Author Topic: Lexmark model M parts interchange.  (Read 4498 times)
Offline naikon996
« on: Tue, 24 February 2009, 10:47:22 »
Hi there, I am thinking about purchasing a IBM 82G3292 keyboard(spanish layout).
I already own a 1988 1391401, 52G9658, and a customizer 101.
Would it be at all possible to swap the US layout from the Lexmark built 52G9658
I already have and transfer the keys to the spanish layout board?
I would imagine the frame of the older IBM built boards might be incompatible, but the
lexmark boards should be fairly interchangable...right?
Cheers:)
IBM Model M 1391401 (1988)
IBM Model M 1391401 (1989) *NIB*
IBM Model M 1370477 (1995)
Unicomp Customizer 101 (2008)
Cherry G80-3000LAMDE
Offline itlnstln
« Reply #1 on: Tue, 24 February 2009, 10:51:12 »
That shouldn't be too much of a problem; all the parts should be interchangable.  The only thing I can think of would be keycap shape differences if one 'board is an ANSI layout and the other ISO.
Offline naikon996
« Reply #2 on: Tue, 24 February 2009, 10:58:13 »
Ah right, might be worth a shot then.
Shipping to Ireland is a pain though:(
If anyone is interested, here is the link: clicky
Offline lowpoly
« Reply #3 on: Tue, 24 February 2009, 10:59:44 »
Quote from: itlnstln;22610
This.
Offline itlnstln
« Reply #4 on: Tue, 24 February 2009, 11:02:58 »
Right off the bat, you are going to have some issues with the Enter key and the left Shift (and non-existent caret key in the US model).  You can use the spring/hammer parts with no issues on these keys, you just won't be able to use the keycaps.
Offline naikon996
« Reply #5 on: Tue, 24 February 2009, 11:08:57 »
Quote from: itlnstln;22614
Oh well.
Thanks for the heads up. Better safe than sorry:o
Spanish layout should not be too much of a problem, but I like
the ISO 8859 layout too much.
Again. thanks:)
Offline itlnstln
« Reply #6 on: Tue, 24 February 2009, 11:26:49 »
The letters are certainly changable.  You would just need to leave the Enter and Left Shift/Carets.
Offline bhtooefr
    • bhtooefr.org
« Reply #7 on: Tue, 24 February 2009, 11:44:45 »
And the right backslash key functions the same, even though it's at a different place in the matrix - I'm not sure if they're wired identically, or seperately, but it's the same scancode.
Offline wumpyr
« Reply #8 on: Tue, 24 February 2009, 13:49:08 »
If you'd rather UK keycaps to replace the spanish ones, Unicomp will sell you a set for $20.
IBM Model M13 Raven Black \'96, \'97 (2), \'98 (2)
IBM Model M13 Industrial Gray \'96 (2)
IBM Model M Industrial Gray \'88, \'94
IBM Model M White Label 1391401 \'92
IBM Model M International \'95 (2), \'96
IBM Model M 52G9658 \'93
IBM Model M 1370475 Mini \'93
Offline lowpoly
« Reply #9 on: Wed, 25 February 2009, 05:22:16 »
Quote from: wumpyr;22630
Even with shipping it might be cheaper to get a german Model M from ebay.de and a keycap set from Unicomp than buying an original 1391406 on ebay.co.uk?
Offline Chloe
  • Switch Kitten
« Reply #10 on: Wed, 25 February 2009, 05:41:07 »
Are Unicomp keycaps two part?
Offline cchan
« Reply #11 on: Wed, 25 February 2009, 06:00:34 »
They can be. Unicomp sends two- or one-part caps on request.
HP Envy17: Core i7-2760QM, 8GB DDR3, 128GB Crucial m4 + 750GB Hitachi, Windows 7 Home Premium x64, Cherry ML4100, Logitech M500, HP zr22w
IBM Thinkpad X60: Core Duo T2400, 2GB DDR2, 128GB Samsung 830, Xubuntu 12.04 x86, Cherry ML4100, Logitech M205, HP zr22w
Raspberry Pi Model B: BCM2835, 0.25GB DDR2, 8GB Samsung SD card, Raspbian Wheezy, human interaction devices as above
