Author Topic: alternative sources for feet (?) on custom KB cases  (Read 1582 times)
Offline jalaj
« on: Tue, 04 February 2014, 11:51:00 »
I'm looking for material similar to this:
http://www.kbdmod.co.kr/product/detail.html?product_no=26
Found some M3 (meaning they're compatible with M3 screws) flat, conical, countersunk aluminum washers of various colors on ebay.
I think these are usually meant for RC devices and even automobiles.
53217-0
53218-1
53219-2
//pics yoinked from ebay
Anyone have success using these as feet on their custom KB?
I'm looking because I want to stack up the washers at a higher height to increase the KB slant.
« Last Edit: Tue, 04 February 2014, 12:09:54 by jalaj »
Re: alternative sources for feet (?) on custom KB cases
« Reply #1 on: Tue, 04 February 2014, 12:04:25 »
You might search for aluminum feet used for computer cases.
Offline jalaj
« Reply #2 on: Tue, 04 February 2014, 12:14:53 »
Good tip. Though thus far my search is only coming across M4 screw compatible feet. Will keep looking. Thanks.
« Reply #3 on: Tue, 04 February 2014, 12:16:48 »
