Author Topic: Zeal’s Cables - [closed]  (Read 3374544 times)
Offline Zeal
  • * Moderator
    • Zeal Generation Inc.
Re: Zeal’s Cables - [#LEGITBALLIN' ErgoDox cables now available!]
« Reply #600 on: Mon, 16 June 2014, 16:20:40 »
Sooo if I wanted to be stupid crazy...
Could I get a blue LED aqua blue wire weaved in with 2 UV pink wires with white insulation?
Do you mean Blue LED + aqua blue base + UV pink sleeve on top with white heatshrink? (Heatshrink style requires gold plated ends)
I have made double sleeved LED cables, and can, if you'd like, but the lighting would be dimmer under normal use.
Offline FrostyToast
  • Litshoard
« Reply #601 on: Mon, 16 June 2014, 16:30:44 »
When I said "weaved in with 2 other wires", I was referring to something like this crazy looking thing thatyoumightneverevereverdoagain.
(Although the difference is that my order doesn't have 4x 16AWG wires.)
Also by "white insulation" I was referring to having the braid over a white cable.
Quote from: elton5354
Offline Zeal
  • * Moderator
« Reply #602 on: Mon, 16 June 2014, 17:17:26 »
So you mean something like this:
2x Blue LED cables with aqua blue sleeve
2x Blue LED cables with UV pink sleeve
1x white paracord/plastic sleeved usb cable
Braid LED cables around white cable, with UV pink/blue alternating?
Hack a way to power 4 LED cables simultaneously?
 :cool:
That'll be an expensive cable...  ;)
Offline FrostyToast
  • Litshoard
« Reply #603 on: Mon, 16 June 2014, 17:26:08 »
 :cool:
1x Blue LED cable with aqua blue sleeve
2x Cables with UV pink sleeve using white cable
So this will use 3 cables altogether instead of the four
(gold bling and white heatshrink as well)
That's what I was going for, hope it cleared thing up a bit.
Also, that's slightly more affordable.
Offline Zeal
  • * Moderator
« Reply #604 on: Mon, 16 June 2014, 17:30:53 »
 :cool:
Ah, I see. So the UV pink cables are just cosmetic.
Yes, I should be able to do that. :) Please PM me for custom pricing. Thanks :thumb:
Offline Zeal
  • * Moderator
« Reply #605 on: Mon, 16 June 2014, 23:55:16 »
FrostyToast's Order:
Once again, Zeal seems to be the go-to-guy for crazy custom cable ideas.  :))
~3ft braided"Miami LED Cable" - Aqua Blue on Blue LED cable + UV Pink w/ super taught, white, 16awg wire w/ gold plated ends & white HS.  ;)
Dat glow/reflection
*This will also be another one of a kind cable that I probably won't do again.  :p
« Last Edit: Tue, 24 June 2014, 18:06:56 by Zeal »
Offline taylordcraig
« Reply #606 on: Tue, 17 June 2014, 00:09:00 »
Zeal your cables always look so neat and tidy. The heat shrink is always so tight. Keep up the good work.  :thumb:
Offline CK Briefs
  • formerly calvins1
« Reply #607 on: Tue, 17 June 2014, 00:12:36 »
Obligatory BC bump.
Oh and prepare for a large order from me soon, Zeal (:
Current Keyboards: Orion - 62g ergo clears;
A87 PS2AVR - 59g ergo clears; QFR - stock blues
Offline Zeal
  • * Moderator
« Reply #608 on: Tue, 17 June 2014, 01:12:27 »
Thanks for your kind words, Taylor!  :)
Obligatory BC bump.
My body is ready.   :cool:
Offline tbc
« Reply #609 on: Tue, 17 June 2014, 01:53:20 »
Dat glow/reflection
exclusivity....gone
nooesssssss
Offline CK Briefs
  • formerly calvins1
« Reply #610 on: Tue, 17 June 2014, 02:23:24 »
Dat glow/reflection
exclusivity....gone
nooesssssss
Why would you want an exclusive bulge
Pls.
