Author Topic: what SP color code best matches a mx brown stem?  (Read 2075 times)
Offline tbc
« on: Mon, 17 February 2014, 23:29:25 »
like the title says? what color code is it?
this is totally not a serious thing, i just have a CM switch tester and i want to get keycaps on top that match the switch they're covering.
thanks for the help.
http://keycapsdirect.com/pbtcolors.php
http://keycapsdirect.com/abscolors.php
EDIT:
added abs colors cause i posted wrong link at first -_-
« Last Edit: Mon, 17 February 2014, 23:59:05 by tbc »
Offline Zeal
    • Zeal Generation Inc.
Re: what SP color code best matches a mx brown stem?
« Reply #1 on: Mon, 17 February 2014, 23:55:37 »
I only see one PBT brown colour from SP. Would you be fine with ABS colours?
Here's a quick phone pic for now. Left my camera at my office...
Left is with light shining on it. Right is without a direct light.
IRL, I would say it's closer to the bottom PBT "TGJ" colour.
Brown's a hard image to take a pic of. Depending on lighting, the colour can change from this:
to this:
« Last Edit: Tue, 18 February 2014, 00:08:38 by Zeal »
Offline tbc
« Reply #2 on: Tue, 18 February 2014, 00:58:01 »
haha, thnaks alot zeal.  major CSI zoom and enahnce work there.
your suggestion looks pretty spot on.  I wonder if a SP GB runner wants to chip in though.
