Author Topic: Lexmark Model M with bigass enter?  (Read 8237 times)
Offline Techno Trousers
  • ʘ_ಠ
« on: Wed, 19 February 2014, 21:31:09 »
Here's an odd one. Supposed to be model 1397771. Anybody ever see one of these before? I was skeptical that it's a buckling spring board, but it looks like one of the caps is missing, showing the underlying stem. Did anyone but IBM use those types of two piece key caps? I wish there was a picture of the underside.
http://pages.ebay.com/link/?nav=item.view&id=321328445533
Re: Lexmark Model M with bigass enter?
« Reply #1 on: Wed, 19 February 2014, 22:52:23 »
I haven't. It would need a differently programmed controller for the pipe key to work, I think.
Or he just put keycaps from an AT model F on it.
Interesting.
Offline PRISONER 24601
« Reply #2 on: Wed, 19 February 2014, 23:36:38 »
what is this demonry?
even the ps/2 cable screams IBM
but it also looks like a Key Tronic, going by that oem rectangle in the corner.
Ever tried. Ever failed. No matter. Try Again. Fail again. Fail better.
G80-3000LSCRC-2 (MX), "Ricercar" G86-6241OEUAGSA (MX), MX11800 (MX), AEKII (ALPS), AEK (ALPS) Apple Keyboard A9M0330 (ALPS), IBM Model F XT (Bucking Spring), IBM Space Saver 1391472 (Bucking Spring).
Offline ed_avis
« Reply #3 on: Thu, 20 February 2014, 02:47:28 »
Is this what they call a US International keyboard?  Or is that with the tall, backwards-R-shaped Enter key?  Anyway this layout looks close to the older Model F, which I like.
« Reply #4 on: Thu, 20 February 2014, 06:46:51 »
That looks like an AT plug to me, but I have never seen an IBM AT cable that was not black.
It would be easy to mod the keys that way if you were doing a bolt mod, but I am surprised that it came from the factory like that.
- D Trump 2026-10-24
Offline E TwentyNine
    • Some of My Keyboards
« Reply #5 on: Thu, 20 February 2014, 19:58:24 »
I'm not the buyer, but I asked the seller to send me a pic of the label:
Which is a DELL Model M.
Here's a similar one with a detachable cable:
And an old listing with more pictures: http://www.ebay.com/itm/251430823194
And a web page with one from the same year with a hardwired cable (which this one I believe is): http://www2s.biglobe.ne.jp/~duelist/1369050/index.htm
Note however these all have the standard enter.
The 1397771 Model number seems legit, but I cannot find any other photos of it.
Offline Pacifist
  • on hiatus
« Reply #6 on: Thu, 20 February 2014, 19:59:29 »
Did somebody say Dell?
I MUST GET MY HANDS ON ONE
« Reply #7 on: Thu, 20 February 2014, 20:28:42 »
Aren't we way off-topic here?
Yes, Dell offered a re-branded buckling spring board for a while.
None of these other comments address the bigass Enter and beige AT plug.
Offline JimByr
  • ...old guy...
« Reply #8 on: Thu, 20 February 2014, 20:42:28 »
Why do you think that the 1397771 is a Dell? It's is not one of the three Dell Model M variants that I know of.
I actually bought the Dell 1397651 pictured above for considerably less than the price shown in the listing.
 The hardwired Dell linked above is a 1369050.
The parts sites have the 1397771 listed as: "101-Key; Attached Cable w/ AT Style Plug (Lexmark)"
« Last Edit: Thu, 20 February 2014, 21:03:32 by JimByr »
« Reply #9 on: Thu, 20 February 2014, 21:14:27 »
I think it's a Dell due to the logo cutout on the top case.  The only IBM keyboard with that kind of logo might have been those Aptiva keyboards (think that was it), and they didn't have AT connectors.
But yes, that is a secondary question...
« Reply #10 on: Thu, 20 February 2014, 21:45:45 »
Don't Ambra model M's have the cutout?
Even the AT&T model M's don't have an enter key like that. It's only the Wheelwriters and AT's that do, as far as I know.
« Reply #11 on: Thu, 20 February 2014, 21:50:26 »
Ambra!  That was the name I was looking for!  But Ambras have a trapezoid logo.   The old Dell logo seems to have the same rounded rectangle as this one.
I'm not 100% on it being a Dell, just seems to fit.
I did some searching on wheelwriters too, to see if maybe they offered something like this, no luck....
  • ʘ_ಠ
« Reply #12 on: Thu, 20 February 2014, 23:24:13 »
Thanks for getting the picture of the back, E TwentyNine. So it seems legit, and is probably much rarer than any other Model M variant. It should make a nice collector's item for someone.
« Reply #13 on: Fri, 21 February 2014, 01:08:02 »
I have a few (4 at least) wheelwriter keyboards, and I did some poking around on them a while ago. From what I was able to determine, they didn't make anything like this for the wheelwriters, actionwriters, or any typewriter.
