Author Topic: Anyone know what component = VIN1 voltage reading in CPUPID HWMonitor?  (Read 5466 times)
Offline Voixdelion
 Can't for the life of me figure out what this particular sensor (voltage 1) is reading in this software - can anyone tell me what it is?
Asus P4p800-E
 Voltages
Hardware monitor    Winbond W83627THF
    Voltage 0    1.60 Volts [0x64] (CPU VCore)
    Voltage 1    3.22 Volts [0xC9] (VIN1)
    Voltage 2    3.31 Volts [0xCF] (+3.3V)
    Voltage 3    5.01 Volts [0xBC] (+5V)
    Voltage 4    11.86 Volts [0xC3] (+12V)
    Temperature 0    27°C (80°F) [0x1B] (SYSTIN)
    Temperature 1    21°C (69°F) [0x2A] (CPUTIN)
    Temperature 2    48°C (118°F) [0x1A0] (VTIN)
    Fan 1        2500 RPM [0x87] (FANIN1)
« Last Edit: Tue, 28 January 2014, 13:19:19 by Voixdelion »
"The more you tolerate each other, the less enforcement will happen."-iMav
