Author Topic: Buyer Alert: IBM Model M Gray Industrials & M13 Trackpoints  (Read 5659 times)
Offline ozar
« on: Fri, 06 March 2009, 22:36:01 »
I wasn't sure where to put this thread so perhaps iMav can put it in the correct location if there's a better forum for it.  Thanks!
Just a heads up... if any of you have been wanting either or both of the above-mentioned boards, I just got word that a dozen of each is about to go on the block at eBay.  The seller said he hopes to get them all listed this weekend, so you might want to watch for them.
Edit: I should add that the grays are from the '80's and the trackpoints are black according to the seller.
Offline bhtooefr
    • bhtooefr.org
« Reply #1 on: Fri, 06 March 2009, 22:54:01 »
ebay finds would be the best forum...
Offline ozar
« Reply #2 on: Fri, 06 March 2009, 23:02:11 »
Thanks... I considered putting it there but since they aren't listed yet, I wasn't sure.
Hopefully, iMav will see it and move it to the appropriate forum.
Offline ozar
« Reply #3 on: Sat, 07 March 2009, 12:01:44 »
Yep, that's the seller that says he has a dozen of them, so there should be more coming soon.
Looks like he's gone up a bit in price since the $50 ones a few weeks back.
Offline ozar
« Reply #4 on: Sat, 07 March 2009, 12:57:38 »
He's put up a few more from '88 now, and they look good in the photos.  I probably won't buy because I have one on hand already:
http://search.ebay.com/140306129136
http://search.ebay.com/130292178391
http://search.ebay.com/140306137822
Not sure when the M13's will start appearing.
Offline Mercen_505
« Reply #5 on: Sat, 07 March 2009, 18:17:49 »
I wouldn't mind getting another m13 just to have some replacement keycaps. They don't appear as utterly indestructible as the original Ms are.
Offline Mercen_505
« Reply #6 on: Mon, 09 March 2009, 07:39:34 »
That's not a bad idea... thanks!
Offline ozar
« Reply #7 on: Mon, 09 March 2009, 11:05:40 »
If anyone is still wanting an Industrial Model M, a nice looking '87 Industrial just got listed:
http://search.ebay.com/130292617750
It's the same seller, and these aren't lasting long once he lists them.  All those listed over the weekend are gone already.
Offline elmwood
« Reply #8 on: Tue, 10 March 2009, 00:02:15 »
Aside from the color, is there anything special about the industrial Ms?
Offline wumpyr
« Reply #9 on: Tue, 10 March 2009, 05:37:38 »
Quote from: elmwood;23993
No, just harder to come by.
IBM Model M13 Raven Black \'96, \'97 (2), \'98 (2)
IBM Model M13 Industrial Gray \'96 (2)
IBM Model M Industrial Gray \'88, \'94
IBM Model M White Label 1391401 \'92
IBM Model M International \'95 (2), \'96
IBM Model M 52G9658 \'93
IBM Model M 1370475 Mini \'93
