Author Topic: Foam decompressing :(  (Read 2975 times)
Offline Ghetto Caps
  • i make ghetto caps.
« on: Mon, 27 January 2014, 20:46:55 »
so my brand new filco wrist rest ins decompressing badly when i barely put any pressures one it?
anyone know how to get it to pop back up????
Visit the Typing Test and try![/sigpic]
Re: Foam decompressing :(
« Reply #1 on: Mon, 27 January 2014, 20:48:09 »
Is it legit? Or is it one of those fakes?
Offline Ghetto Caps
« Reply #2 on: Mon, 27 January 2014, 20:50:53 »
hmm it says Feete on the bottom.
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #3 on: Mon, 27 January 2014, 21:49:06 »
anyone know how to get it to pop back up? ???
Weird, I've got the TKL size version and the foam is pretty firm, the thing about it is that the bottom part (plate to which the foam is glued to) comes apart easily.  I suppose I live here in Hell Town and hence most glues give up the ghost.  All I did was find some polyurethane adhesive, applied it and now the bottom stays on.
If the foam is decompressing then you need to chuck it.....
Offline GeorgeK
« Reply #4 on: Tue, 28 January 2014, 03:29:31 »
That sounds faulty to me - mine's nearly 2 years old now and is still very firm.  I'll check what mine says on the underneath when I get home later.  Can you return it to the shop you bought it from?
Offline Ghetto Caps
« Reply #5 on: Tue, 28 January 2014, 20:18:17 »
its been 4 months so i cant really return it :(
