Author Topic: I nearly lost an eye today.  (Read 7059 times)
Offline lam47
« on: Sun, 01 March 2009, 08:27:37 »
Im stupid.
There is no other word for it.
I was working on the palm rests I know some of you are waiting for.
Well 3 have been cut and were ready to have the chamfer added to the front.
This is done with a router.
I have my router mounted upside down under the desk and the chamfer bit sticks up through a hole.
I had just put a new one in and tightened the chuck.
Im cutting away and it flies out of the router!
This is an inch across piece of steel with a cutting blade on either side.
Still spinning in the air it cuts into my face just to the side of my eye.
I am so lucky it did not go in it as it would have gone through the eyelid and into the eye for sure.
I will from now on wear goggles at all times.
No exception!
There may be a delay on the rests until I have sorted out the router.
Its a dewalt which are normally very good.
Looking at the messy cut and the scorch mark I think it could have been in crooked but I am not sure how.
Keyboards. Happy Hacking pro 2 x2. One white one black. IBM model M US layout. SGI silicone Graphics with rubber dampened ALPS. IBM model F. ALPS apple board, I forget what it is. And some more I forget what I have.
Typewriters. Olivetti Valentine. Imperial Good Companion Model T. Olympia SM3
Offline iMav
  • geekhack creator/founder
« Reply #1 on: Sun, 01 March 2009, 08:42:46 »
Wow.  Glad you are ok.  How bad did you cut your face?
Offline Chloe
  • Switch Kitten
« Reply #2 on: Sun, 01 March 2009, 08:59:01 »
:eek: I'm glad you're okay.
Offline lowpoly
« Reply #3 on: Sun, 01 March 2009, 09:07:37 »
Good you didn't get hurt seriously.
No exception!
Safety first, always.
Offline lam47
« Reply #4 on: Sun, 01 March 2009, 09:14:54 »
The cut is deep but not too long. I think the bone stopped the chamfer bit :)
I have steri stripped it together and its a bit painful but not too bad.
Thanks guys.
Im going to buy some good goggles tomorrow.
No work till then.
I find they compromise my sight on detailed stuff so I will look for some high quality ones.
Offline ozar
« Reply #5 on: Sun, 01 March 2009, 10:30:56 »
Wow, glad you are alright and things didn't go for the worse.  Safety glasses are definitely a must with most power tools.  Some type of good ear protection isn't a bad idea, either.
Offline Zalusithix
« Reply #6 on: Sun, 01 March 2009, 14:40:30 »
You're damn lucky... that's for sure. Beyond the glasses, I'd definitely check to make sure that the router itself is functioning properly like you said. If you did properly tighten the bit in, it should NOT have flown out. Seriously... I get goosebumps even thinking about a router bit flying through the air.
Offline wellington1869
« Reply #7 on: Sun, 01 March 2009, 15:24:56 »
No exception!
good god man, I'm amazed that you havent been. yes, please do.
using: ms 7000/Das 3
Offline D-EJ915
« Reply #8 on: Sun, 01 March 2009, 16:23:59 »
Quote from: ozar;23193
yeah ear protection when sawing & stuff is a must that stuff is so loud.
That hitting me would have scared the crap out of me O.O
Offline nerp
« Reply #9 on: Sun, 01 March 2009, 16:33:24 »
Everyone I know has had a close call like this and worn goggle since. It's like spilling that cup of coffee next to your keyboard instead of on it and then swearing to never put your coffee there agian.
U N I.C O M P - Am I the only one that likes the logo?
Offline itlnstln
« Reply #10 on: Mon, 02 March 2009, 08:31:09 »
I am glad to hear you are OK.  I know some of the DIY shops around here do sell high quality protective eyewear using optical grade polycarbonate for the lenses, and they are aroung $50 - $60.  For the type of you do and your saftey, they would be well worth it.
Offline bigpook
« Reply #11 on: Mon, 02 March 2009, 08:49:48 »
I had a similar experience a few years back. I was disassembling an old bbq grill, pretty straight forward. There was this piece that looked like the letter H. For whatever reason I wanted to break it down, I went at it with a hack saw but couldn't cut all the way through.
So I started twisting the 2 vertical pieces of the H, back and forth, almost there...
It snaps, the right vertical piece now has the sharp end of the horizontal piece, -l  which
flys back to my head. It was about an inch or so from my left eye. It broke the skin on my farhead. And it hurt quite a bit. I would have lost my eye for sure if it had made contact.
Thankfully,  none of my neighbors saw this, I was so retarded.
People at work said the cut looked like the lightning bolt on Harry Potter.
So yeah, when in doubt, wear eye protection, and gloves if need be.
Its not like I can go down to Wal-Mart and get a new eyeball : )
Offline Eclairz
« Reply #12 on: Mon, 02 March 2009, 17:45:07 »
I haven't done wood work in ages but heard lots of horror stories. Anyway goggles always got in the way but i would always wear them just in case. Lucky you had a great escape and lived to tell the tail, must sting like hell though.
Lenovo ThinkPad TrackPoint Keyboard
RealForce 45g UK 88UB
FILCO Majestouch TenKeyPad
Offline Haruko
« Reply #13 on: Thu, 05 March 2009, 05:25:21 »
I'm glad you're okay :/ the cut still sounds awful though.
Using: White Label IBM Model M (1391401) (Dec 92\')
Offline FKSSR
« Reply #14 on: Thu, 05 March 2009, 12:42:39 »
Man, that's scary.
I'm very glad you're okay!
Add me on Steam | Twitter
Offline lam47
« Reply #15 on: Thu, 05 March 2009, 16:02:28 »
Thanks everyone :)
I'm not too bothered by cuts to be honest.
I used to partake in Downhill racing then BMX flatland so am used to surface wounds.
I don't like it when there is something wrong and you cant see it because its inside.
Currently I am suffering from something and not knowing exactly what is horrible and frighting.
I have some good goggles now so hope to get back in the shed soon and get some rests made (and joysticks)
Again I appreciate the concern :) XX
