Author Topic: Why Ergo Clears?  (Read 44705 times)
Offline 1pq
  • Hipster Doofus
Re: Why Ergo Clears?
« Reply #100 on: Mon, 10 February 2014, 21:38:02 »
This is true, but I just want point out that my custom aluminum plate seems to sit a decent amount lower than the stock filco one. Perhaps I'm just imagining things, though.
main kbs:  87UB (55g)  Custom Filco TKL (62g clears)
WTS JD40, Custom Ergoclear Filco
WTB ROHS Red BBv2 (Topre), OG EK Tri-Color Skull (TOPRE)
Offline robertsig
« Reply #101 on: Mon, 10 February 2014, 21:43:31 »
Here it is.
« Reply #102 on: Mon, 10 February 2014, 21:49:20 »
With a Keycool you will have to desolder each switch in order to open it.
Offline Pacifist
  • on hiatus
« Reply #103 on: Mon, 10 February 2014, 21:53:55 »
Pretty much every non community made board requires desoldering to remove switches
Offline 1pq
  • Hipster Doofus
« Reply #104 on: Mon, 10 February 2014, 21:55:19 »
That isn't made by cherry, or isn't a Poker, or an ergodox. So, not really :p
Offline robertsig
« Reply #105 on: Mon, 10 February 2014, 21:58:42 »
Oh that sucks.  I don't think I'm willing to go through that surgery.
Offline 1pq
  • Hipster Doofus
« Reply #106 on: Mon, 10 February 2014, 22:05:06 »
If you don't want to mess around, you should buy a G80-3000 for cheap and muck around. You won't have to get your hands dirty with soldering, and you can play around with springs and lube and such.
Offline ideus
  • Björkö.
« Reply #107 on: Mon, 10 February 2014, 22:11:09 »
OK so my Poker X pcb mounted switches are good candidates for moding...hehe.
Offline robertsig
« Reply #108 on: Tue, 11 February 2014, 05:28:43 »
What is a good TKL board to buy where it is easy to change all the switches to clears?  I bought a board with Clears built-in, not knowing it would be difficult to open the switches up.
Offline 1pq
  • Hipster Doofus
« Reply #109 on: Tue, 11 February 2014, 08:15:13 »
I don't know of any PCB mounted TKLs, but you might be able to pick up a custom TKL with a plate that allows for customization in the classifieds. You could also pick up a G80-1800, which is closer to a TK layout.
« Reply #110 on: Tue, 11 February 2014, 08:20:27 »
You could buy the phantom listed here http://geekhack.org/index.php?topic=54030.0
Offline 1pq
  • Hipster Doofus
« Reply #111 on: Tue, 11 February 2014, 08:23:33 »
I think the point was so he didn't have to solder, though.
« Reply #112 on: Tue, 11 February 2014, 08:27:20 »
The phantom allows for switch top removal.
Offline 1pq
  • Hipster Doofus
« Reply #113 on: Tue, 11 February 2014, 08:28:58 »
Oops, I didn't click on the link and thought you were liking him to a PCB, not an assembled board with a phantom. :rolleyes:
Offline robertsig
« Reply #114 on: Tue, 11 February 2014, 09:14:00 »
Well, I already bought the keyboard.  It would probably come out to the same price if I just found someone here was was more handy with a soldering iron than me, and pay him.  :)
Offline 1pq
  • Hipster Doofus
« Reply #115 on: Wed, 19 February 2014, 10:36:51 »
I just swapped some of the stock clears on my custom filco with 62g korean springs, and I have to say...this is the most excited I've been about a keyboard since I tried topre. Know that I'm a little biased, since I usually prefer lighter keyswitches, but I much prefer 62g springs to the stock clear ones. They make the switch feel much more tactile.
Offline robertsig
« Reply #116 on: Wed, 19 February 2014, 11:27:41 »
The 62g Korean springs ARE lighter than the stock clear ones.
« Reply #117 on: Wed, 19 February 2014, 11:29:00 »
Very much so. 62g Korean springs are almost equivalent to stock blue/red/brown springs.
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #118 on: Wed, 19 February 2014, 11:31:05 »
... He realizes that. That's why he's saying that he's biased :).
Offline 1pq
  • Hipster Doofus
« Reply #119 on: Wed, 19 February 2014, 11:31:11 »
Exactly. That's why I'm saying I might be slightly biased in preferring them, because I generally enjoy lighter switches more.
Offline robertsig
« Reply #120 on: Thu, 06 March 2014, 19:10:44 »
I had a user on GH unsolder the switches for me on my new Keycool Cherry MX Clear based board and put on 65g Korean springs.  Wow...this is easily the best Cherry based keyboard I've used.  67g might be slightly better, but this is fine.  I still prefer Topre, but I now finally have a Cherry board that is sufficient to use as a backup.
Very nice feeling for those who want a bump before it breaks (a la Topre, a la buckling spring).  Although compared to Topre, it still feels somewhat cheap, but not as much as Reds/Browns (which feel like a Playskool toy)
Offline xuanwumen
  • * Commercial Vendor
    • EZKB
« Reply #121 on: Fri, 07 March 2014, 05:26:15 »
Feel happy to see the keycool mx clear board can be useful to you.
NIZ KEYBOARDS VENDOR
