Author Topic: Chicony KB-5161  (Read 8805 times)
Offline ianxblog
  • no
Chicony KB-5161
« on: Tue, 11 February 2014, 19:49:57 »
As a new keyboard collector, I'm wondering what switch does this keyboard have.
Thanks.
PD: You guys rule! You know a lot and have the same passion around keyboard than me. Love yall
Offline ianxblog
  • no
Re: Chicony KB-5161
« Reply #1 on: Tue, 11 February 2014, 19:56:53 »
I found on an old thread that it haves blue alps. Are they good? How they compare to cherry mx, blue for example?.
Re: Chicony KB-5161
« Reply #2 on: Tue, 11 February 2014, 20:06:01 »
They are the best. Some of us prefer Alps to Cherries, especially for typing.
- D Trump 2026-09-28
Offline ianxblog
  • no
Re: Chicony KB-5161
« Reply #3 on: Tue, 11 February 2014, 20:08:28 »
I read 70g actuation force on a site. 70g???? Isn't that a LOT? Is that info bad or are they fatigatin when typing?
Offline PRISONER 24601
Re: Chicony KB-5161
« Reply #4 on: Tue, 11 February 2014, 20:09:46 »
Knowing chicony, it could be anything from a blue alps to a fake cherry...
they're not known for their consistency
Ever tried. Ever failed. No matter. Try Again. Fail again. Fail better.
G80-3000LSCRC-2 (MX), "Ricercar" G86-6241OEUAGSA (MX), MX11800 (MX), AEKII (ALPS), AEK (ALPS) Apple Keyboard A9M0330 (ALPS), IBM Model F XT (Bucking Spring), IBM Space Saver 1391472 (Bucking Spring).
Offline ianxblog
  • no
Re: Chicony KB-5161
« Reply #5 on: Tue, 11 February 2014, 20:20:41 »
Here is a picture of the keyboard.
Not showing the switch, sadly.
Offline ianxblog
  • no
Re: Chicony KB-5161
« Reply #6 on: Tue, 11 February 2014, 20:28:04 »
Oh, and here's some info on the ad. I don't know why I didn't put it on first place.
Chicony
S/N: E8H5IKKB-5161
Product Name: AT XT Vintage 5161 Keyboard AT Clicky
Interface: XT / AT
Re: Chicony KB-5161
« Reply #7 on: Tue, 11 February 2014, 21:14:32 »
There was a thread a week ago with a 5161 that had orange Omron switches. Those are nice.
As has been said before, it could be any of different switches, but it will be clicky.
Offline RickyJ
Re: Chicony KB-5161
« Reply #8 on: Tue, 11 February 2014, 21:18:32 »
Mine had proper Alps complicated blue switches.  The controller overheated/shorted on me one day though, I've read of others with the same problem unfortunately, so it became a switch donor board.
Currently GMMK Pro: lubed 68g U4T, FR4 plate, extra gaskets, etc
Offline ianxblog
  • no
Re: Chicony KB-5161
« Reply #9 on: Tue, 11 February 2014, 21:39:20 »
And what about the switches itself? were they good? Is that problem GOING to happen or its just some failed units? Were the switchs too heavy? Did they offer a good typing experience?
In case you used blues, were they similar? Im seeking for clicky switches and this may be it, and I could get it cheap (You don't wanna know how expensive mechanical keyboards are in my country, besides im in high school and got no job).
Offline nuclearsandwich
Re: Chicony KB-5161
« Reply #10 on: Tue, 11 February 2014, 22:18:00 »
Alps blues are among the most coveted by Alps clicky fans. Check out this recent review.
Offline ianxblog
  • no
Re: Chicony KB-5161
« Reply #11 on: Tue, 11 February 2014, 22:40:46 »
How much is this keyboard worth?
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
Re: Chicony KB-5161
« Reply #12 on: Wed, 12 February 2014, 17:31:52 »
This is everything I know so far:
http://deskthority.net/wiki/Chicony_KB-5161
From that FCC ID, the switches I've seen so far: blue Alps, Cherry MX, white Alps, and Cherry MX clones
If the FCC ID ends in "5161A" it's the NKRO version, with the switches seen so far being: blue Alps, Omron B3G-S, and little Mitsumis
Your odds are reasonable that it's got good switches, but you could still end up with MX clones :)
It might even be a different switch.
