Author Topic: IBM PC Industrial  (Read 7585 times)
Offline ed_avis
IBM PC Industrial
« on: Fri, 14 February 2014, 04:03:35 »
http://www.ebay.co.uk/itm/261395715066
An IBM Industrial keyboard for the IBM PC (or perhaps the PC-XT).
Offline berserkfan
Re: IBM PC Industrial
« Reply #1 on: Fri, 14 February 2014, 06:25:40 »
As pictures show, these are Oak switches, not capacitative buckling springs. There isn't much documentation for Oak, so god knows how the actual switch feel is like.
Offline ed_avis
« Reply #2 on: Fri, 14 February 2014, 06:37:48 »
Oh!  So it's not just your common or garden PC keyboard in a grey case.  Any idea why IBM chose to outsource this keyboard?
  • Live long and prosper
« Reply #3 on: Fri, 14 February 2014, 07:04:33 »
I didn't even know industrial Model Fs existed... let alone with switches other than buckling springs.
Someone should buy it and do a complete review on it...
tp thread is tp thread
« Reply #4 on: Fri, 14 February 2014, 07:31:02 »
Offline 127001
« Reply #5 on: Fri, 14 February 2014, 11:11:33 »
4 people, including myself, have had the option to buy it for ~$50.
Offline Sniping
« Reply #6 on: Fri, 14 February 2014, 15:40:35 »
There are some Industrial Model F's floating around on Ebay at the moment, but I believe that they all use the Oak switches. Pretty sure these are "quiet" switches and probably aren't as appealing as buckling spring.
but....case swap?
Offline intelli78
« Reply #7 on: Fri, 14 February 2014, 15:42:13 »
but....case swap?
Never heard of "Oak" switches before. Anyone used them? Anything worthwhile about them?
Offline Sniping
« Reply #8 on: Fri, 14 February 2014, 15:48:20 »
but....case swap?
I believe they're mechanical but not clicky. A quick google search shows me that there's linear Oak switches in a Sun Microsystems keyboard. I think this is the patent for the switch, seems like it's mechanical:
"A pushbutton switch has a base and a button telescopically movable on the base. There are a pair of terminals, with one of the terminals having a contact arm positioned within a switching chamber in the base. Movement of the button is effective to cause the contact arm to close upon the other terminal. The effective length of the contact arm is greater than its actual length. In one improvement, a light emitting device may be illuminated when the switch is operated. In another, a portion of the light emitting device forms the means to close the contact arm. "
« Reply #9 on: Fri, 14 February 2014, 15:51:06 »
Also, you can't swap XT Model F internals into that OAK switch Industrial XT, because the OAK case doesn't have the curved interior.
« Reply #10 on: Fri, 14 February 2014, 15:51:45 »
Oak FTM (full travel membrane) switches were most notably used in the sun Type 3, sun type2 (most likely) and the KB for the osborne portable
I noticed that but I'm still not sure it's impossible. It's just the front plate that's not curved on the oak case, so the XT will possibly fit, but just look ugly.
« Reply #11 on: Fri, 14 February 2014, 16:05:12 »
But I doubt the back of the case has those plastic supports to support the curved plate, either. Isn't that OAK PCB flat?
« Reply #12 on: Fri, 14 February 2014, 17:30:56 »
I'm going to keep an open mind until I see pictures of the inside of the case.
Offline berserkfan
« Reply #13 on: Fri, 14 February 2014, 19:37:49 »
yeah, somebody with lots of spare cash can buy it, tell us about it, do a community pass around if possible.
Offline ebacho
Offline E TwentyNine
    • Some of My Keyboards
« Reply #15 on: Fri, 14 February 2014, 21:52:42 »
I had mentioned this in one of the other threads - look at the bottom,  the indented ridge on the standard XT is in a different place than on this and may interfere with the keyboard assembly.
Offline berserkfan
« Reply #16 on: Fri, 14 February 2014, 22:23:54 »
Offline EverythingIBM
« Reply #17 on: Sat, 15 February 2014, 19:47:33 »
These things have always been floating around.
The XT layout isn't really optimal for a lot of people, and would personally drive me nuts.
« Reply #18 on: Fri, 21 February 2014, 07:49:52 »
another one, with internal pictures
http://www.ebay.com/itm/261404179268
looking at them, I don't think XT guts will fit.
Offline berserkfan
« Reply #19 on: Fri, 21 February 2014, 08:08:58 »
there is no limit to the number of optimistic sellers.
$189 for this ancient scrap that most folks won't pay $40 for?
Let's hear from the guys who actually bought: are OAK switches that good?
« Reply #20 on: Fri, 21 February 2014, 08:11:07 »
Did anyone ever get one of these?
 I'd be interested to hear from them as well.
« Reply #21 on: Fri, 21 February 2014, 08:57:19 »
Nobody's buying these for the quality of the keyswitch.
I think this guy might have picked up one of the ones that sold for around $50 and is trying to turn it around quick for a profit.
Offline berserkfan
« Reply #22 on: Fri, 21 February 2014, 09:44:32 »
oh well, the foolishness of ghers has no limit. any rare switch, they'll buy at high prices
Offline bitslasher
« Reply #23 on: Thu, 13 March 2014, 02:45:33 »
I picked up one of these from someone who sold one on eBay, but actually had one more hiding in her garage!  She sold it to me for $35 + $14.95 shipping.  The board build quality is great.  But it is not structurally compatible with the Model F.  It is flat all around, as others have noticed.  It's a super neat board as a collector item though.  The switches are linear and smooth.
Offline ed_avis
« Reply #24 on: Thu, 13 March 2014, 06:26:27 »
So, bitslasher, why did IBM choose to supply this keyboard with the Industrial models instead of giving them a regular Model F?  What's better about it?  Or was it some bizarre cost saving measure?
« Reply #25 on: Thu, 13 March 2014, 19:17:49 »
I think the FTM would seal better against dust and suchlike than a model F. Hard to say, though.
Offline ed_avis
« Reply #26 on: Fri, 14 March 2014, 15:24:13 »
I guess you're right - in my experience I have found the AT Model F, at least, to be sensitive to dust getting into the well where the spring is.
