Author Topic: Is it safe to go from AT to PS2 to USB with adapters?  (Read 1974 times)
Offline runfrombears
« on: Fri, 31 January 2014, 15:39:27 »
I have an extremely rare, interesting Nickeldeon keyboard from 1994.  It has an AT connector.  I found a passive AT to PS2 connector that I am using right now.  However I'd like to try it on USB.  I just want to make sure I don't damage anything.
I have this USB adapter that I would tag on to the passive ps2 adapter.  Would this be safe for both my keyboard and motherboard?
http://www.amazon.com/PS2-Keyboard-To-USB-Adapter/dp/B000BSJFJS/ref=sr_1_5?s=electronics&ie=UTF8&qid=1351342595&sr=1-5
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
Re: Is it safe to go from AT to PS2 to USB with adapters?
« Reply #1 on: Fri, 31 January 2014, 15:47:08 »
That should work fine. You won't break anything, but sometimes you'll find an old keyboard that won't work with the Blue Cube, and you will need to try another PS/2 to USB converter. My Monterey K102 AT keyboard is one — won't work at all with a Blue Cube, but it's fine with a lousy Belkin. I've used a lot of AT keyboards with AT→PS/2→USB.
Bore Awards
