Author Topic: Post your hand wired matrix  (Read 5424 times)
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« on: Sun, 16 February 2014, 15:53:14 »
Alright guys.  Lets see some pics of your hand wired matrices.  I will post mine here in the next week when I get it done.  I got 2 rows left then the columns.
Re: Post your hand wired matrix
« Reply #1 on: Sun, 16 February 2014, 16:03:24 »
soon its time i use some of these goods i've purchased over the last 6 months or so
Offline Melvang
« Reply #2 on: Sun, 16 February 2014, 16:14:48 »
Less talkie more workie.  Lol let's see some progress spamray
« Reply #3 on: Sun, 16 February 2014, 16:29:03 »
Hey I'm proud of myself I desoldered my first keyboard today and started soldering back up and was going to test it and realized I left my usb cable for it at work :|
Offline Melvang
« Reply #4 on: Sun, 16 February 2014, 16:36:27 »
And you don't have a spare?
« Reply #5 on: Sun, 16 February 2014, 16:37:54 »
not a spare male to male :/ stupid connector choice
perhaps i should just hack together a couple of the other usb cables i have
Offline hydrospell
  • some keyboard thing
    • octobrain
« Reply #6 on: Sat, 01 March 2014, 03:16:20 »
dat nekkid matrix
⌨ Filco MJ2 MX Blues / M0116 Orange Alps / Homemade 60% MX Reds / M0110
Cherry MX art prints 20/50 still available!
« Reply #7 on: Sat, 01 March 2014, 03:28:29 »
Matrix, you say?  How's this?
It's still a WIP, so bear with me, but I'm so close to being done!  Just need to throw in a teensy, program it, and bend myself a 7x costar wire.  Can't be too hard, can it?  :P
Offline hydrospell
    • octobrain
« Reply #8 on: Sat, 01 March 2014, 04:05:02 »
Jinx it yourself eh
Very neat work, I'm super impressed. Share your methodology?
And how do you insulate your rows from your columns? To my eye they look like naked copper wires running across?
« Reply #9 on: Sat, 01 March 2014, 04:36:02 »
Jinx it yourself eh
The rows and columns are separated simply by distance.  There's about 2-3mm of space between each crossing wire.  You are correct that everything is bare wire.  As long as nothing shifts or gets squished together I'm hoping that my method will work out.
If you're interested I'd be happy to post some pictures showing the separation from a lower angle than the pictures I've provided above.  :)
Offline hydrospell
    • octobrain
« Reply #10 on: Sat, 01 March 2014, 04:45:49 »
No mystery then :D
How did you get your diodes and copper so neat!?  :eek:
Offline False_Dmitry_II
« Reply #11 on: Sat, 08 March 2014, 01:42:56 »
Looks alot like lowpoly's m0110. While it's a very elegant method, I don't like trusting things to work as planned. I'm about to start on a M0116 to turn it into a gaming-able thing. Good thing that was the plan when I got it, because I tested it with the imate to make sure it worked and the matrix as-is is completely worthless.
