Author Topic: Keycaps on G80-11900  (Read 4023 times)
Offline 1pq
  • Hipster Doofus
« on: Fri, 31 January 2014, 07:00:09 »
Does anyone know what type of keycaps are on this keyboard?
main kbs:  87UB (55g)  Custom Filco TKL (62g clears)
WTS JD40, Custom Ergoclear Filco
WTB ROHS Red BBv2 (Topre), OG EK Tri-Color Skull (TOPRE)
Re: Keycaps on G80-11900
« Reply #1 on: Fri, 31 January 2014, 07:02:49 »
I believe the white version has PBT and the black has POM.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Fri, 31 January 2014, 12:51:11 »
There are also models with doubleshots, those will have an H in the model number like G80-11900HRMUS-2
Offline 1pq
  • Hipster Doofus
« Reply #3 on: Fri, 31 January 2014, 14:12:16 »
The model number for this one is G80-11900LUMEU-0 -- is that PBT? Are stock cherry PBT dyesubs thick or thin?
Offline ebacho
« Reply #4 on: Fri, 31 January 2014, 14:37:34 »
The modern white models are usually thin lasered PBT.
« Reply #5 on: Fri, 31 January 2014, 16:46:06 »
Right that would be lasered PBT. Thickness will depend on production year, but I would assume Cherry thin. But even Cherry thin is almost twice as thick as most OEM profile keys. They will most likely be just the same as those on that 3000 you had from me.
Offline moonexe
« Reply #6 on: Fri, 31 January 2014, 18:04:41 »
Cherry PBT next to GMK doubleshot. :rolleyes:
(My keys are dyed black, but originally white/beige)
G80-3000, MX brown           -           Filco Majestouch 2 HAKUA TKL+TK, MX brown, JIS Layout
Offline 1pq
  • Hipster Doofus
« Reply #7 on: Fri, 31 January 2014, 18:13:36 »
Ahh OK. Thanks for the info. Even though they were thin and lasered, those caps on the 3000 felt pretty nice. Once I get the blank ones from your GB though...this thing should feel great ;)
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #8 on: Mon, 07 April 2014, 15:48:46 »
How about a black G8011900LTMEU2?
|||My other keyboards :
x
