Author Topic: Cherry profile keycaps on a filco mj2  (Read 4361 times)
Offline Girtarded
« on: Tue, 18 February 2014, 23:54:43 »
I know that cherry profile keys are shorter than the standard keys on an mj2, but I was wondering if I bought a full set of, say, IMSTO thick pbt cherry profile caps they would fit correctly on an mj2.
Offline IPT
  • Formerly projectD
Re: Cherry profile keycaps on a filco mj2
« Reply #1 on: Wed, 19 February 2014, 00:11:59 »
yup no prob
Offline Girtarded
« Reply #2 on: Wed, 19 February 2014, 00:15:30 »
Thanks :D
Offline Candyflip
« Reply #3 on: Wed, 19 February 2014, 00:56:35 »
Of course they would even nicer than stock ones!
Offline fknraiden
« Reply #4 on: Sun, 23 February 2014, 09:00:35 »
I just put cherry on my MJ earlier this week. much nicer.
« Reply #5 on: Sun, 23 February 2014, 10:56:00 »
I use GMK on my filco, and SP on my other one.
Works fine.
Offline daetsid
« Reply #6 on: Tue, 25 February 2014, 09:42:03 »
With Cherry caps profile, a QFR or a MJ looks 10x better :>
Offline haroro92
« Reply #7 on: Tue, 25 February 2014, 16:51:15 »
Actually I had a problem with the Imsto Thick PBT cap on my Filco. My big keys ended up being extremely mushy and didn't press all the way down. Does anyone know how to fix this?
« Reply #8 on: Tue, 25 February 2014, 17:00:21 »
You're stabilizers (the little white things) probably aren't in all the way.
Offline IPT
  • Formerly projectD
« Reply #9 on: Tue, 25 February 2014, 17:00:31 »
u using orings or any pads?
i had them on my MJ2 MX Blue with no issues
Offline haroro92
« Reply #10 on: Wed, 26 February 2014, 13:50:56 »
The stabilizers are in all the way and I have no O rings. I looked this up and people had similar problems where the bigger keys will grind or something of that nature. They said it's because the IMSTO keys are cherry profile and thick. Some people recommended shaving some parts off so I don't exactly know what to do. At this point, I'm using my Filco spacebar with the rest of the keys IMSTO until I solve this problem.
Offline IPT
  • Formerly projectD
« Reply #11 on: Wed, 26 February 2014, 14:01:56 »
odd, never had this happen to me when I was using imsto's thick PBT cherry replica.
Offline haroro92
« Reply #12 on: Wed, 26 February 2014, 15:44:10 »
Hey actually I fixed the issue. So basically, you can get unlucky with bigger warped pbt keycaps which actually changes the feel and the interaction with the stabilizers alot. My spacebar, shift key and enter key were all warped so I used the hair dryer to straighten them out just a tad. It didn't fully solve the problem for the enter key, but solved the spacebar and shift key.
