Author Topic: Mechanical Keyboards addict for years  (Read 1855 times)
Offline JinksyW
« on: Tue, 28 January 2014, 08:49:19 »
Hi, I've been on this forum quite few times and  finally have decided that it is time to go from passive to active and give something back to the community if I will have a chance to. :)
Regards.
Offline spuriousgeorge
Re: Mechanical Keyboards addict for years
« Reply #1 on: Tue, 28 January 2014, 22:45:56 »
Glad you joined, JinksyW!
Which keyboard (or if you're like most people on this site, keyboards) do you use? Any advice for someone looking to buy their first mechanical?
Offline atlas3686
  • HHKB Elite
« Reply #2 on: Wed, 29 January 2014, 05:54:46 »
Try as many switches as possible before you decide  :thumb:
« Reply #3 on: Wed, 29 January 2014, 07:54:59 »
Thanks, atlas3686!
That's great advice, especially with MX switches, since you can get those samplers from WASD Keyboards and elsewhere.
Offline TheHardkaare
« Reply #4 on: Sun, 02 February 2014, 09:05:24 »
Welcome to you :-)
You'll fit riiiight in :D
