Author Topic: What font is this?  (Read 5661 times)
Offline 007brendan
What font is this?
« on: Sun, 09 February 2014, 01:39:41 »
Saw this geekhack keyboard.  I like the font.  Does anyone know what font this is?
I thought maybe it might be some type of Helvetica, but I'm not sure.  Any other good fonts like this?
http://s10.photobucket.com/user/andrelyn/media/DSC_0531.jpg.html
http://s10.photobucket.com/user/andrelyn/media/DSC_0538.jpg.html
http://i10.photobucket.com/albums/a118/andrelyn/DSC_0537.jpg
Edit:  Here's another one that's pretty similar
http://www.pimpmykeyboard.com/deals/skull-squadron-base-set-2/
« Last Edit: Sun, 09 February 2014, 04:41:16 by 007brendan »
Offline Zeal
    • Zeal Generation Inc.
Re: What font is this?
« Reply #1 on: Sun, 09 February 2014, 02:04:44 »
Edit: It's round 3 Dolch replica using what seems like SP's "ISOTHERM LINE" font.
« Last Edit: Sun, 09 February 2014, 02:12:02 by Zeal »
Offline 007brendan
« Reply #2 on: Sun, 09 February 2014, 02:45:28 »
Thanks.  You're right, the color scheme looks a lot like the dolch replicas.  As for SP ISOTHERM, I found this:
http://keycapsdirect.com/pdfs/LineFont.pdf
I don't think the font is the same.  The numbers definitely don't match and the F, C, and O keys look pretty different.
Offline 007brendan
« Reply #3 on: Sun, 09 February 2014, 14:54:40 »
For those interested, the font is Core Humanist Sans.  Thank god for www.identifont.com
Offline Coreda
« Reply #4 on: Sun, 09 February 2014, 21:59:09 »
Try typing out QWERTY 123 in the sample text box on MyFonts, you'll see the 'Q' and '3' don't match. Appears to be a different typeface.
If it's close enough for what you need might as well use it though :thumb:. I haven't had much success with font ID sites in the past, even with clean samples, as often they can be custom typefaces or the engine doesn't recognize an exact match.
Offline aref
« Reply #5 on: Fri, 14 February 2014, 16:59:35 »
Nice site when looking to identifying a font. Good find.
Offline jacobolus
« Reply #6 on: Sun, 16 February 2014, 04:32:33 »
If you really want a typeface identified, go ask at http://typophile.com/fontid and you’ll get answers from the pros.
Offline Coreda
« Reply #7 on: Sun, 16 February 2014, 06:38:50 »
Or the community side of MyFonts WTF once you've run through the automated search. I've ID'd some fonts in the past, including some lettering.
