Author Topic: PCBs that fit QFR Case  (Read 1415 times)
Offline tricheboars
  • Keyboards are Important!
« on: Sun, 09 February 2014, 20:37:19 »
So i am disappointed to discover that phantom pcbs do not fit into qfr cases.  Which PCBs do fit that can be bought separately? I want to build something for no reason.
Re: PCBs that fit QFR Case
« Reply #1 on: Sun, 09 February 2014, 20:38:48 »
You can put a phantom in a QFR case, I did.
Offline tricheboars
« Reply #2 on: Sun, 09 February 2014, 20:45:19 »
WFD wrote that he had to drill holes in the PCB of the phantom to get it to fit.  Did you not have to do that?
« Reply #3 on: Sun, 09 February 2014, 21:17:50 »
All I had to do was clip one of the standoffs in the bottom of the case, everything else lined up.
There's a thread about it somewhere around here.
