014, 02:12:02 »
Would you mind linking them?
I cannot seem to effectively navigate that site.
If today had been a hippo, then you'd really have to worry about tomorrow.
Offline Photoelectric
« Reply #103 on: Wed, 04 June 2014, 14:48:42 »
Is anyone finding the rigidity of the steel plate + dense metal tray case to be uncomfortable?  Here's how I've added some dampening to mine, and it's helping slightly:
Thin silicone o-rings!  Place over the stand-offs:
66957-0
Insert the PCB/plate diagonally into the case, mini USB socket into the hole first, then lower the PCB onto the standoffs.  Add bolts.   Here you can see an o-ring peeking out
66959-1
Still sounds a bit metallic along the edges, but I'll be looking into other dampening methods in addition to the o-rings--perhaps something to go between the PCB and the plate around the perimeter.
Offline BlueBär
« Reply #104 on: Wed, 04 June 2014, 15:28:57 »
I've seen some rubber bands on korean keyboards between the PCB and plate: http://www.otd.kr/data/file/pj_356/2105777654_958acd14_DCS_7620.jpg
Not sure if they're used for that purpose though, but I think it could help.
« Reply #105 on: Wed, 04 June 2014, 16:27:00 »
Interesting--thanks for the link.
Offline MythicalWagyu
  • Poor Impulse Control
« Reply #106 on: Wed, 04 June 2014, 16:43:45 »
Touched up my LightSaver today: swapped side LEDs to aqua and in-switch LEDs to turquoise + blue (alternating rows) and red for indicator LEDs + Function.
Plus some re-programming, and it's back to being my main keyboard  :thumb:
These are stunning - going right into the keyboard porn folder!
KEYBOARDS >>
MICE >>
COMPUTER >>
Offline acantha
  • Aure Entuluva
« Reply #107 on: Fri, 06 June 2014, 22:35:24 »
has anyone has success using the TMK then O2D method with macros? everything else is working but the macros i set aren't taking.
« Last Edit: Fri, 06 June 2014, 23:06:20 by acantha »
All the Happy Hacking Things
Offline elton5354
« Reply #108 on: Sat, 07 June 2014, 00:45:01 »
That is a beauty, m'lady. I love those numpad key caps.  I wish I had some.  Plus with those windowed caps lock, num lock, scroll lock is perfect.
Offline tadbitnerdy
« Reply #110 on: Tue, 10 June 2014, 14:22:28 »
after months getting it, finally found time to assemble my light saver v1.
mx clears with 67g springs and transparent switch tops, no LED (yet), hyperfuse dsa keycaps
thanks for the help Elton and Photoelectric (and also for the helpful 'how to setup' and faq).
looking forward to getting the v2 pcb and plates, i hope they fit and mounting screws match the v1 case
Hello all!
I have a question for all you Lightsaver V1 folk:  How would you go about programming the arrow keys in the above picture to actually register arrow key presses?  I just built my V1 with almost the exact layout, but when I go into the 02D_Keymapper, all it has is ? for the arrow keys.  Do I need to you the old software to do this?
-Tad
Offline tadbitnerdy
« Reply #111 on: Tue, 10 June 2014, 14:32:08 »
Nevermind. I was able to get it working with the old TrueCustom software :)  Thanks!
« Reply #112 on: Tue, 10 June 2014, 14:40:03 »
The latest firmware has arrows.  The intermediate one had a bug where they showed up as ? in the UI.
Offline tadbitnerdy
« Reply #113 on: Tue, 10 June 2014, 17:00:30 »
Strange.  I used the link in your first post for the 02D firmware.  Is there a more up to date version than that?
« Reply #114 on: Tue, 10 June 2014, 17:06:55 »
You're right--just downloaded it as a test, and despite the screenshots on the webpage, the arrows are still showing up as ? on the latest version :(  They do work as intended, however, despite their appearance.
Offline tadbitnerdy
« Reply #115 on: Tue, 10 June 2014, 18:31:28 »
Cool cool.  I'll give it another try, but the first time I tried it, when I assigned the buttons to the correct ?'s, then create the hex file, the hex file would show them as not assigned.
« Reply #116 on: Tue, 10 June 2014, 18:57:27 »
Are you moving the arrow keys to their non-default location?  I think that's the reason no one's really complained (or one of the reasons): most of us have left the arrow keys alone in their original location.
