Author Topic: Looking for the perfect keyboard  (Read 4536 times)
Offline Mikecase00
    • http://www.mikecase.net
« on: Thu, 05 March 2009, 11:33:29 »
I'm looking to add another keyboard to my arsenal.  In particular I have the following requirements:
 - Mechanical/tactile/clicky key switches (buckling spring, blue cherry, or ALPS equivalent).
 - Solid construction (it doesn't have to be as beefy as my M's, but it can't feel cheap)
 - Dark color (black, dark grey, etc)
 - Standard 101/104 key layout
 - Wireless
As far as I can tell, no such keyboard exists.  One wonders why not.  Surely there's a market for something along the lines of a well made DasIII or IOne in a wireless design?  Is there already something like this out there that I just haven't seen yet?
IBM Model M 1391401 (dyed black) w/ keys from M-13
IBM M-13 Trackpoint (naturally black)
IBM Model M 1392934 SpaceSaver
Several plain IBM 1391401 Ms
Epson Equity Q203A
Offline itlnstln
« Reply #1 on: Thu, 05 March 2009, 11:37:35 »
I think there might be something in the Filco line that might interest you.  I can't remember off hand what form factors they come in.  There are blue Cherry and white Alps versions, but again, I am not sure what versions they come in.
Offline bhtooefr
    • bhtooefr.org
« Reply #2 on: Thu, 05 March 2009, 11:59:01 »
Are the Filcos plate or PCB mount? If they're PCB, then you could buy a FKBT104M/EB and an iOne Scorpius M10, and swap the springs and stems.
Offline itlnstln
« Reply #3 on: Thu, 05 March 2009, 12:00:56 »
They are PCB mounted.
Offline Chloe
  • Switch Kitten
Offline itlnstln
« Reply #5 on: Thu, 05 March 2009, 12:17:33 »
Here I am looking at my plate-mounted switches in my ABS ans typing PCB.  Fail.
Offline Chloe
  • Switch Kitten
« Reply #6 on: Thu, 05 March 2009, 12:24:21 »
Well, they are PCB mounted too... :) ALPS need the face plate, two pins are not stable enough.
Offline nerp
« Reply #7 on: Thu, 05 March 2009, 18:41:16 »
What about a Customizer 104? It pretty much meets all your categories. ** except wireless. :/
U N I.C O M P - Am I the only one that likes the logo?
Offline wheel83
« Reply #8 on: Thu, 05 March 2009, 19:04:25 »
a customizer with a 5m extension cable should do wonders haha
I <3 BS
Offline FKSSR
« Reply #9 on: Thu, 05 March 2009, 19:37:54 »
yeah, a unicomp with a wireless mod of some sort may be possible, but that may take some work...
Add me on Steam | Twitter
Offline wheel83
« Reply #10 on: Thu, 05 March 2009, 19:48:04 »
wireless adaptors are definitely possible with todays technology. im pretty sure ive seen such devices exist cheaply.
I <3 BS
Offline bhtooefr
    • bhtooefr.org
« Reply #11 on: Thu, 05 March 2009, 22:06:06 »
But WUSB adapters are quite large things that... let's just say they're the size of a wireless router, and have a power brick that big, too.
You're going to have to do a controller swap, and the only controller I could find that was readily available... can't really be reprogrammed without some specs that the manufacturer won't give to an individual.
Offline iMav
  • geekhack creator/founder
« Reply #12 on: Fri, 06 March 2009, 01:15:07 »
There exists a Filco 'board with bluetooth and blue Cherry keyswitches.  Since you don't want/need a tenkeyless, you should be good to go with Filco.
Offline bhtooefr
    • bhtooefr.org
« Reply #13 on: Fri, 06 March 2009, 07:08:29 »
What's the model number, though? I'm guessing it has "91" or "108" somewhere in it? :)
Offline chongyixiong
« Reply #14 on: Fri, 06 March 2009, 10:10:35 »
http://www.diatec.co.jp/en/det.php?prod_c=495
I believe this is EXACTLY what fits your bill.
They come in either soft tactile brown or linear black though.
Offline bhtooefr
    • bhtooefr.org
« Reply #15 on: Fri, 06 March 2009, 10:29:51 »
Right, I already mentioned that... but it doesn't have blues.
Offline Mikecase00
« Reply #16 on: Fri, 06 March 2009, 13:53:59 »
Quote from: chongyixiong;23720
That's close, but coming from a Model-M I'm not sure I can live with the loss of clicky feedback.  In an ideal world I'd buy a black, blue tooth enabled, IBM M-2 keyboard, but obviously no such keyboard exists.  I was wondering if there might be something wireless with clicky mechanical switches.  If the Filco had cherry blues I'd be in business...
Epson Equity Q203A
Offline Mikecase00
« Reply #17 on: Fri, 06 March 2009, 13:55:03 »
Quote from: nerp;23653
I already have several Model-Ms, a Customizer would be redundant.
Epson Equity Q203A
Offline bhtooefr
    • bhtooefr.org
« Reply #18 on: Fri, 06 March 2009, 13:58:24 »
Well, if you feel like doing a crap-ton of soldering, you could always put blues in it...
Offline FKSSR
« Reply #19 on: Fri, 06 March 2009, 14:37:21 »
sounds like a good mod project, whether you mod an IBM, Unicomp, or Filco. :D
EDIT: This is my 100th post! :P
