Author Topic: Clipped leads??  (Read 6104 times)
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
Clipped leads??
« on: Sun, 16 February 2014, 15:52:02 »
So when you guys are soldering up a board what do you do with the clipped leads from LEDs and diodes?
Do you save them for trace repair or just throw away?
Re: Clipped leads??
« Reply #1 on: Sun, 16 February 2014, 16:06:28 »
I've seen people post that they use them when direct wiring.
Offline Wildcard
  • When caffeine isn't enough
Re: Clipped leads??
« Reply #2 on: Sun, 16 February 2014, 16:14:26 »
That's what I've always done. I usually keep the longer pieces and trash anything less then 1cm
Offline bpiphany
Re: Clipped leads??
« Reply #3 on: Tue, 11 March 2014, 04:40:05 »
I have a bag of leads, but after a while you just have enough for a lifetime, so nowadays I just throw them away =)
Offline Neebio
  • Dance Master
Re: Clipped leads??
« Reply #4 on: Tue, 11 March 2014, 18:13:28 »
Ideally you would collect any garbage metal you don't want and every once and awhile make a trip to a metal recycling centre.
Remember the three R's man! Think of the penguins!
RK9000RE w/ Raindrop & DDR arrow keys
Cherry G80-11900LUMEU-2 w/ Red/Black SA keys
Re: Clipped leads??
« Reply #5 on: Wed, 12 March 2014, 22:05:00 »
I plan to solder mine together and add it to my huge blob of lead solder (I melt down and then refine the impurities out of solder that I vacuum out of keyboards and anything I desolder.)
Offline PointyFox
Re: Clipped leads??
« Reply #6 on: Wed, 12 March 2014, 22:19:33 »
 :confused:
Offline ebacho
Re: Clipped leads??
« Reply #7 on: Thu, 13 March 2014, 00:47:09 »
 :confused:
 :confused: indeed...
