Author Topic: Zeal’s Cables - [closed]  (Read 3383347 times)
Offline Zeal
  • * Moderator
    • Zeal Generation Inc.
Re: Zeal’s Cables - [Green Tea Kit Kat with every order?!]
« Reply #850 on: Tue, 11 November 2014, 12:58:27 »
6ft Coiled Kelly Green Paracord Micro USB Cable w/ Gold Plated Ends. ~4" uncoiled on both sides
10ft Coiled Neon Green Paracord Mini USB Cable w/ Gold Plated Ends & Gray HS. ~1ft Coil @ Mini B
6ft Coiled Black/Copper Paracord Mini USB Cable w/ Gold Plated Ends & Black HS
8ft Coiled Black Paracord Mini USB Cable w/ Gold Plated Ends & Black HS
10ft GID Blue Reflective Paracord Mini USB Cable
P.S. All cable orders now come with a Green Tea Matcha Kit Kat. :))
« Last Edit: Tue, 11 November 2014, 23:09:31 by Zeal »
Offline billiob
« Reply #851 on: Tue, 11 November 2014, 13:09:05 »
Damn, I need to get a new cable :)
Offline Zeal
  • * Moderator
« Reply #852 on: Tue, 11 November 2014, 13:12:00 »
Offline FrostyToast
  • Litshoard
« Reply #853 on: Tue, 11 November 2014, 13:18:51 »
P.S. All Green Tea Matcha Kit Kat orders now come with a cable :))
Sweet
« Last Edit: Tue, 11 November 2014, 13:21:33 by FrostyToast »
Quote from: elton5354
Offline Zeal
  • * Moderator
« Reply #854 on: Tue, 11 November 2014, 13:22:35 »
Sweet
Oh you... :rolleyes:
Offline Noko
  • jolonarr: a tough dude who takes no esses!
    • Noko's Leatherworks
« Reply #855 on: Wed, 17 December 2014, 15:12:45 »
Zeal when did you start selling switches?!? A Canadian supplier for switches, this is awesome :D
Noko's Leatherworks - Handmade Custom Leather Wrist Rests -  http://www.noko.ca
Sales Thread: http://geekhack.org/index.php?topic=51762.0
Build Log: http://geekhack.org/index.php?topic=47704.0
Offline Zeal
  • * Moderator
« Reply #856 on: Wed, 17 December 2014, 17:43:16 »
Around October! :D
Will be stocking Cherry PCB stabs with a finishing touch on top very soon as well.
Haven't updated my thread with pics of cables in a while, will have to get to that sometime this week. :)
Offline cseng
« Reply #857 on: Thu, 25 December 2014, 09:57:24 »
 i'm interested in the GID Blue but can't really decide between the reflective and non-reflective ones. could you show me some pictures of both GID Blues and also the GID Pink?
« Last Edit: Thu, 25 December 2014, 11:40:18 by cseng »
Offline Sniping
« Reply #858 on: Sat, 27 December 2014, 01:42:05 »
I'm thinking that I need a GID cable right about now too lol....I think it would go well on my lightsaver.
Offline Big Mac 1998
« Reply #859 on: Sat, 27 December 2014, 01:42:49 »
Damn i need one of these for my poker
Offline Zeal
  • * Moderator
« Reply #860 on: Thu, 01 January 2015, 15:46:16 »
Here's a pic of the three sleeves. :) Sorry for the late reply, was on a short trip during the winter holidays.
Can't really capture the GID look, but pink almost turns white, and the blues have a greenish glow.
Offline jjt
« Reply #861 on: Tue, 06 January 2015, 02:16:16 »
If I want to get an Ergodox TRRS right angle cable, is the length done from the posts, or from where the cable meets the connectors? The cables look great, I just want to make sure that I get the correct length for my setup.
Offline Zeal
  • * Moderator
« Reply #862 on: Tue, 06 January 2015, 14:53:48 »
Length you request is the length I cut the cable at. It's usually around the same, or ~inch or so longer after soldering.
