Author Topic: Which tenkeyless/60% should I get?  (Read 5485 times)
Offline Roibhilin
  • Saver of Humens
« on: Wed, 05 February 2014, 15:32:11 »
Hi guys, I'm new here and I decided that I'm going to get a new tenkeyless board with Blues+custom keycaps to complement my Quickfire TK since it's apparently difficult to replace all of the keycaps on it.
A Quickfire Rapid is out of the question because I already have a CM product and in general I don't like the "look" they have, so far the one I'm thinking of is this Leopold: http://elitekeyboards.com/products.php?sub=leopold,tenkeyless&pid=fc200rcab
I'm on a 100 dollar budget(not including the keycaps), should I get a Poker II or a Choc Mini instead?
« Last Edit: Wed, 05 February 2014, 15:41:48 by Roibhilin »
QFR | Poker II | Quickfire TK
Re: Which tenkeyless should I get?
« Reply #1 on: Wed, 05 February 2014, 15:35:10 »
Your title and last question are contradictory. Do you want a TKL or 60% layout?
Offline Roibhilin
  • Saver of Humens
« Reply #2 on: Wed, 05 February 2014, 15:41:11 »
Sorry, I got them mixed up, tenkeyless keyboards just have the numpad chopped off while 60% ones just have the numbers/letters, right?
If that's the difference brb, changing title
Re: Which tenkeyless/60% should I get?
« Reply #3 on: Wed, 05 February 2014, 15:44:49 »
Example of a 60% board:
From here
Example of a TKL board:
From webwit's site
So yes you're correct. You might also find this helpful.
I recommend a Filco MJ2 for the TKL option and Poker 2 for the 60% option. And welcome to GeekHack! :D
Offline Roibhilin
  • Saver of Humens
« Reply #4 on: Wed, 05 February 2014, 15:57:52 »
From here
From webwit's site
Thanks  :D
I can't afford the Filco for a while and the Poker is just in my budget, what would your second choice be instead of the M2 if I get a TKL?
Offline abtrout
« Reply #5 on: Wed, 05 February 2014, 16:00:20 »
CM Storm QFR (Quickfire Rapid) seems to be a popular choice based on my forum lurking :) They are pretty cheap, too!
Offline Roibhilin
  • Saver of Humens
« Reply #6 on: Wed, 05 February 2014, 16:04:27 »
Are those still really overbranded? I'm worried the case design won't go with the keycaps I want to get for it.
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #7 on: Wed, 05 February 2014, 16:11:19 »
They used to be overbranded, but aren't anymore. There is no branding on the top of the case (just matte black), and a CMStorm logo on the back left side of the case (if you're sitting in front of the keyboard you can't see it).
  • Cherry Peasant
  • keycult.com
« Reply #8 on: Wed, 05 February 2014, 16:12:26 »
See here for pictures of what they look like now.
Offline Roibhilin
  • Saver of Humens
« Reply #9 on: Wed, 05 February 2014, 16:31:02 »
The spacebar is standard size, right?
One of the reasons I'm getting another is because I can't replace all of the keycaps on my TK thanks to the 6.5x spacebar  :(
  • Cherry Peasant
  • keycult.com
« Reply #10 on: Wed, 05 February 2014, 16:31:45 »
Yes, the QFR is a great board for modding in pretty much every way. Completely standard keyset.
Offline Comment
« Reply #11 on: Wed, 05 February 2014, 16:33:20 »
I have both a choc mini and poker 2. I definitely recommend the poker 2 cause I fat finger too much for my noppoo. Definitely not a fan of the layout and you get used to the fn layer.
Check out my WTB/WTS/WTTF Thread!
   HHKB Pro 2                 Noppoo Choc Mini
Offline mooswa
« Reply #12 on: Wed, 05 February 2014, 16:42:09 »
QFR is great.  There is also a programmable replacement controller board for it - Frosty Flake - so you can mod it to support a custom layout as well.
Offline Roibhilin
  • Saver of Humens
« Reply #13 on: Wed, 05 February 2014, 16:57:01 »
Welp, guess I'm going with the QFR after all, where do people get that grey casing for it though?
« Reply #14 on: Wed, 05 February 2014, 17:58:22 »
hhkb
wait didn't see the budget. sorry.
save up more and buy hhkb.
(or a used poker, since i think they retail over 100)
Offline Roibhilin
  • Saver of Humens
« Reply #15 on: Wed, 05 February 2014, 18:16:22 »
hhkb
no way am I getting a 260 dollar keyboard  :-X
« Reply #16 on: Wed, 05 February 2014, 18:20:43 »
not with that attitude you aren't!
Offline heedpantsnow
  • Old enough to know better
« Reply #17 on: Wed, 05 February 2014, 19:16:52 »
I also recommend a used Poker I or II over the Choc Mini.  I didn't like my Choc Mini at all, especially the keycaps.  Plus it's hard to replace them whereas it's not so bad for the Pokers.
I'm back.
Offline Comment
« Reply #18 on: Wed, 05 February 2014, 20:07:29 »
Poker poker poker poker poker!!!
Offline Roibhilin
  • Saver of Humens
« Reply #19 on: Wed, 05 February 2014, 21:12:55 »
So far I'm torn between the Poker and the QFR  :-\
Offline Comment
« Reply #20 on: Wed, 05 February 2014, 21:14:53 »
The QFR is very nice for the price. Personally I love the 60% layout and that you can mod just about anything on it. Much more bang for your buck IMO but its all preference.
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #21 on: Wed, 05 February 2014, 21:17:26 »
Get a HKKB.
Disclaimer: I'm just channeling the popular opinion here.
Offline Roibhilin
  • Saver of Humens
« Reply #22 on: Wed, 05 February 2014, 21:35:02 »
Get a HKKB.
I can't afford a HHKB. I'm paying for college and I still can't justify spending 260 dollars on a keyboard.
Offline Roibhilin
  • Saver of Humens
« Reply #23 on: Wed, 05 February 2014, 21:43:54 »
Thanks for the answers guys, what are the keycaps on the QFR made of? Amazon says they're lasered but they don't specify whether it's PBT or ABS.
Offline Comment
« Reply #24 on: Wed, 05 February 2014, 21:50:11 »
I believe theyre ABS
Offline Roibhilin
  • Saver of Humens
« Reply #25 on: Wed, 26 February 2014, 17:38:17 »
sorry if this necroposting, pulled the trigger and got a QFR with Blues!
i'd recommend it to anyone here who likes MX switches and wants a good, customizable board
