Author Topic: Cheapest Mechanical Keyboard?  (Read 3845 times)
Offline WakeMeIPlan
  • Micro Baby, Micro.
    • United Kingdom Box plots
« on: Thu, 13 February 2014, 12:16:37 »
I have a friend who's on a budget and he wants one. Preferably cherry.
Re: Cheapest Mechanical Keyboard?
« Reply #1 on: Thu, 13 February 2014, 12:20:37 »
If layout doesn't matter and used keyboards are fine, there are TG3 keyboards that go for like $30-40 on eBay. I think Monoprice has a keyboard that I've seen at about $40 too.
Offline WakeMeIPlan
« Reply #3 on: Thu, 13 February 2014, 12:34:12 »
Sorry, layout matters. What's the cheapest full sized?
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #4 on: Thu, 13 February 2014, 12:35:01 »
Those TG3 are pretty sucky really. G80-8200LPBUS at least has NKRO so can be used for gaming and is much more standard. Or can spend more for other version with MUCH nicer doubleshot keycap.
« Last Edit: Thu, 13 February 2014, 12:37:22 by IvanIvanovich »
Offline Linkbane
« Reply #5 on: Thu, 13 February 2014, 13:44:56 »
Rosewill has some really cheap boards, and Newegg usually has some steep discounts. I've seen them for under $50, and it's got a standard layout.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline heedpantsnow
  • Old enough to know better
« Reply #6 on: Thu, 13 February 2014, 14:15:10 »
I've demoed a Rosewill board, and the quality wasn't bad.
I'm back.
Offline intelli78
« Reply #7 on: Thu, 13 February 2014, 14:21:37 »
The CM Storm QFR, of course, is commonly considered the best "bang for your buck." It's not dirt cheap (~$80), but if he can budget a little more, he'll probably be a lot happier.
Offline Linkbane
« Reply #8 on: Thu, 13 February 2014, 15:27:35 »
$80 is exorbitant for a QFR, it's mostly worth it when you buy for $50 or so on discount. Also he did ask for a full-size.
Offline 1pq
  • Hipster Doofus
« Reply #9 on: Thu, 13 February 2014, 16:58:58 »
listen to this guy
that 8200 with doubleshots is much better than anything else you'll get for $65. I believe it's PCB mounted as well so if you ever get into modding, it will make your life a lot easier.
main kbs:  87UB (55g)  Custom Filco TKL (62g clears)
WTS JD40, Custom Ergoclear Filco
WTB ROHS Red BBv2 (Topre), OG EK Tri-Color Skull (TOPRE)
Offline aref
« Reply #10 on: Thu, 13 February 2014, 18:38:06 »
+1 on the CMQFR. Last I looked, MX Blue switches are the lowest priced on this KB. Market demand/trend seems to affect price on Cooler Master's keyboards.
« Reply #11 on: Thu, 13 February 2014, 19:00:51 »
listen to this guy
I have bought several (4 or 5) of the 8200s with doubleshots, and I don't like them. The PCB flexes in the middle and is not well supported. The case is also pretty cheap. The switches, keycaps and cable are very well made; whereas the PCB, case and internal connectors are very cheap and poor.
That said, they can be had for cheap, and will get you NKRO. Used cherry browns are pretty decent switches to start with as well.
Offline MissMurd3r84
  • In IRC wondering why Kmiller8 is yelling.
« Reply #12 on: Thu, 13 February 2014, 19:57:49 »
Lol. They were over $100 here in Australia.
KBC Poker - Red switches. Noppoo Choc Mini - Black switches. Leopold FC700R (White) - Blue switches. Ducky YOTD - Brown switches. Razer BW - Blue switches and rusted.
Offline Linkbane
« Reply #13 on: Thu, 13 February 2014, 21:09:13 »
I feel for you Australians, but doesn't mechkb sell boards at decent prices there?
Offline Tony
« Reply #14 on: Thu, 13 February 2014, 21:56:42 »
I bought two Compaq MX 11800s for $20 each.
« Reply #15 on: Thu, 13 February 2014, 22:02:28 »
Their prices aren't too bad. :) No idea why Australia got stuck with such big QFR prices though, not that anywhere seems to still stock them.
Offline Hak Foo
  • Make America Clicky Again!
« Reply #16 on: Thu, 13 February 2014, 22:19:34 »
Gotta agree on the 8200... it's a big board, and it flexes pretty badly.  You also have a mildly nonstandard layout in the numpad area and the ISO Enter.
You might look at the DSI ASK-6600U; it's more conventional and pretty cheap, but has ALPS switches instead of Cherry.
Overton130, Box Pale Blues.
« Reply #17 on: Thu, 13 February 2014, 22:33:00 »
Not all have ISO enter. A small number of them have ANSI enter. They are harder to find though.
Offline thesentinel
« Reply #18 on: Thu, 13 February 2014, 22:33:33 »
I'm not sure if this is a good suggestion, but I've heard good things about the Poseidon keyboard. It costs 80 bucks and is a full sized board and I haven't heard one bad thing about it.
EDIT: Er, turns out it only comes in brown and red. Though unlike the competitor (CM Storm), it has less branding and a less hideous font. And backlight, which is either good or bad.
« Last Edit: Thu, 13 February 2014, 22:36:50 by thesentinel »
Keyboards are the only thing keeping me from consuming human flesh.
Offline Charizard^
« Reply #19 on: Thu, 13 February 2014, 22:39:22 »
Monoprice with Cherry MX Blues is sub $60. I have heard that they are OK. Its also fullsize.
