Author Topic: Cherry G80-3181HPU  (Read 4155 times)
Offline ebacho
Offline 1pq
  • Hipster Doofus
Re: Cherry G80-3181HPU
« Reply #1 on: Thu, 13 February 2014, 18:54:09 »
These are doubleshots, right? (I'm cherry model number semi-illiterate--does the H in the model number indicate doubleshots?)
main kbs:  87UB (55g)  Custom Filco TKL (62g clears)
WTS JD40, Custom Ergoclear Filco
WTB ROHS Red BBv2 (Topre), OG EK Tri-Color Skull (TOPRE)
« Reply #2 on: Thu, 13 February 2014, 19:15:48 »
Yes, it should have doubleshots.
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #3 on: Thu, 13 February 2014, 20:23:11 »
Offline 1pq
  • Hipster Doofus
« Reply #4 on: Thu, 13 February 2014, 20:37:00 »
Are these rare? Because $200 just for a slightly abnormal cherry board with doubleshots seems a bit expensive...
Offline Pacifist
  • on hiatus
« Reply #5 on: Thu, 13 February 2014, 20:53:50 »
http://www.ebay.com/itm/Cherry-G80-3181HPU-PS-2-Wired-Keyboard-Model-MX3160-New-open-box-/291078966898?pt=PCA_Mice_Trackballs&hash=item43c5a88e72
Not really a great find, but... it's certainly something.
Good find especially that huge ENTER key next to the numpad area  :thumb: .
Whoa didn't see that at first. Does anybody know what kind of stab that has?
« Reply #6 on: Thu, 13 February 2014, 22:03:47 »
I'm not sure, but I have a feeling it just has normal switches underneath. Some may be without springs though.
Offline smknjoe
« Reply #7 on: Thu, 13 February 2014, 22:09:16 »
Are you guys sure about the double shots? How can you tell? I had one almost identical to that with clears and lasered PBTs and got it for ~$35. Sold it for the same price too.
SSKs for everyone!
« Reply #8 on: Thu, 13 February 2014, 22:15:46 »
Areyou sure it wasnt a G80-8113? Those are very common.
You can tell pretty easily that it's not lasered PBT. I dont know of any cherry dyesub POS boards, so it's most likely doubleshot
Anotehr oddity: uses M8 (I think) for the click buttons. The pink stems are aftermarket, but here's a picture from kbdmania
http://www.kbdmania.net/xe/photo/7675244
Offline ebacho
« Reply #9 on: Thu, 13 February 2014, 23:29:47 »
I'm thinking of throwing the seller an offer.  Any ideas of how much it'd be worth?
Offline Pacifist
  • on hiatus
« Reply #10 on: Fri, 14 February 2014, 00:24:36 »
Start low go up
Offline ebacho
« Reply #11 on: Fri, 14 February 2014, 00:37:24 »
Start low go up
That's a given I think.
On taobao these go for around 530ish RMB for a used one, so I'll probably start there.
« Reply #12 on: Fri, 14 February 2014, 02:39:40 »
remember: you can only offer 3 times I think.
Offline Elrick
  • Hype Master
« Reply #13 on: Fri, 14 February 2014, 02:54:33 »
Yep, then you're stuck with paying the full price, that's if you really want it  8) .
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #14 on: Fri, 14 February 2014, 10:04:03 »
I had one of these once. That big 2x2 enter key have 1 switch in center and 1 stabilizer mounted vertically. The keycap itself does have mounts as well for a 4x switch POS style. On mine the new line and right shift were 2 switch caps.
Price is high... but it is new old stock, has fulltouch caps lock and 1.25 alts in black/beige, all double shot except the huge enter, new line and relegendables obviously. Also this model should have clear switch. It is partially programmable too, but it is a huge pita as the old cherryconf under DOS is required. It uses low profile M8 switch for the trackpad buttons which was another interesting thing. I think maybe something like $130-150 might be more reasonable.
« Last Edit: Fri, 14 February 2014, 10:05:46 by IvanIvanovich »
