Author Topic: Cherry G80-3700  (Read 3856 times)
Offline daibo
Cherry G80-3700
« on: Tue, 24 February 2009, 12:18:00 »
Hi geekhackers,
Does anyone know which kind of switch the cherry g80-3700 uses? I intend to buy one to abuse as a poor man's Belkin n52. Its layout isn't too good to serve as an FPS controlling device, but for my needs (I mainly play DotA, a Warcraft 3 custom map) it might be just fine.
Offline lowpoly
Cherry G80-3700
« Reply #1 on: Tue, 24 February 2009, 12:21:24 »
Cherry MX linear/black.
Offline daibo
Cherry G80-3700
« Reply #2 on: Tue, 24 February 2009, 12:50:38 »
Quote from: lowpoly;22622
Thanks, do you have any experiences with that kind of switch regarding gaming?
And on another note, I have been trolling ebay lately to grab some Model Ms. As I'm looking for them on ebay Germany, most of them are UK-made. Is there any qualitative difference between US Ms and UK Ms? And should I buy the grey labeled ones over the blue labeled ones?
Thanks for your replies.
Offline itlnstln
Cherry G80-3700
« Reply #3 on: Tue, 24 February 2009, 12:56:26 »
Thse switches are non-tactile (and not clicky, for that matter), and gamers, in general, like that.  I don't think they would be my favorite for general typing duties as I prefer tactile switches.  That, and Cherry blacks are fairly stiff, though that would matter less for gaming than typing, IMO.  Deck and Steelseries keyboards use Cherry blacks, and they are marketed to gamers with a fairly strong following.
Offline Ulysses31
Cherry G80-3700
« Reply #4 on: Tue, 24 February 2009, 13:10:15 »
Just curious but what's the actuation point for the blacks?  Partially depressed or all the way down?
Offline zwmalone
Cherry G80-3700
« Reply #5 on: Tue, 24 February 2009, 15:30:59 »
The 3700 doesn't seem any cheaper than the n52... in some cases it's more expensive...
Can't get enough of them ALPS
Offline itlnstln
Cherry G80-3700
« Reply #6 on: Tue, 24 February 2009, 15:35:07 »
From experience, get the n52.  It kicks a*s.  Move with the d-pad, and use the buttons for whatever.  It helped my game tremendously since I had more controls at my fingertips, and I didn't have to waste keys on movement.  I don't game anymore, though.  I like to go outside and play these days. :)
Offline Eclairz
Cherry G80-3700
« Reply #7 on: Tue, 24 February 2009, 17:28:38 »
I have the ML version of the 3700 called the 4700, to be honest they are not easy to program, the n52 is developed by belkin uses decent rubber domes some one says and is much more easier to configure each button especially if you buy the Razer version as their drivers are usually decent and the razer version also lights up.
Lenovo ThinkPad TrackPoint Keyboard
RealForce 45g UK 88UB
FILCO Majestouch TenKeyPad
Offline daibo
Cherry G80-3700
« Reply #8 on: Tue, 24 February 2009, 18:15:57 »
Thanks everyone for your input.
I can't seem to find the classic n52 at a decent price anymore, just the newer version n52te (produced by razer iirc), which has worse keys according to some reviews. Don't need the d-pad anyway since RTS games are the only ones I play.
Offline Eclairz
Cherry G80-3700
« Reply #9 on: Tue, 24 February 2009, 18:22:06 »
D-pad is useful to traverse the map quicker in RTS, once you get used to it you will reduce the amount of scrolling you do ;-) Alternatively you could search for a MS Strategic Commander
http://www.neoseeker.com/Articles/Hardware/Reviews/strategiccommander/
I still own this piece of kit, and to be honest it is not being used, keys light up and feels nice in the hand but in the end i just preferred using a full size keyboard to complement my mouse.
Offline daibo
Cherry G80-3700
« Reply #10 on: Tue, 24 February 2009, 19:02:07 »
Quote from: Eclairz;22698
I can get the 3700 for very cheap. Good point about the d-pad though. Maybe Saitek's and Logitech's counterparts of the n52 deserve a shot too. Anyone here able to give a brief review on them?
Offline Chloe
  • Switch Kitten
Cherry G80-3700
« Reply #11 on: Wed, 25 February 2009, 02:53:47 »
Quote from: Ulysses31;22627
All Cherry MX switches have overtravel. Actuation point is at 2mm.