Offline Zeal
  • * Moderator
« Reply #611 on: Tue, 17 June 2014, 03:00:34 »
[snip]
[snip]
Dat glow/reflection
[snip]
exclusivity....gone
nooesssssss
Pls.
tbc collects all sorts of bulges...  :rolleyes:
« Last Edit: Tue, 17 June 2014, 03:15:32 by Zeal »
Offline Zeal
  • * Moderator
« Reply #612 on: Wed, 18 June 2014, 19:32:20 »
Vroom~
Do you guys like speed?  ;)
How about the ONLY custom sleeved USB cable available at this time, that's made with Hi-Speed certified cable?! Base price starts at $30, and is only available in Plastic Sleeves. I'll be experimenting with heatshrink style in the coming days. I'll also try to update my site with these cables by tomorrow.
Definitely not your average Joe keyboard cable. Ideal for transferring multiple/large files at a time from one device to another. (Or you just like the look & feel of thick USB cables to pair up with your Korean custom :) )
6ft UV Green/Black Mini USB Cable w/ Gold Plated ends - $35
*Green is a bit darker IRL. It likes to absorb light due to being a bit translucent, so the picture makes it appear "lighter".
Please note: Your devices must be able to transfer files at high speed specifications in order for this cable to meet its full potential.
« Last Edit: Tue, 24 June 2014, 18:06:01 by Zeal »
Offline FrostyToast
  • Litshoard
« Reply #613 on: Wed, 18 June 2014, 19:37:22 »
Vroom~
I wonder if anyone will order a Hi-speed super bulge...
I'm not too interested, so if anyone wants to take this idea that Zeal might only do once, have at it!  :p
Offline Zeal
  • * Moderator
« Reply #614 on: Wed, 18 June 2014, 19:42:26 »
Vroom~
tbc's hi-speed?(the wires meet hi-speed spec...heh) bulge was probably the last time I'd ever do that.
I can't have all these bulgy cables in my portfolio, Frosty.  :p
Offline FrostyToast
  • Litshoard
« Reply #615 on: Wed, 18 June 2014, 19:51:49 »
Yeah... It might be inconvenient if people kept giving you awkward "bulges".  :))
I know how you feel.  :p
Offline Zeal
  • * Moderator
« Reply #616 on: Thu, 19 June 2014, 03:23:19 »
Zeal be #LEGITBULGING at 1am...
BrokenGame's Order:
6ft Braided Black/White Paracord Mini USB cable w/ Gold Plated Ends & White HS
6ft White Paracord Mini USB cable w/ Gold Plated Ends & White HS
6ft Black Paracord Micro USB cable w/ Gold Plated Ends & Black HS
6ft Black Paracord USB B cable w/ Gold Plated Ends & Black HS
Z16B's Cable  :thumb:
6ft Black Mini USB Cable w/ Gold Plated Ends & angled Mini B
« Last Edit: Thu, 19 June 2014, 12:51:07 by Zeal »
Offline intelli78
« Reply #617 on: Thu, 19 June 2014, 09:25:53 »
Offline Zeal
  • * Moderator
« Reply #618 on: Thu, 19 June 2014, 11:18:47 »
u wot m8
Problem, son?  ;)
Honestly, where are all these bulge requests coming from? :p
I do have to admit though, the Black/White braided cable above looks sooo good.
Offline FrostyToast
  • Litshoard
« Reply #619 on: Thu, 19 June 2014, 23:06:18 »
I think tbc started a trend....
Offline FrostyToast
  • Litshoard
« Reply #620 on: Thu, 19 June 2014, 23:12:52 »
If you ever make Model M cables, then can I claim the 6 wire bulge?
EDIT: Even if you won't make it right now, I will pay you to have that cable reserved.  :p
Offline Zeal
  • * Moderator
« Reply #621 on: Fri, 20 June 2014, 00:11:33 »
I'd have to learn how to Braid 6 cables... :p
I have made Orihalcon cables before, as a special request.
Offline tbc
« Reply #622 on: Fri, 20 June 2014, 00:30:12 »
actually most awesome connector ever
Offline FrostyToast
  • Litshoard
« Reply #623 on: Fri, 20 June 2014, 08:26:23 »
I still feel like a 6 way braid would be too rigid with plastic. Will you ever be stocking cloth/fabric sleeving?
