Author Topic: Where can i buy 60% size keyboard?  (Read 3832 times)
Offline ajx
« on: Thu, 30 January 2014, 16:36:50 »
Hey i am looking for nice great 60% size keyboard
but it seems KBT Pure isnt available anymore
all Poker II are on sale from US
where can i buy Pure/Poker whatever 60% size keyboard with ANSI qwerty layout in EU?
Offline terran5992
  • One With The Cup Rubber
Re: Where can i buy 60% size keyboard?
« Reply #1 on: Thu, 30 January 2014, 18:26:58 »
If you want ansi layout , you would have to buy in from the US.
Id recommend qtan
http://www.vendio.com/stores/E-sports-Gaming-equipments/
Offline Pacifist
  • on hiatus
« Reply #2 on: Thu, 30 January 2014, 19:10:43 »
banggood?
Offline ajx
« Reply #3 on: Thu, 30 January 2014, 19:12:41 »
thanks, there are some poker and pure available, good to know
does qtan sell from china or us?
« Last Edit: Thu, 30 January 2014, 19:15:39 by ajx »
Offline ajx
« Reply #4 on: Thu, 30 January 2014, 19:16:57 »
banggood?
thanks fore the link
how reliable are they?
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #5 on: Thu, 30 January 2014, 19:18:16 »
banggood?
Processing and shipping is slow, but everything usually shows up to the best of my knowledge.
Offline terran5992
« Reply #6 on: Thu, 30 January 2014, 19:21:13 »
He sells from the US  AFAIK
Offline Pacifist
  • on hiatus
« Reply #7 on: Thu, 30 January 2014, 19:21:14 »
bg isn't reliable but they do the job.
It'll take around 2+ weeks to get the item, but it will be there and it will be cheaper than most other places. So take it with a grain of salt
  • Cherry Peasant
  • keycult.com
« Reply #8 on: Thu, 30 January 2014, 19:23:15 »
« Reply #9 on: Fri, 31 January 2014, 06:55:51 »
qtan sells from china
Offline ajx
« Reply #10 on: Fri, 31 January 2014, 15:26:04 »
what do you recommend to me, Poker 2 or Pure?
i owned them in the past, Poker 1 and Pure as well, i kinda appreciate 60% size.
backlit? is it reliable?
where can i find great keycaps for Poker 2 (i dont really like these PBT dark grey keys from Poker 2)
« Reply #11 on: Fri, 31 January 2014, 15:44:07 »
The backlighting is very good on the vortex boards from what I've seen, if a little but dimmer than most.
The Poker 2 is a very nice board, and you can put any standard ANSI/ISO set on it, as there are no layout quirks.
Offline katushkin
  • Too Keycool for School
  • Just the guy
Offline Oobly
« Reply #13 on: Sat, 01 February 2014, 05:41:09 »
ANSI Poker 2 from Banggood is about 80€ at the moment. They also have some nice blank POM and PBT caps which will fit for less than 20€ a set. Shipping is free, but it takes a LONG time. You can choose tracked shipping which is quite reasonably priced and should arrive sooner.
I am very happy with the sets of caps I bought from them.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline ajx
« Reply #14 on: Sat, 01 February 2014, 16:47:17 »
any link for Poker 2 keycaps?
Poker 2 seems to be the perfect 60% size keyboard to me but i dont really like those dark grey PBT keys, any chance to find full black keycaps compatible with?
Offline Oobly
« Reply #15 on: Sun, 02 February 2014, 02:26:10 »
http://www.banggood.com/POM-87-Set-Blank-Key-Caps-Black-Keycaps-For-Cherry-MX-Keyboard-p-84081.html
These are blank black POM. Nice keycaps, especially for the price. Any ANSI keycaps sets will fit, so you really have a LOT of options. Look through the Group Buys section for sets or ask in the Keycaps section. You can also get caps from:
http://pimpmykeyboard.com/
http://keycapsdirect.com/marketplace.php
http://www.wasdkeyboards.com/index.php/products/keycap-set.html
http://www.keyboardco.com/index.asp
And many other places.
Offline ajx
« Reply #16 on: Sun, 02 February 2014, 03:03:39 »
Sorry to bother you but can you show me a picture of your Poker 2 with POM keycaps?
i couldnt see anything on Banggood, pictures are too small.
thanks
Offline n0rvig
« Reply #17 on: Mon, 03 February 2014, 01:47:59 »
Pexon seems to have the Poker 2 with Red switches. That might suit you.
http://www.pexonpcs.bigcartel.com/product/poker-2-mechanical-keyboard
Offline Oobly
« Reply #18 on: Mon, 03 February 2014, 04:09:45 »
I don't have a Poker, but here are the keycaps as I got them from Banggood:
http://geekhack.org/index.php?topic=48643.msg1107427#msg1107427
That thread is all about the Banggood keycaps and there are some photos of boards with them on. They are a bit thinner than the stock Poker caps.
If you like Cherry profile thick PBT keycaps and want black, Ivan currently has a group buy going: http://geekhack.org/index.php?topic=50935.msg1117903#msg1117903
They will be the same colours as Realforce black on black keycaps.
Offline ajx
« Reply #19 on: Mon, 03 February 2014, 13:29:11 »
i eventually bought on Banggood, price was good
but i m expecting delivery and wonder if you guys already met local custom fees?
will they provide tracklist where we can find localisation of parcel?
Offline ajx
« Reply #20 on: Tue, 11 February 2014, 13:38:22 »
i go back to square one, Bg did not have Poker 2 in their stocks.
i highly dislike this kind of business behavior
when i orderered, it was pretty clear, they had in stock and now its back order (like mostly out of stock)
that why i contacted Qtan before ordering anything
