Author Topic: Where to get a TKL Case From?  (Read 1802 times)
Offline clickclack123
« on: Wed, 12 February 2014, 22:42:49 »
Anyone got any ideas on where I can get a TKL case for a reasonable price from?
I'm planning to get a custom pcb/plate made to create something similar to Acidfire's 70% Layout, but I would like to get a case bottom to put it in, so I can measure where the screwholes are for the pcb.
CM sells QFR top panels, but not the bottom part.
I'm perfectly happy with plastic, I don't need a $200 aluminum case for a prototype.
54311-0
