Author Topic: TRiK PCB F/W, P/G Update(21.2.14)  (Read 4100 times)
Offline LifeZ
  • LifeZone
« on: Thu, 20 February 2014, 18:26:13 »
Key chattering  minimize and input speed control.
We wanted it.
55007-0
55009-1
* TRiKer R1.2.1.zip (700.66 kB - downloaded 278 times.)
LZ Limited
Offline Photoelectric
Re: TRiK PCB F/W, P/G Update(21.2.14)
« Reply #1 on: Thu, 20 February 2014, 18:27:19 »
!!!!!  Thank you!
Offline laden3
« Reply #2 on: Thu, 20 February 2014, 19:24:07 »
For those who are using windows 8.1 and having problems updating the F/W, try windows 7 compatibility mode.
Can we add the function to use macro keys without key combinations?
55014-0
I rrrove brrracks.
Offline LifeZ
  • LifeZone
« Reply #3 on: Thu, 20 February 2014, 19:34:32 »
triker is not support win8.
sry.....
LZ Limited
Offline laden3
« Reply #4 on: Thu, 20 February 2014, 19:38:02 »
Still works after I updated it under windows 7 compatibility mode.
Adding macro keys into the standard keymap will make the pcb more powerful  :p
I rrrove brrracks.
Offline ebacho
« Reply #5 on: Thu, 20 February 2014, 19:39:37 »
I'm assuming this is only for TKL LZ boards?
Offline rebluer
« Reply #6 on: Sat, 22 February 2014, 01:11:34 »
Update & Finished!!
Thank you, LZ~ :thumb: :thumb: :thumb: :thumb:
 ;D ;D ;D ;D
Offline exitfire401
  • The Force is Re/\l
« Reply #7 on: Tue, 25 February 2014, 10:22:26 »
Thanks guys!
« Reply #8 on: Tue, 25 March 2014, 18:55:02 »
Mmmm, minty fresh new firmware :)  Using it now.  I was having the chattering issue, hopefully this puts it to rest.
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #9 on: Sat, 12 April 2014, 09:05:33 »
Can we get a DSA Dolch update?
Offline tricheboars
  • Keyboards are Important!
« Reply #10 on: Sat, 12 April 2014, 19:22:55 »
Someone from REDLINE needs to step up and answer to the Dolch DSA Group Buy.  Anyone interested in this keyboard should be weary of this vendor.  Until someone responds to the Dolch Group Buy I strongly recommend staying away from any REDLINE buy.  They may have scammed thousands out of this community.  Beware.
REDLINE respond to the situation on the Dolch Group Buy thread.  Thanks
