Author Topic: eBay GeekFang Aluminum Space Bar is too loose, won't fit - Help!  (Read 2112 times)
Offline SonicRevolution
  • * Commercial Vendor
    • Qwerkywriter
« on: Thu, 06 February 2014, 23:01:31 »
Hey you guys,
Just got the new aluminum space bar from GeekFang.  Unfortunately, the bar is just way too loose.  It looks like the stems are cut too wide or something.  I'm trying to fit this on a KB 60.
Any tips?
SonicRevolution
www.qwerkywriter.com
@qwerkywriter on Twitter
Offline jalaj
Re: eBay GeekFang Aluminum Space Bar is too loose, won't fit - Help!
« Reply #1 on: Thu, 06 February 2014, 23:02:50 »
use plastic wrap as shims
Offline ebacho
« Reply #2 on: Thu, 06 February 2014, 23:26:09 »
Take a plastic bag, cut small squares, and use them to fill some of the space.
Offline Photoelectric
« Reply #3 on: Thu, 06 February 2014, 23:41:33 »
Use pliers and very gently push the stem parts closer together a very small amount.  Do this gradually in steps until the spacebar fits more tightly.
    • Qwerkywriter
« Reply #4 on: Fri, 07 February 2014, 11:20:54 »
Again, you guys are amazing!  Thx for the tips.  I will try this tonight!
SonicRevolution