Offline cseng
« Reply #863 on: Fri, 09 January 2015, 07:04:40 »
UV Pink on Rose Pink double sleeved. Good or bad idea?  :-\
Offline Zeal
  • * Moderator
« Reply #864 on: Sat, 10 January 2015, 22:55:41 »
Enhances the UV pink sleeve.  :)
Offline runcom
  • Topre lover
Special order cable:
Random colour of my choice.  :eek:
How to order exactly the green one with SDL to USB A (plus the converter I suppose)?? Is it also possible to add a coil?
« Last Edit: Fri, 16 January 2015, 13:02:24 by runcom »
Don't be a dumbass, always be kind to people, here and afk
Offline FrostyToast
  • Litshoard
Just tell Zeal that is the exact cable style you want and then specify a length for the cable (both the length of the coil and the length of the straight area)
The only issue with this is that you will have to purchase the SDL cable yourself and have it sent to him as Zeal doesn't have them.
Another issue is that Zeal has no way of testing the cable to see if it works.
EDIT: I assume that this won't be done through his site and rather via PM. That is how I did my order... in fact, all of my orders...
Offline taylordcraig
« Reply #867 on: Sat, 24 January 2015, 15:09:56 »
someone lend seal an ssk to test sdl cables
Offline Zeal
  • * Moderator
« Reply #868 on: Sat, 24 January 2015, 15:11:17 »
Already discussed about the SDL cable with runcom and it's on its way to me. :P
Offline whentheclouds
« Reply #869 on: Sat, 24 January 2015, 15:23:11 »
grats on vendor status, your store just needs to stock on lube and maybe a couple more LED colors now (btw you still haven't fixed those LEDs photos!) and it'll be the most complete NA store around. i'll definitely be in touch with you in the future about my Octagon and many potential orders. keep up the good work!
Offline Zeal
  • * Moderator
« Reply #870 on: Sat, 24 January 2015, 15:55:22 »
Lube is already in the works. :)
Yes, I'll have to get on the LED pics! Got some new camera gear :D
« Reply #871 on: Fri, 13 February 2015, 11:15:47 »
heya. do you happen to have any color that closely resembles the Octagon's blue grey?
Offline Zeal
  • * Moderator
« Reply #872 on: Fri, 13 February 2015, 12:28:38 »
Since I'll have a blue gray on hand (along with yours), I'll see if I can get a colour match in person once I receive the Octagons. :)
« Reply #873 on: Fri, 13 February 2015, 12:35:02 »
niiice. i'll be waiting for that, along your batch of Gateron clears to arrive before placing a mega bux order  :thumb: since i wouldn't be in Canada for a little while longer, i'm debating whether to commission you to assemble it for me, or just doing it myself since all the hard parts are already done (and i really want to acquire some real soldering experience despite not even having a kit atm lol). gonna give this more consideration and i'll let you know once i place my order :)
Offline awhitedev
« Reply #874 on: Sun, 15 February 2015, 09:42:37 »
Hey Zeal! Not sure why I didn't see your thread on cables before. Absolutely beautiful work!
Just placed an order for a couple of cables for my keyboards :) Let me know if my comments didn't make any sense  :))
« Last Edit: Wed, 18 February 2015, 07:00:41 by awhitedev »
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #875 on: Sun, 01 March 2015, 03:55:52 »
Hi Zeal, I'm a big fan of your website, and I've been eyeing your cables for a long time now. Do you have an orange that matches the Skidata Orange?
#hype #hype #hype
Offline naasfu
  • The Curator
  • CURSE YOU HE-MAN
« Reply #876 on: Fri, 10 April 2015, 23:53:59 »
acid purple and GID pink, both with clear outer sleeving.  i love these cables.  thanks, zeal!
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #877 on: Mon, 13 April 2015, 13:43:59 »
Wow, those cables match really, really well! Nice job Zeal.
Offline cseng
« Reply #878 on: Thu, 16 April 2015, 04:09:41 »
not sure if i'm doing this right. i want a coiled paracord, single sleeved and the maximum coil length is 1ft. so i put coil length on 1ft and 7th on "Length of Cable?"
Offline Zeal
  • * Moderator
« Reply #879 on: Thu, 16 April 2015, 05:14:21 »
Sort of. The first dropdown will determine how long your cable will be cut to. So if you ordered 7ft, and requested 1 ft of coil, the whole cable will only be 1ft in length, with a full coil. If you would like some remainder straight cable at one end, then be sure to add some extra length on the first drop down menu "Length of Cable?".