Offline bianco
« Reply #117 on: Tue, 10 June 2014, 20:34:31 »
that's exactly how i did it.  ;D
Offline tadbitnerdy
« Reply #118 on: Tue, 10 June 2014, 22:15:10 »
Thanks for the confirmation bianco!
Also, thanks for the help Photoelectric!  I did not move the arrows.  I kept them there and placed other buttons around them.  Tried again, but same issue.
« Reply #119 on: Tue, 10 June 2014, 22:30:49 »
What is the error that you're seeing exactly?  In my case, the arrow keys show up as ?, but one the hex file is created and I transfer it to the keyboard, the arrow keys all function properly.
Offline tadbitnerdy
« Reply #120 on: Tue, 10 June 2014, 22:50:42 »
My arrow keys also show up as ?, but when I load the hex file they don't do anything at all.
« Reply #121 on: Tue, 10 June 2014, 22:54:45 »
Do you reassign the arrows or do you leave those 4 keys alone when you open a new template?  I know they work as intended if you don't do anything to them at all using one of the default presets.  Perhaps reassigning them doesn't work properly.  Basically I load the LightSaver Custom layout and modify everything but the arrow keys, leaving those alone, and everything works properly after programming.
Offline tadbitnerdy
« Reply #122 on: Tue, 10 June 2014, 22:58:49 »
I did it both ways:  both leaving them alone and then assigning them.  Neither way worked.  However, when I use the older software and the TrueCustom Keymapper it works like a charm.  Side LEDs won't work, but the arrows do :)
« Reply #123 on: Tue, 10 June 2014, 23:13:31 »
Strange :(  I'm not really sure why that's happening.  I've reprogrammed my lightsaver around 15 times now, tweaking various things over time, and the arrows always showed up as ? and always worked okay regardless.  We should probably contact whoever is writing the firmware about it.
Offline tadbitnerdy
« Reply #124 on: Wed, 11 June 2014, 12:59:07 »
I GOT IT TO WORK!!!  Not really sure how, but it works now.  I just loaded up a new custom firmware template, and now it works.  I was also able to program the FN layer to make the up and down arrows Page Up and Page Down, and now I can have LED control also!  Thanks for the help!
-Tad
« Reply #125 on: Wed, 11 June 2014, 13:03:23 »
-Tad
Awesome!  I think just don't touch those arrow keys on the premade template at all while changing the rest, and it should be good.
Offline tadbitnerdy
« Reply #126 on: Wed, 11 June 2014, 13:39:12 »
Good plan :)  Now to wait for my V2!
Offline acantha
  • Aure Entuluva
« Reply #127 on: Thu, 10 July 2014, 12:34:47 »
Finally got around to taking some pictures of my lightsaver...
oh hello hellboy... I want to put a few LEDs on the switches so that this fellow and the windowed key that turns the lights on and off can get some backlight.
as i am currently lacking a dsa numpad (just dumb on my part forgetting to get one) i'm using my round3 numpad and it actually works okay. helps me know without looking when i've strayed over too far.
ooohhh purty lights. contemplating trying the LED replacement though.
I have to say that dsa kits are brilliant on this
« Reply #128 on: Thu, 10 July 2014, 22:39:25 »
^ That Fire key! ;D
Offline bianco
« Reply #129 on: Sat, 12 July 2014, 09:07:12 »
new keycaps for my light saver
Offline acantha
  • Aure Entuluva
« Reply #130 on: Tue, 15 July 2014, 17:29:16 »
nice! great minds think alike!  :thumb: (especially when one of them, ie me, steal the layout from the other)
Offline MrChunky
« Reply #131 on: Mon, 21 July 2014, 02:31:53 »
Got around to taking some better pictures with a new set. Also discovered that I love DSA , at least on this keyboard.
71791-0
71793-1
71795-2
Offline Sniping
« Reply #132 on: Mon, 21 July 2014, 03:24:06 »
Looking good with the Granite!
Offline MrChunky
« Reply #133 on: Thu, 24 July 2014, 12:21:22 »
Does anyone know if it is possible to remap the LED that lights up when you turn on NumLock? I looked around, but I can't find anything...
