Author Topic: [help pls] Busted a switch in my keyboard..  (Read 4707 times)
Offline antCB
« on: Sat, 15 February 2014, 22:53:24 »
Hello guys and girls(not really),  I'm new here in the forums, and although I knew about this I never thought I would register :P I do like mechanical keyboards, but since it is expensive stuff, specially for a student, I only own one and an entry model at that :)
Last night while taking the keycaps of my Steelseries 6GV2 for cleaning, I busted up one of the switches.. that happened because the little "hammer" (the plastic thing with a + "sign" that holds the keycap) was "glued" together with the keycap and I couldn't put it back together :(
Is all my hope gone, or is the fix a simple matter of ordering a new switch, take the old one out and soldering the new one onto the board ?
It is the "regular" Cherry MX black Steelseries 6GV2
Steelseries 6GV2 ISO-PT with Gateron Blues.
Offline Pacifist
  • on hiatus
Re: [help pls] Busted a switch in my keyboard..
« Reply #1 on: Sat, 15 February 2014, 22:58:33 »
Desolder resolder is your best option
Offline luis911
« Reply #2 on: Sat, 15 February 2014, 23:00:24 »
Can you take a pic so that we can see the damage?
Check out my website FDMPrints.org
Offline antCB
« Reply #3 on: Sat, 15 February 2014, 23:21:22 »
Here it is pic.
I really think my only bet is to desolder resolder :(
What's the best place to order from ? Mind you I'm from Portugal, so I'd like to avoid ordering from the US, China, etc. I'd like to keep it within Europe (so I don't waste too much money in this) :P
thanks in advance
Offline luis911
« Reply #4 on: Sat, 15 February 2014, 23:25:19 »
Here it is pic.
thanks in advance
You can probably buy the stem, top cover, and spring, and replace those parts without removing the switch. I can't tell if the bottom cover is broken or not.
Offline Pacifist
  • on hiatus
« Reply #5 on: Sat, 15 February 2014, 23:28:23 »
Can you stuff the top cover into housing that has a plate like that?
Best option is just to desolder and resolder. Go to the free stuff thread in classifieds and I'm sure someone in EU would give you a black for free
Offline Zeal
    • Zeal Generation Inc.
« Reply #6 on: Sat, 15 February 2014, 23:32:41 »
I'm surprised that you were able to break the switch cover from pulling the keycap.  :eek: If you're confident with desoldering/soldering, your best option would be to desolder that switch and replace it with a new black switch.
Offline antCB
« Reply #7 on: Sun, 16 February 2014, 00:03:54 »
nope, I tried using a tweezers to open up the housing and I busted up the top part of the housing (it has some sort of swivel mechanism) :\ meh. should've not messed around with it... worst part is that the shift key got "stuck".. if it didn't I wouldn't try to "fix" it..
Offline 1pq
  • Hipster Doofus
« Reply #8 on: Sun, 16 February 2014, 00:21:32 »
Here it is pic.
thanks in advance
I'm not sure if he'd be able to get the cover on again, though, since it's a plate mounted board...
main kbs:  87UB (55g)  Custom Filco TKL (62g clears)
WTS JD40, Custom Ergoclear Filco
WTB ROHS Red BBv2 (Topre), OG EK Tri-Color Skull (TOPRE)
Offline luis911
Offline Pacifist
  • on hiatus
« Reply #10 on: Sun, 16 February 2014, 00:30:50 »
Offline luis911
« Reply #11 on: Sun, 16 February 2014, 00:33:32 »
http://www.ebay.co.uk/itm/CHERRY-MX-Series-Keyswitches-Black-Keyboards-Switches-ORIGINAL-/120951918447?pt=LH_DefaultDomain_0&hash=item1c294bcf6f
Alright here you go. Thank me later.
That's extremely overpriced. A black switch is worth 30 cents max since its so common
Link? he's in europe too so any US shops might not be convenient for him.
Offline Pacifist
  • on hiatus
« Reply #12 on: Sun, 16 February 2014, 01:02:31 »
Don't have a specific link, but here in classifieds people sell them dirt cheap when they scavenge old Cherry boards for switches.
Offline margo baggins
  • Dungeon Dweller
  • Get back to work!
« Reply #13 on: Sun, 16 February 2014, 01:48:36 »
Where in the EU are you?
Are you in the UK? I can either send you a black switch, or you can send me the board and I will fix it free you just pay postage.
I got boards.
Offline antCB
« Reply #14 on: Sun, 16 February 2014, 02:01:58 »
I'm from Portugal, i'd love to replace this switch asap :)
What do I need to PM you with? Do you need me to pay the postage expense from uk to portugal ?
thanks
  • Dungeon Dweller
  • Get back to work!
« Reply #15 on: Sun, 16 February 2014, 02:06:45 »
PM me your address
I got boards.
Offline antCB
« Reply #16 on: Sun, 16 February 2014, 02:25:44 »
done, thank you margo!
Offline antCB
« Reply #17 on: Fri, 21 February 2014, 10:33:16 »
[BUMP] Problem solved! [/BUMP]
 pic of soldering work :)
Thank you enosdan for the goods you provided me.
Margo, thanks for coming forward to help, but enosdan covered that ! :)
Offline berserkfan
« Reply #18 on: Sat, 22 February 2014, 00:10:10 »
well done! we are a very friendly community!
Offline exitfire401
  • The Force is Re/\l
« Reply #19 on: Sat, 22 February 2014, 01:28:13 »
Good to see you got the necessary help so quickly!
Offline antCB
« Reply #20 on: Sat, 22 February 2014, 01:34:48 »
this is one community i'll keep tabs on :) there's so much things I pay attention too that don't deserve 1/10 of my attention... might be getting a GH board near summer time :) (for the northern hemisphere :P)
Offline CatNip :3
  • bouncy bouncy
« Reply #21 on: Sun, 23 February 2014, 02:09:48 »
It's great your keyboard is repaired. :D
