Author Topic: Key Pullers  (Read 3244 times)
Offline pexon
  • El Jefe of Sleeving
    • Pexon PCs
Key Pullers
« on: Thu, 06 February 2014, 12:35:06 »
I am interested in getting a nice new key puller, something that will not damage thin ABS caps. I have seen some cool turned metal ones, does anyone know where I can pick one up from? Classifieds?
Offline C5Allroad
  • Formerly HUNTERANGEL121
Offline pexon
    • Pexon PCs
Re: Key Pullers
« Reply #3 on: Thu, 06 February 2014, 13:55:25 »
Offline esoomenona
  • Gnillort?
Re: Key Pullers
« Reply #4 on: Thu, 06 February 2014, 13:58:59 »
Offline tricheboars
  • Keyboards are Important!
Re: Key Pullers
« Reply #5 on: Thu, 06 February 2014, 14:00:16 »
how are you damaging keycaps with a puller? holy moley you guys must go Conan on your caps.
then again i dont really do crappy caps so maybe that is why i havent had to deal with issues like this.
Offline pexon
    • Pexon PCs
Re: Key Pullers
« Reply #6 on: Thu, 06 February 2014, 14:01:24 »
I haven't damaged my keycaps, I simply want a quality puller that will not put any undue stress on my new AT101W caps
Re: Key Pullers
« Reply #7 on: Thu, 06 February 2014, 14:03:45 »
Honestly this is the best key cap puller ever
http://geekhack.org/index.php?topic=45795.msg967098#msg967098
Just DIY!
Offline Tym
Re: Key Pullers
« Reply #8 on: Thu, 06 February 2014, 14:06:10 »
Only problem with those MKC ones were that alot arrived with bent parts, but i think they were straightened out pretty easily.
Offline pexon
    • Pexon PCs
Re: Key Pullers
« Reply #9 on: Thu, 06 February 2014, 14:06:34 »
Just DIY!
Thats awesome, I will give it ago, cheers Ray
Offline BlueBär
Re: Key Pullers
« Reply #10 on: Thu, 06 February 2014, 15:10:36 »
Those plastic keypullers (those without a wire) can scratch your keycaps, which is especially bad for backlit keycaps as they just have a thin coat of paint on the outside.
Offline HPE1000
  • Keycap Paparazzo
Re: Key Pullers
« Reply #11 on: Thu, 06 February 2014, 15:34:37 »
I don't know, my wire keypuller screwed up a couple of my GMK keycaps. It dug into the edges of some of them.
Re: Key Pullers
« Reply #12 on: Thu, 06 February 2014, 15:35:28 »
Yeah, Alps are tough to remove. Use that keypuller!
