Author Topic: Stuck on a color scheme for my Ducky.  (Read 5533 times)
Offline jackh
« on: Fri, 31 January 2014, 20:38:44 »
I've been wanting to change my caps out forever, just don't know what color scheme to use.
This is what I've been entertaining lately. I like RGB modifiers.
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
Re: Stuck on a color scheme for my Ducky.
« Reply #1 on: Fri, 31 January 2014, 20:43:48 »
You won't find many people here recommending WASD keycaps. They're made of thin ABS (a plastic that will show wear and shine after continued use) and are lower-quality than other keycap sets at similar price points. I don't love WASD's colors either; I don't think they compose well.
That's just, like, my opinion, man. Ultimately, it's all down to your personal preference.  :thumb:
Also, welcome to GeekHack!
Offline jackh
« Reply #2 on: Fri, 31 January 2014, 20:44:52 »
What are some other alternatives? I'm new at this, obviously.
Offline FrostyToast
  • Litshoard
« Reply #3 on: Fri, 31 January 2014, 20:56:51 »
Here is a set of RGB modifiers which are dyesub PBT which is basically the best you can get.
http://www.originativeco.com/collections/keysets/products/bsp-rgb-set
As for the white and black keycaps, you can only buy full PBT sets for each colour (except for some possible rare exceptions in the classifieds) which could run you $50 a set.
Quote from: elton5354
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #4 on: Fri, 31 January 2014, 22:08:53 »
Except that the BSP RGB set won't fit on a Ducky since they use 1.5 size. Instead you could get some GMK Cherry doubleshot RGB from EK... and for the rest of the keys I would suggest to grab an old Cherry G80/G81 like one of these or these. They also exist in the inverse, with black legends on white/beige keys but I didn't see any on ebay in my quick look. Check the classifieds here for them. Might as well start at the top and get the best.
Offline nammkit
« Reply #5 on: Sat, 08 February 2014, 03:55:42 »
You could try the ones from banggood if you dont mind waiting some time( my last order took around 20 days).
- http://www.banggood.com/Keycool-PBT-Multicolor-Top-Or-Side-Or-Blank-Laser-Engraving-Keycap-p-84137.html
Offline KingSupreme
« Reply #6 on: Sat, 08 February 2014, 21:39:06 »
Who else other than WASD lets you modify the color of full set keycaps so that they're not all one color?  I would really appreciate the answer, especially if they come in PBT key caps.
Offline tbc
« Reply #7 on: Sat, 08 February 2014, 23:26:51 »
pretty sure no one lets you customize like that.
most people are happy with 2 colors and are willing to buy two sets (some combination of complete or mods/alphas only)
Offline RESPRiT
  • HHKB = ❤
« Reply #8 on: Sun, 09 February 2014, 02:36:31 »
If you want to go crazy with customizing your caps that's fine for WASD, the problem is a few things. For starters, the cap quality from there is just not great by any means. Additioanlly, you really don't need to have a ton of colors on your board for it to look nice, and in all honesty I think most WASD boards I see look ridiculous since people go overboard with the customization.
Offline MiR4i
« Reply #9 on: Sun, 09 February 2014, 23:52:22 »
Here's a link to an actual Ducky RGB modifier set:
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=713
Offline lolkey
« Reply #10 on: Wed, 12 February 2014, 10:01:42 »
Where can I download a PSD layout to color like you've done?
filco ninja mj2 tkl · mx brown · black case · blank black pbt
varmilo va87mr tkl · gateron red · black case · dye sub pbt ❤
vortex pok3r rgb · mx silent · white case · blank xda pbt
« Reply #11 on: Wed, 12 February 2014, 10:05:26 »
Check out this link from the Simple Questions Simple Answers OP
I recommend taking a look at the Keycap Color Scheme Archive for some ideas.
Offline Protato_Tubby
  • people enthusiast
« Reply #12 on: Wed, 12 February 2014, 11:58:53 »
Does your mouse have a colour scheme? It'd look nice of you could match that.
DELL AT102W Black Alps | IBM Model M 122 | Matias Tactile Pro 4