Offline Zeal
  • * Moderator
« Reply #624 on: Fri, 20 June 2014, 11:41:02 »
I have been providing paracord sleeve for a while now.   :-X link to paracord colours is currently below plastic colour options. The above black/white braid & cables were made with paracord sleeve.
*needstogatherallmysleevesinonepicture*
Offline tbc
« Reply #625 on: Fri, 20 June 2014, 20:48:18 »
also another trend i started ;)
Offline FrostyToast
  • Litshoard
« Reply #626 on: Fri, 20 June 2014, 22:50:05 »
I will now announce that I have ordered yet another bulge not one week after my previous bulge order.
I won't reveal any details and will instead wait for you guys to see the picture because this is probably the stupidest bulge order Zeal has received.
The only hint I will give you guys is that I had to order an SDL to USB cable.
Offline Zeal
  • * Moderator
« Reply #627 on: Fri, 20 June 2014, 22:52:38 »
I'm hating myself already.
Offline CK Briefs
  • formerly calvins1
« Reply #628 on: Fri, 20 June 2014, 22:54:43 »
Woo I love to see zeal in pain
KEEP THE BULGES COMING
Offline FrostyToast
  • Litshoard
« Reply #629 on: Fri, 20 June 2014, 22:58:19 »
I think me and tbc are now on his "most hated customers" list.  :p
Offline Zeal
  • * Moderator
« Reply #630 on: Tue, 24 June 2014, 22:04:49 »
Good day everyone!
Zeal PC is having a sale from today til July 4th, 23:59:59 PST!
Use Coupon Code: 4THOFJULY to receive 10% off all orders at checkout! http://zealpc.net
Please note: July 1st is a holiday in Canada, so orders do not get picked up until next day. July 4th is a holiday in USA, so orders placed on July 3rd/4th will be delivered on July 7th.
Cheers,
Henry
« Last Edit: Wed, 25 June 2014, 04:37:15 by Zeal »
Offline Zeal
  • * Moderator
Re: Zeal’s Cables - [10% OFF ALL ORDERS FROM NOW TIL JULY 4TH]
« Reply #631 on: Thu, 26 June 2014, 13:34:39 »
Cables that were ordered yesterday and completed yesterday (and also mailed same day :eek:):  ;)
6ft Coiled (1ft total coil) Imperial Red Paracord Mini USB w/ Gold Plated ends & Gray HS
10ft Imperial Red Paracord Micro USB w/ Gold Plated Ends
10ft White w/ Single strand of Clear on White Paracord Micro USB w/ Gold Plated ends
6ft Acid Purple Paracord Mini USB Cable w/ Gold Plated Ends & Purple HS
4ft Black/Copper Paracord Micro USB w/ Gold Plated ends
3ft Black/Copper Paracord Mini USB w/ Angled end
Offline CK Briefs
  • formerly calvins1
« Reply #632 on: Thu, 26 June 2014, 13:36:44 »
Cables that were ordered yesterday and completed yesterday (and also mailed same day :o ):  ;)
Wow that imperial red coiled might just be my new favourite :S
Offline Zeal
  • * Moderator
« Reply #633 on: Thu, 26 June 2014, 14:12:48 »
It's also another interesting Paracord colour that changes depending on ambient light. :)
Offline MythicalWagyu
  • Poor Impulse Control
« Reply #634 on: Fri, 27 June 2014, 10:56:25 »
Yeah sure is a good looking color - can't wait to see it in person!  :)
KEYBOARDS >>
MICE >>
COMPUTER >>
Offline Zeal
  • * Moderator
« Reply #635 on: Fri, 27 June 2014, 12:48:17 »
It's on the delivery truck!  :p
Great way to start the weekend too, not having to wait days, or even weeks for a purchase.  ;)
« Reply #636 on: Fri, 27 June 2014, 13:20:39 »
Yes, worth the cost, especially for custom items that are not easily replaceable! I am not always a patient man (I can be with groupbuys because I know what i'm getting into) which is why I have Amazon Prime - I like it when stuff shows up a few days after I order it! UPS seems really hit & miss depending on which driver you get... thus far I've only had good experiences with DHL  :thumb:
I'll be sure to give you a plug & post a photo once they arrive :)
KEYBOARDS >>
MICE >>
COMPUTER >>
Offline Zeal
  • * Moderator
« Reply #637 on: Fri, 27 June 2014, 13:36:54 »
Thanks bro!  :thumb:
Amazon Canada really sucks. It's a completely empty market, and things are overpriced if they are even available on Amazon.ca
DHL's pretty good with delivery times imo. They don't spread their delivery options into 2 or 3 day "economy" shipments like UPS/FedEx -- just time definite options for next business day :)
Offline luisbg
« Reply #638 on: Fri, 27 June 2014, 13:37:19 »
I know! Must. not. spend. money.
