Author Topic: What seperates high end Rubber Dome from regular ones?  (Read 3666 times)
Offline Kamen Rider Blade
« on: Sun, 16 February 2014, 02:30:30 »
I'm not talking about Topre switches, but just classic Rubber Domes.
Most traditional Rubber Domes are limited to ~ 1-5 million clicks of durability if they're even listed at all
Yet higher end Rubber Domes can have durability up to 15 million clicks which is getting into the realm of Mechanical keyboards.
From my research, switching the Rubber Dome material to Silicone helps with the durability factor.
What other changes from traditional Rubber Dome KB construction is necessary to bring the KB up to the 15 million clicks level or better?
Maybe using a PCB instead of a flexible plastic circuit sheet?
Any ideas from the knowledge folks here?
Re: What seperates high end Rubber Dome from regular ones?
« Reply #1 on: Sun, 16 February 2014, 03:11:07 »
Rubber domes don't click. The word "click" refers to a click sound. A "clicky" keyboard switch emits a click sound, and so far all clicky keyboard switches have been mechanical. A click sound could also be emitted by electronics through a solenoid or a speaker, but then it wouldn't be a property of the keyboard switch.
The term you are looking for is "key press". You could also use the word "actuation" which implies that the key press has succeeded in being recognized electrically.
What other changes from traditional Rubber Dome KB construction is necessary to bring the KB up to the 15 million [key presses] level or better?
Model M buckling springs have membranes as the actuation mechanism and often work fine for a very long time. I believe it is mostly when keyboards have been subjected to spills (coffee, tea, soda...) that membranes erode and break or short.
Topre and Model F buckling springs use capacitative sensing, which is contact-less and should last mechanically for longer but they are still sensitive to erosion and shorts.
Many types of keyboard switches will also worsen in feel a lot before they break. Topre rubber domes get stiffer. Regular rubber domes not only get stiffer but also a mushier landing.
Key Tronic used to have rubber dome/membrane keyboards called "Lifetime Series" because they had been engineered to last - but there was really nothing spectacular about them.
« Last Edit: Sun, 16 February 2014, 03:23:02 by Findecanor »
Offline ComradeSniper
  • HHKB Pro
« Reply #2 on: Sun, 16 February 2014, 03:14:39 »
I have typed on a few rubber domes which had PCB mounted domes and steel backplates along with sliders. Can't remember the exact brand. The keys themselves still felt like crappy old rubber domes, but the board in general did have a much more solid and satisfying feel than a cheap all plastic & membrane rubber dome board.
Offline damorgue
    • Personal portfolio
« Reply #3 on: Sun, 16 February 2014, 03:18:42 »
I think high end could refer to a number of things. High end as in great tactility and quality feel as well as durability and longevity. You seem to be considering the latter, where for instance very sealed constructions won't let contaminants in between the contact points as easily. Polymers which age better and are more resilient will of course also increase the longevity. The dome can be designed to not have some weak at the points where it bends the most etc. The contact points could develop an oxide layer as well so a nice and thick plating which doesn't wear off could alleviate that somewhat.
There are some examples at least.
« Reply #4 on: Sun, 16 February 2014, 16:35:24 »
So what causes Rubber Domes to require more force / pressure over time until they finally stop working?
Offline tbc
« Reply #5 on: Sun, 16 February 2014, 17:33:27 »
isn't that a natural property of rubber?  that's what i was always tols.  rubber just gets hard when constantly put under pressure
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #6 on: Sun, 16 February 2014, 20:24:31 »
<iframe width="560" height="315" src="//www.youtube.com/embed/jKC-RwNfXPI" frameborder="0" allowfullscreen></iframe>
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
