Author Topic: Just destroyed a brandnew Qpad MK-80  (Read 3265 times)
Offline Levial
« on: Wed, 05 February 2014, 01:45:36 »
Hi Geeks,
just wanted to change the Blue LED from my MK80 to pink ones.
Used these here http://www.ebay.com/itm/130868524773?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Used a Keyboard with blue LEDs cause the Voltage for the LEDs is the same.
Desoldered the old ones soldered the new ones without problems. Tested it with a single Pink LED and it worked. A little dark but it worked.
After installing the rest the new LEDs stay dark and the Keyboard is not recognised by the PC via Usb. PS/2 works still.
Desoldered every single LED, same error.
Any ideas what could have gone wrong here?
« Last Edit: Wed, 05 February 2014, 08:19:29 by Levial »
CM Storm Quickfire TK MX Brown
Logitech G13 Mechanical Mod Mx Brown
Offline joneslee85
  • HHKB Scrub JP
  • Professional Rubyist programmer!
    • Ruby Journal
Re: Just destroyed a brandnew Qpad MK-80
« Reply #1 on: Wed, 05 February 2014, 01:47:35 »
It seems to me you have short-circuit, what you could do desoldering-all and solder one by one, each comes with testing.
TOO MANY KEYBOARDS THAT I COULD NOT COUNT! BUT I AM STILL USING MY MODEL F77
Offline Levial
« Reply #2 on: Wed, 05 February 2014, 13:47:38 »
So after some Hours of testing als measuring I've found the problem.
I desoldered this little guy here:
http://cdn.pollin.de/article/big/G160076.JPG
After that I couldn't notice any difference except that my LEDs are working now.
I thougt that Thyristor is for the light-dimming but that works too after desoldering.
Maybe a broken LED toastet that thing?
Any ideas what else is it good for?
Offline regack
« Reply #3 on: Wed, 05 February 2014, 13:57:00 »
Voltage regulator, mosfet... hard to tell just from the TO-220 package outline.
Offline Levial
« Reply #4 on: Thu, 06 February 2014, 02:09:52 »
I just wonder that it seems to have no function. Everything works without that thing...
Eccept USB recognition, maybe it switches between USB+PS/2 mode? But that would make not much sense, a normal transistor could do that.
Electronic is a mystery sometimes  ;)
« Last Edit: Thu, 06 February 2014, 02:21:30 by Levial »
