Author Topic: Boredom + two boards with MX-compatible switches = ...  (Read 72949 times)
Offline bhtooefr
    • bhtooefr.org
« on: Sat, 28 February 2009, 17:50:09 »
Yes? No?
I know I didn't get all the keycaps switched over - unfortunately, there were supports on some of those keys...
Offline lam47
« Reply #1 on: Sat, 28 February 2009, 18:16:42 »
Im sorry but no. Its horrible :(
Keyboards. Happy Hacking pro 2 x2. One white one black. IBM model M US layout. SGI silicone Graphics with rubber dampened ALPS. IBM model F. ALPS apple board, I forget what it is. And some more I forget what I have.
Typewriters. Olivetti Valentine. Imperial Good Companion Model T. Olympia SM3
Offline bhtooefr
    • bhtooefr.org
« Reply #2 on: Sat, 28 February 2009, 18:17:54 »
Can't do Caps Lock, either Shift, Backspace, Enter, right + or Enter, and the backslash keys won't interchange (but both of the Laser's backslashes WILL fit on this board - left backslash on the Windows key, and right on either the right Windows key or the menu key.)
Either way, I decided to switch it back...
Offline FKSSR
« Reply #3 on: Fri, 06 March 2009, 14:33:53 »
I think the black one is okay.  Really, it comes down to what you like.  If you like the way it looks, or it helps you do any tasks, then who cares what anyone else thinks? :P
Add me on Steam | Twitter
