Author Topic: Reducing roughness of PBT keycaps  (Read 6925 times)
Offline Fandom
« on: Wed, 12 February 2014, 18:40:23 »
Hey everyone,
I recently was introduced to the beauty of PBT keycaps and I am pleased by the quality, even though I have noticed a much higher surface roughness compared to the ABS one. Also, strangely, I have noticed that the left shift is particularly rough as a surface compared to the other keys. It really stands out.
My question is, has anyone figured out a method to smoothen out the PBT keycaps? (one could think of sandpaper for example)
Topre RealForce 88 UB. Previously: Filco Ninja Majestouch 2 (brown) + CM Storm Quickfire TK (brown)
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
Re: Reducing roughness of PBT keycaps
« Reply #1 on: Wed, 12 February 2014, 18:42:36 »
PBT texture depends on the manufacturer as well. What caps do you have specifically?
Also, no one I know of is smoothing out their caps in any way.
Offline smknjoe
« Reply #2 on: Wed, 12 February 2014, 18:44:16 »
I assume you are talking about the rougher texture on Topre PBTs? There are different PBT makers out there and the texture is not the same on all of them. IBM (early) PBT rougher than HHKB PBT rougher than etc....
Personally, I like it. It's like grip tape for your fingers.
SSKs for everyone!
Offline HPE1000
  • Keycap Paparazzo
« Reply #3 on: Wed, 12 February 2014, 18:47:03 »
I'm not a huge fan of them being rough, but it is certainly better than being really smooth, where they start getting dirty faster it seems.
Offline Fandom
« Reply #4 on: Wed, 12 February 2014, 21:47:52 »
Indeed I was referring to the pretty rough Topre keycaps. Is there any way around them?
« Reply #5 on: Wed, 12 February 2014, 23:20:22 »
You can probably polish the keycaps to shine them: they will be smooth then.
If you want them to be a little rough bot not smooth, getting them that way without recasting the keycap would be very difficult to get even.
Offline lolkey
« Reply #6 on: Wed, 12 February 2014, 23:58:53 »
Take some 50 grit sandpaper to it..
filco ninja mj2 tkl · mx brown · black case · blank black pbt
varmilo va87mr tkl · gateron red · black case · dye sub pbt ❤
vortex pok3r rgb · mx silent · white case · blank xda pbt
Offline HPE1000
  • Keycap Paparazzo
« Reply #7 on: Thu, 13 February 2014, 00:01:44 »
@_@ sounds like the proper grit to use
Online Findecanor
« Reply #8 on: Thu, 13 February 2014, 01:04:45 »
Hehe. No 50 grit sandpaper is even coarser than the Topre keycaps themselves. I would recommend 200 grit or so.
Too bad that you don't like the texture of the Topre keycaps. I really like those. I think that my Cherry PBT keys are too smooth.
Offline Fandom
« Reply #9 on: Thu, 13 February 2014, 12:10:04 »
My primary worry with sandpaper is that it might ruin the legends on the keycaps. Any other recommendations lads?
Offline Dreamre
    • kbdlife
« Reply #10 on: Thu, 13 February 2014, 13:49:24 »
You'll end up making it worse than any better IMO.
Online Findecanor
« Reply #11 on: Thu, 13 February 2014, 13:54:22 »
There is no way to modify the key surface without damaging the legends.
I have seen some early images of hobbyist-made Topre sliders that are Cherry MX-compatible. There are more  keycap options for them. I am not too interested in that myself, so I don't remember where I saw them though.
Offline tbc
« Reply #12 on: Thu, 13 February 2014, 23:39:50 »
hobbyist made or the Coolermaster novatouch ones?
Offline HPE1000
  • Keycap Paparazzo
« Reply #13 on: Thu, 13 February 2014, 23:56:15 »
There were ones that people made themselves a while before the CM board. I cannot remember what board they salvaged the hybrid plunger things from though.
Offline Linkbane
« Reply #14 on: Fri, 14 February 2014, 02:37:24 »
They all vary by brand in terms of roughness, and there's really not much you can do about it unless you don't care about the legends or it's blank. The medium-thick Keycool blank caps I have are rough-textured (I prefer it actually), while the thick PBT on my Ducky is as smooth as ABS.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Online Findecanor
« Reply #15 on: Fri, 14 February 2014, 10:04:54 »
smooth as ABS.
Signature Plastics' ABS keys are rough as Topre's. ;)
Offline Linkbane
« Reply #16 on: Fri, 14 February 2014, 10:15:39 »
smooth as ABS.
Well, what we usually associate with cheaper ABS like those on CM boards. And I actually really like the caps on my FC660C; are they similar to those on Realforces or HHKBs?