The big thing to note is if the key next to backspace sends a proper scancode or not. It "could" in theory just be an M with some aftermarket replacement keycaps.
Offline REVENGE
« Reply #14 on: Fri, 21 February 2014, 05:09:16 »
Offline HAL9000
« Reply #15 on: Fri, 21 February 2014, 05:21:35 »
Thats what I thought when I bought it. Thanks for the find Techno Trousers
Code: [Select]
/*pz*/char p[]=" ELPRTWZ";unsigned z[]={553179788,1641},
_=14;main(){while(_--)putchar(p[z[_/012]>>3*(_%10)&7]);}
« Reply #16 on: Fri, 21 February 2014, 06:18:28 »
On a standard M the extra location under the backspace sends 0x7D scan code.  Which is not the same code as the backslash key (0x2B).
It could be the controller is different or maybe there's a defined keyboard that will take that as backslash (just like AZERTY/QWERTY use the same codes for different letters).
« Reply #17 on: Fri, 21 February 2014, 06:19:13 »
You do realize we're going to expect an analysis of this thing once you get it?  :)
Offline HAL9000
« Reply #18 on: Fri, 21 February 2014, 07:12:53 »
Yes. I will provide some info once I get the keyboard.
Code: [Select]
  • ʘ_ಠ
« Reply #19 on: Fri, 21 February 2014, 22:31:19 »
Great, I'm looking forward to it.
Offline JimByr
  • ...old guy...
« Reply #20 on: Sat, 22 February 2014, 18:31:01 »
Note that the Model M boards (1399261) made by Lexmark for CompuAdd had the rectangular logo recess and a fixed cable with a DIN-5 connector... and the ones that I've found were made in 1994.
« Last Edit: Sat, 22 February 2014, 18:33:41 by JimByr »
« Reply #21 on: Sat, 22 February 2014, 18:40:04 »
Also important to note is CompuAdd had the big enter key on their RT101, which is the model-M looking keyboard made by NMB (not buckling spring).
Offline HAL9000
« Reply #22 on: Wed, 05 March 2014, 07:00:58 »
Yesterday I got the Model M 1397771 that I recently acquired from the post office. Upon initial inspection I am quite sure that the fat-ass ENTER-key is genuine and the keyboard has not been tampered with:
 - the keyboard sandwich has not been opened i.e.: not bolt modded, all (most of them anyway) rivets are intact
 - the barrel where the \ and | key on the US-ANSI layout would be has no spring
 - the barrel where the # key on the German-ISO layout would be has no spring
The fat-ass ENTER-key looks like a combination of ANSI and ISO Model M ENTER-key
« Last Edit: Wed, 05 March 2014, 07:02:31 by HAL9000 »
Code: [Select]
« Reply #23 on: Wed, 05 March 2014, 08:11:18 »
Awesome.  If you peek down the empty barrels - are there pivot plates there (without the spring) or just an empty spot?
Any labelling inside?  I think the CompuAdd idea may be the right one...
« Reply #24 on: Wed, 05 March 2014, 08:21:35 »
Do all the keys register properly?   Can we get some pictures of the internals include the controller board?
« Reply #25 on: Wed, 05 March 2014, 08:27:12 »
Unless this is wildly out of character, they will be empty.
IBM made all the components (all the ones that I have seen, anyway) the same, so that alternate layouts were achieved by merely populating different barrels with springs and hammers. I would even be surprised if controllers were different, an empty barrel would simply never send a signal. But I may be wrong, that is empirical observation, not electronic knowledge.
« Reply #26 on: Wed, 05 March 2014, 08:40:01 »
This whole keyboard is wildly out of character, that's why I asked.
As noted previously the scancode sent for the hidden barrel under the standard backspace which is replaced here with a small backslash key is not the same as the one sent for the standard backslash key, so the keyboard would need to do something different or be set up differently in the OS (like AZERTY/QWERTY).
Offline JimByr
  • ...old guy...
« Reply #27 on: Wed, 05 March 2014, 09:47:36 »
btw... The seller has come across a trove of CompuAdd boards. She sold the 1397771. Then two CompuAdd 1399261 Model Ms and now she has a CompuAdd NMB for sale.
« Last Edit: Wed, 05 March 2014, 21:12:15 by JimByr »
« Reply #28 on: Thu, 06 March 2014, 08:20:06 »
link to the seller's store:
http://www.ebay.com/sch/molly867928-2009/m.html?_nkw=&_armrs=1&_ipg=&_from=
I'm eyeing that trackball, but it's looking more "consumer" than "industrial" to me.
  • ʘ_ಠ
« Reply #29 on: Thu, 06 March 2014, 18:37:17 »
Does putting "RARE!!" At the front of all your descriptions do anything besides look very annoying?
I do like how some are VERY RARE!! though. I'll take one of those and leave the mere RARE!! items to the unsophisticated mass market buyers.
