Author Topic: Post Reporting Time  (Read 6238 times)
Post Reporting Time
« on: Thu, 13 February 2014, 06:36:16 »
What's with the 40 second time limit on post reporting?
I can report a lot of posts in 40 seconds.  ::)
I had to go check facebook and then come back and report, rinse and repeat.
Offline osi
Re: Post Reporting Time
« Reply #1 on: Thu, 13 February 2014, 07:32:06 »
Now they are preferring this brand?!
Offline esoomenona
  • Gnillort?
« Reply #2 on: Thu, 13 February 2014, 08:54:03 »
That's the problem.
« Reply #3 on: Thu, 13 February 2014, 08:54:35 »
« Reply #4 on: Thu, 13 February 2014, 08:56:39 »
You guys are such buzzkills
« Reply #5 on: Thu, 13 February 2014, 09:00:06 »
Also, crackpots
« Reply #6 on: Thu, 13 February 2014, 10:06:12 »
Also, crackpots
cracked pot reminded me of this
A water bearer in India had two large pots, each hung on one end of the pole he carried across the back of his neck. One of the pots had a crack in it, and while the other pot was perfect and always delivered a full portion of water at the end of the long walk from the stream, the cracked pot arrived only half full. This went on every day for two years, with the bearer delivering only one and a half pots of water to his master’s house.
Of course, the perfect pot was proud of its accomplishment and saw itself as perfectly suited for the purpose for which it was made. But the poor cracked pot was ashamed of its imperfection and miserable that it was able to accomplish only half of what it had been made to do. After two years of what it perceived as bitter failure, it spoke to the water bearer one day by the stream. “I am ashamed of myself and I want to apologize to you.”
“Why?” asked the bearer. “What are you ashamed of?”
“For the past two years, I have been able to deliver only half my load because this crack in my side causes water to leak out all the way back to your master’s house. Because of my flaws you have to work without getting the full value of your efforts,” the pot said.
The water bearer felt sorry for the old cracked pot, and out of compassion he said, “As we return to the master’s house, I want you to notice the beautiful flowers along the path.” Indeed, as they went up the hill, the old cracked pot took notice of the sun warming the wildflowers on the side of the path. The pot felt cheered.
But at the end of the trail, the pot still felt bad because it had leaked out half its load, and again it apologized for its failure. The bearer said to the pot, “Did you notice that there were flowers only on your side of your path, but not on the other pot’s side? That’s because I knew about your flaw and took advantage of it. I planted flower seeds on your side of the path, and every day while we walk back from the stream, you’ve watered them for me. For two years I have been able to pick these beautiful flowers to decorate my master’s table. If you were not just the way you are, he would not have such beauty to grace his house.
Moral: Each of us has his/her unique flaws—we are all cracked pots.
Offline esoomenona
  • Gnillort?
« Reply #7 on: Thu, 13 February 2014, 12:28:34 »
So this thread can be closed now, right? Do I just report it to get that ball rolling?
« Reply #8 on: Thu, 13 February 2014, 12:46:33 »
What's with you Texans wanting to close all the threads?
Besides I got no legitimate answer from anybody who matters (a mod or admin, jd doesn't count because he can't decide if he is a keeper or a mod) about why the post reporting is limited to once every 40 seconds, why not make it so we can only post every 60 seconds that way people have time to read a post and report it before another post gets posted.
« Reply #9 on: Thu, 13 February 2014, 12:58:57 »
This mod enough for ya? ;)
I don't really see any compelling reason for changing it, other than you personally just want to be able to report more frequently.
