Author Topic: Noppo Choc Mini Registering Keystroke twice ??  (Read 1282 times)
Offline Abn
« on: Sat, 08 February 2014, 19:24:39 »
So my noppo choc mini recently started doing this thing on like the s aand some other keys like the a as it just did when i typed and. It registers twice and its so frustrating does anyone know a fix for this? Thank you.
EDIT: Red switches btw.
Noppoo Choc Mini Reds | Ducky Shine 3 TKL Browns | Topre Realforce 87U 45gram
Offline m1_account
Re: Noppo Choc Mini Registering Keystroke twice ??
« Reply #1 on: Sun, 09 February 2014, 15:34:43 »
This is a common issue with the Choc Mini. There is, in fact, an issue about Choc Minis on page 1 in which this issue is mentioned. A lot of people have solved this by using Fn+F10/F11 (if I remember the keys correctly) to change the setting. As for me, it did nothing to solve the problem on my Choc Mini. Good luck.
Offline aref
« Reply #2 on: Sun, 09 February 2014, 16:31:55 »
I've heard and read of the same problem from other Noppo Choc Mini users. Sorry to hear that yours has gone this route.
Offline syntinex
« Reply #3 on: Sun, 09 February 2014, 22:09:03 »
I've had the same issue with mine. It started with just the a or s key and has now spread around to more keys. It was my 1st mech and now it's on the bench cause it drives me bonkers...I have the old model btw.