Offline cseng
« Reply #880 on: Tue, 21 April 2015, 07:45:09 »
alright thanks! are you planning to restock the paracord blues anytime soon? i'm looking for 8ft+ cables.
Offline Zeal
  • * Moderator
« Reply #881 on: Tue, 21 April 2015, 10:55:52 »
What particular shades of blue are you interested in? Some have been discontinued from my supplier, so I may or may not be able to get more for now.
Offline cseng
« Reply #882 on: Tue, 21 April 2015, 11:27:44 »
Baby Blue and Colonial Blue.
Offline Zeal
  • * Moderator
« Reply #883 on: Tue, 21 April 2015, 20:35:26 »
Those two happen to be out of stock for now. :( I'll see if my supplier has any update with an ETA.
Offline cseng
« Reply #884 on: Wed, 22 April 2015, 07:48:07 »
alright thanks!
Offline Bucky
« Reply #885 on: Mon, 04 May 2015, 15:52:57 »
Any chance you will stock Techflex? Some great looking cables!
Offline Zeal
  • * Moderator
« Reply #886 on: Mon, 04 May 2015, 17:20:12 »
Many of Techflex's line of PET sleeves are quite loosely woven. I prefer to offer customers with sleeves with denser weaves, so no, I most likely will not be stocking their line of sleeves.
Offline MoarCoffeePlzzz
  • Formerly Deeptek
« Reply #887 on: Tue, 26 May 2015, 12:58:33 »
Seems your website product page is having some errors? Please let me know when the website is fixed so I can order my cable. Thanks
Offline trizkut
« Reply #888 on: Tue, 26 May 2015, 13:05:14 »
Custom cables are temporarily closed as I'll be heading out on a business trip + attending Computex 2015 (definitely will go to Ducky & Topre booth!) from May 27 - June 14.
https://geekhack.org/index.php?topic=72167.0
Offline Zeal
  • * Moderator
« Reply #889 on: Tue, 26 May 2015, 13:06:14 »
Hi Ryan,
I've temporarily closed the cable order form as I'll be leaving for a business trip this week, and won't be back til mid June. Order form will be back up once I return. :)
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #890 on: Wed, 27 May 2015, 09:28:49 »
Hi Ryan,
By then I may be hitting you up for another cable lol
Offline asgeirtj
« Reply #891 on: Mon, 07 September 2015, 11:57:29 »
My autism is strong today.  I'm considering buying a white paracord coiled cable from Zeal to go with my future silver Mira with Ivan's 4th round pbt black legend biege.  I've decided everything but this minor detail: whether to have 1" or 2" at the start of the cable uncoiled.  Here are pics which show this:
1
2"
Which should I choose?  Can't decide which would look better  :confused: (Autism intensifies)
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
Offline jennb
« Reply #892 on: Wed, 16 September 2015, 18:18:19 »
Got my GID Pink + Clear. Brilliant sleeving work. I love it and will be back to buy more.
Thank you!
Keyboards: Code MX Clear, Minivan Aliaz switches
Keycap sets: DSA Granite, SA Ice Cep
Offline demopolisa
« Reply #893 on: Mon, 21 September 2015, 12:29:18 »
Hey Zeal,
Some of your earlier pics showed right angled connectors. Do you still do them?
If you do I'm definitely gonna pick a few up  ;D
Offline Zeal
  • * Moderator
« Reply #894 on: Mon, 21 September 2015, 13:47:46 »
Hey Zeal,
No, right angled connector housings have been discontinued a while ago due to durability concerns.
Offline Redeemd
« Reply #895 on: Fri, 16 October 2015, 02:57:21 »
Hi Zeal, first off i have to say i am very impressed with your cables.
I want to see what a 6ft champagne gold and clear with black hs and maybe gold plated ends would cost for a usb a to usb b. thanks!
Offline Zeal
  • * Moderator
« Reply #896 on: Fri, 16 October 2015, 13:28:19 »
Hi Redeemd,
Champagne gold/clear plastic sleeve has been sold out and is no longer offered. :( My cable listing is also temporarily closed as I focus on shipping a bunch of Zealio switches out to the GB participants.