Bore Awards
Offline ianxblog
  • no
Re: Chicony KB-5161
« Reply #13 on: Wed, 12 February 2014, 19:08:06 »
Unafortunately I think this is the 2KRO version. This means you basically can't game with it? I mean W+D+CTRL.
D:
  • RIP
    • Boring twaddle
Re: Chicony KB-5161
« Reply #14 on: Wed, 12 February 2014, 19:52:48 »
It depends how they've wired the matrix and how the controller is programmed. I wouldn't want to play FPS-type games on Alps though (even if I did play games : ) — they're more a typing switch.
Bore Awards
Offline ianxblog
  • no
Re: Chicony KB-5161
« Reply #15 on: Wed, 12 February 2014, 20:41:49 »
Yup, I always read bad stuff about clicky switches for FPS Gaming. Never tried, so I don't know. But 2KRO is obviously a problem for gaming. Any type of gaming, I would say (Apart from Minesweeper).
Re: Chicony KB-5161
« Reply #16 on: Thu, 13 February 2014, 01:44:29 »
That is because of hysteresis, which is a property that Cherry MX Blue has. Clicky Cherry MX clones will also have it.
Alps do not have hysteresis, however. I am not sure about Omron B3G-S.
Offline Azure Flash
Re: Chicony KB-5161
« Reply #17 on: Thu, 13 February 2014, 02:00:25 »
Your preferences for switches is a million times more important than whatever theories people have about some detail in the switch's design allegedly having an effect on some specific application. You can game with Buckling Springs or Blues just fine even if they have Hysteresis. You can type hundreds of pages with linear switches just fine and still love that switch, if you like linear switches.
Also, 70gf is only fatiguing if you have fingers that are genetically engineered to be as weak as possible. Think about it: your hand might weigh, what, half a pound? How could you have any difficulty at all pressing something with 70 gram-force of force? It might be shocking at first if you're used to feather-light 30gf switches, but you'll get used to it I'm sure. Just varying the angle of approach of your fingers will give you more than enough weight behind your fingers to compensate for a measly 40gf difference.
Offline ianxblog
  • no
Re: Chicony KB-5161
« Reply #18 on: Thu, 13 February 2014, 02:06:07 »
Absolutely loved your reply.
Offline tbc
Re: Chicony KB-5161
« Reply #19 on: Thu, 13 February 2014, 02:22:43 »
anyone can use any switch.  it's not if you CAN use it, it's about spending the most comfortable amount of effort.
if you're optimized for 30g, then adding 40g is a HUGE difference to your comfort level.
hand weight is only relevant if your palms are visibly moving up and down for every keystroke.  i personally have never seen anyone do this (either floating above the board in a very fixed spot) or more commonly on a wrist wrest or the desk.
Offline Azure Flash
Re: Chicony KB-5161
« Reply #20 on: Thu, 13 February 2014, 02:45:00 »
Th-that's what I do... I rest my arms at the elbows, the rest is floating. My thumbs slide in front of the spacebar for additional support and alignment. Not touch-typing means I'm pretty much capped at ~85 WPM, but that's enough for me.
Offline taylordcraig
Re: Chicony KB-5161
« Reply #21 on: Thu, 13 February 2014, 02:53:13 »
Wow I type almost exactly the same, with my elbows on my chair's arms. I'm teaching myself to touch type but for now I'm stuck at about 80WPM too.
Offline ianxblog
  • no
Re: Chicony KB-5161
« Reply #22 on: Fri, 14 February 2014, 05:08:34 »
Does anybody know if this keyboard is plate mounted?
Re: Chicony KB-5161
« Reply #23 on: Fri, 14 February 2014, 09:59:28 »
The Chicony keyboards are plate-mounted in all switch variants, yes.
Why do you ask?
If you want to swap switches, then you should know that Cherry MX, Omron, SMK and Alps have different pinouts and dimensions, and therefore different PCBs and plates that are incompatible with one-another.
The only exception is compatibility between Cherry MX and its clones.
Offline ianxblog
  • no
Re: Chicony KB-5161
« Reply #24 on: Fri, 14 February 2014, 13:06:18 »
I don't wanna swap switches.. just asking.
I suck at soldering
