Author Topic: White POM jellys?  (Read 2810 times)
Offline C5Allroad
  • Formerly HUNTERANGEL121
White POM jellys?
« on: Wed, 29 January 2014, 20:22:28 »
Where can I buy some poms?
Offline tricheboars
  • Keyboards are Important!
Re: White POM jellys?
« Reply #1 on: Wed, 29 January 2014, 22:20:31 »
Signature Plastics sells black with white legend alpha Poms for 18$. Worth it.
Or you can buy a used or new cherry g81 like I have in my signature. They have POM  caps too.  But as for white POM caps I don't know. I don't think I have even seen white caps.
Ivan would know.
Offline Oobly
« Reply #2 on: Thu, 30 January 2014, 01:56:19 »
There is a Taobao listing for them: http://item.taobao.com/item.htm?id=10750871018
The colour ones are dyed and you can select an all-white set from the options. Use the proxy / agent of your choice, I really don't know which is best.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline C5Allroad
« Reply #3 on: Thu, 30 January 2014, 20:22:32 »
I can't seem to find the add to cart button or menu to select all white and such. It says This baby has been off the shelf....
Offline tricheboars
« Reply #4 on: Fri, 31 January 2014, 00:37:07 »
I have never done taobao. Too scaredy.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #5 on: Fri, 31 January 2014, 16:48:24 »
Yeah those KBC jellies are pretty much the only. I haven't seen them available for quite awhile, I suppose KBC stopped making them.
We probably could do a groupbuy for them through PLUM, but it's at least 300 sets. I heard they are likely to have more key sizes available in late spring/early summer.
« Last Edit: Fri, 31 January 2014, 16:50:08 by IvanIvanovich »
Offline C5Allroad
« Reply #6 on: Fri, 31 January 2014, 22:25:55 »
I never really heard about PLUM.... I never really looked into keycaps until now...
And those poms would look sexy with the blue leds on my board.
« Reply #7 on: Fri, 31 January 2014, 22:40:22 »
PLUM makes the Noppoo Choc mini, Neo Zelia, and a few models under the PLUM brand. I will be giving them a try in my current PBT groupbuy with the 'black' sets.
Offline C5Allroad
« Reply #8 on: Mon, 03 February 2014, 15:27:52 »
I wanted to try the Neo Zelia... Didn't know PLUM was behind it all though.