Offline tsangan
  • 1000/600
« Reply #134 on: Thu, 24 July 2014, 13:59:01 »
Why don't I have one of these?
Keyboardless
Offline Xenderwind
« Reply #135 on: Thu, 24 July 2014, 14:19:45 »
you can still get a duck viper/eagle if you like 60% :p
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
Offline bianco
« Reply #136 on: Fri, 25 July 2014, 03:03:00 »
v2!
new version, new 'name'
« Reply #137 on: Thu, 31 July 2014, 17:13:41 »
Hey I bought acantha's v1 and I was wondering what the specs are on the leds, both the side and the switch ones. Or can I just use any?
Edit: read the op, don't know how I missed that
« Last Edit: Thu, 31 July 2014, 17:47:44 by Joey Quinn »
Offline taylordcraig
« Reply #138 on: Fri, 01 August 2014, 17:33:32 »
Trying to program mine, links to new firmware don't work.
.edit: i got 1.4.288 and am not sure how to detect it with flip.
atmega32u4 doesnt seem to bring anything up, it's all grey.
edit2: missed the step about updating drivers, my bad.
Offline Ronnn
« Reply #139 on: Fri, 01 August 2014, 17:53:58 »
edit2: wewnt to device manager; found atmel32u4; right click update driver software, choose file from computer, computer/programfilesx86/atmel/flip
Select atmega32u4 first, then disconnect your board, reconnect the board while holding the flip key, then click the USB icon and select usb. Click open then select hex file from file
Offline Ronnn
« Reply #140 on: Fri, 01 August 2014, 19:00:11 »
Not very satisfied with the LEDs. But its too painful to swap them although I have sip sockets installed.
Offline Ronnn
« Reply #141 on: Fri, 01 August 2014, 22:00:37 »
Can someone please tell me how many brightness levels are there?
I have tried the odd firmwares and the newest one, but they all give me only 2 brightness levels (max brightness and off).
Offline animaliaparadoxa
« Reply #142 on: Sat, 02 August 2014, 20:04:13 »
I'm curious about this as well.
« Reply #143 on: Tue, 12 August 2014, 16:54:04 »
74227-0
Just got this! I don't really have caps for it so right now it looks like a mess, also the numpad layout means nothing I just threw caps on so I could play with it.  :thumb:
Offline bianco
« Reply #144 on: Fri, 15 August 2014, 10:43:12 »
does anyone have the latest o2d keymapper?
i can't download the latest one in duck's site (02D_KeyMapper_Custom_v1.4.271.exe).
thanks in advance
Offline Ronnn
« Reply #145 on: Fri, 15 August 2014, 12:05:35 »
thanks in advance
You can download the latest firmware from here
http://kbdlab.co.kr/index.php?mid=board_sw&document_srl=100301
Offline bianco
« Reply #146 on: Fri, 15 August 2014, 15:38:30 »
thank
thanks in advance
thank you!
Offline Ronnn
« Reply #147 on: Fri, 15 August 2014, 16:17:34 »
thank
thanks in advance
thank you!
No problem, if by any chance you have leds installed, could you please tell me how many brightness levels your lightsaver have? You can use led dn and up key to control the brightness. I have asked in this and gb thread, no one answered my question...
Offline bianco
« Reply #148 on: Sat, 16 August 2014, 01:11:39 »
thank
thanks in advance
thank you!
i have tried to use this but wasn't able to change the level of the lights.
the led up/down only turns on/off the lights.
although, i might be reverting the older version of the keymapper as the arrow keys doesn't seem to save in the hex file using the latest keymapper.
even though i use the arrow cluster with the question marks, when i change to a different layer and go back to it, it becomes empty.
« Reply #149 on: Sat, 16 August 2014, 01:18:56 »
thank
thanks in advance
thank you!
it might be because the default fn key isn't like a regular fn key. it's actually a toggle to scroll through the layers.
there are different layers and different fn layers on a lightsaver. this caught me really off guard at first.
[I explained this pretty poorly; but know that there IS most likely a reason for your confusion, and it's because it's not entirely intuitive.]
In other news. I have a beautiful Lightsaver V1 that I will picture and post for you guys tomorrow, but I REALLY want to trade it for a v2 in 1800 layout.
 Also if someone could clarify that the PCB on v2 is indeed different.
