Author Topic: Spilled water on Model M  (Read 6451 times)
Offline artlin
« on: Fri, 31 January 2014, 22:43:27 »
This morning, I accidentally spilled about half a cup of water into my Model M. I cleaned it off and it didn't show any symptoms at first, but then some of the keys acted like the traces were connected to other keys ("G" would result in "GT" and so forth).
I've set the keyboard to the heater and put a hairdryer to it, but the keys still don't work properly. I can't disassemble the keyboard because I'm an urban boy that don't need no power tools, and the keyboard uses rivets so there's that.
In the event that the conductive stuff doesn't dry out, how can I fix the keyboard without disassembling it?
« Last Edit: Fri, 31 January 2014, 22:45:32 by artlin »
Offline spuriousgeorge
Re: Spilled water on Model M
« Reply #1 on: Sat, 01 February 2014, 00:51:13 »
Sorry for your bad luck, artlin.
This may not be what you're after, but in the event that you can't fix the board yourself, there are a number of Geekhackers who might be up to the task (http://geekhack.org/index.php?topic=45886.0). You could also try Unicomp's repair service.
Offline EDI
« Reply #2 on: Sat, 01 February 2014, 03:28:43 »
Probably trace problem as you said.
You should order new membrane from Unicomp. They sell them for $10 http://pckeyboard.com/page/Misc/MEM. Just remember to specify what kinda membrane you want since those new Unicomp membranes are different than original IBM ones.
This of course means that you must do bolt-mod to get it back together.
Offline mich
« Reply #3 on: Sat, 01 February 2014, 05:04:57 »
Life without tools is miserable :)
Check the keyboard after few days. Water stuck between membranes will take a while to dry up, but it finally will.
There is not much you can do without bolt mod.
« Reply #4 on: Sat, 01 February 2014, 09:05:11 »
Give it several days and avoid heat, except for putting it outside in direct sunlight.
- Plato
Offline E TwentyNine
    • Some of My Keyboards
« Reply #5 on: Sat, 01 February 2014, 09:52:24 »
He doesn't need a new membrane or a bolt mod.  Letting the keyboard sit for a few days will do wonders.  It may take slightly longer.  Keeping the keyboard standing upright on its short end (sideways) may be useful.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #6 on: Sat, 01 February 2014, 09:58:41 »
true...............unless he loaded up with sweetner and cream?
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline tbc
« Reply #7 on: Sat, 01 February 2014, 23:26:55 »
unless he mistyped, he only spilled a cup of water.
