Author Topic: Ergo partner for poker  (Read 2161 times)
Offline ianxblog
  • no
« on: Sun, 16 February 2014, 15:34:12 »
I found this on sale for pretty cheap (around $8)
I found it ideal to set it like this:
POKER - MOUSE/PAD - THIS THING
Its an NUMPAD+NAV.
It's a Qtronix QX-032.
Apparently it has Aristotle Cherry Mx clones.
 :thumb:
Offline 1pq
  • Hipster Doofus
Re: Ergo partner for poker
« Reply #1 on: Sun, 16 February 2014, 21:38:04 »
Where would you use this? To the right of the mouse? I don't see the benefit of this over a fullsize if you were going to put it directly to the right of the poker :p
main kbs:  87UB (55g)  Custom Filco TKL (62g clears)
WTS JD40, Custom Ergoclear Filco
WTB ROHS Red BBv2 (Topre), OG EK Tri-Color Skull (TOPRE)
Offline Candyflip
« Reply #2 on: Sun, 16 February 2014, 21:41:40 »
This would fit better on the left of the board but maybe thats just me... Anyway never seen something like this, are there any only arrow cluster pads out there? That would be ideal :p
Offline ianxblog
  • no
« Reply #3 on: Sun, 16 February 2014, 21:42:26 »
To the right of the mouse, exactly..  :thumb:
Offline Pacifist
  • on hiatus
« Reply #4 on: Sun, 16 February 2014, 21:45:51 »
Offline tricheboars
  • Keyboards are Important!
« Reply #5 on: Mon, 17 February 2014, 00:17:43 »
Pacifist do you have an arrow cluster programmed into that pad?
Offline 1pq
  • Hipster Doofus
« Reply #6 on: Mon, 17 February 2014, 21:21:38 »
That's quite a long trip to the arrow keys, though...