Leopold FC660M - Brown mx switches - black case - white blank keys :: ErgoDox - Blue mx switches - classic case - black blank keys
Offline Zeal
  • * Moderator
« Reply #639 on: Fri, 27 June 2014, 13:51:03 »
Help a Canadian bro out? Invoice will be sent in CAD as well! :)
If you're not in BC, how about I sweeten the deal by upgrading your Expedited Parcel to Xpresspost?  ;)
Offline luisbg
« Reply #640 on: Fri, 27 June 2014, 14:12:34 »
Canadian bro! What would be the price then? I am in Montreal, Quebec. Still works for you?
Offline Zeal
  • * Moderator
« Reply #641 on: Fri, 27 June 2014, 14:29:19 »
It's $13 CAD for expedited parcel to QC, and usually takes 4-5 business days. I'll cover the difference and upgrade the shipping to Xpresspost for 2 business days!  :)
Offline CK Briefs
  • formerly calvins1
« Reply #642 on: Fri, 27 June 2014, 14:31:12 »
What a bro.
Offline luisbg
« Reply #643 on: Fri, 27 June 2014, 15:47:04 »
You are the best!  :thumb:
Offline Zeal
  • * Moderator
« Reply #644 on: Fri, 27 June 2014, 19:02:04 »
3ft Gray on Solar Orange Paracord Micro USB Cable w/ Gold Plated Ends
I like the subtle orange colour peaking through the gray sleeve :) Reppin' GH colours :thumb:
« Last Edit: Sat, 28 June 2014, 13:24:59 by Zeal »
Offline luisbg
« Reply #645 on: Fri, 27 June 2014, 19:35:44 »
Made my order. Can't wait.  :thumb:
Offline Zeal
  • * Moderator
« Reply #646 on: Fri, 27 June 2014, 20:28:51 »
Done~
Red Alert!!  ;)
6ft coiled Imperial Red Paracord Mini USB w/ Gold Plated Ends & White HS. 2.25" straight on both ends :thumb:
P.S. You guys pretty much emptied out my imperial red in 2 days...Funny, as it hasn't been touched since I stocked Paracord. :p
I'll look at what colours I'll need to restock and order soon.
« Last Edit: Sat, 28 June 2014, 13:25:37 by Zeal »
« Reply #647 on: Fri, 27 June 2014, 20:37:59 »
Done~
Red Alert!!  ;)
Co-worker took one look at my Imperial Red cable and said "next time you order from this guy let me know so I can get a red cable for my phone!"  ;D
Great work man, I love the way all three of mine turned out. I really like the double-sleeving; I think all my future cables will be double-stuffed (as I keep calling it in my head)
KEYBOARDS >>
MICE >>
COMPUTER >>
Offline Zeal
  • * Moderator
« Reply #648 on: Fri, 27 June 2014, 20:43:04 »
Done~
Red Alert!!  ;)
Double stuffed cables :)) It is somewhat true.
Yeah, majority of the people go for less "daring" colours, so some sleeves never get to see the light. Then there's always one daring fellow that picks up a never sleeved colour, and a trend starts.  :))
Offline luisbg
« Reply #649 on: Fri, 27 June 2014, 21:40:04 »
Done~
Red Alert!!  ;)
That cable is going to look so goooood in my FC660M. Will take pictures!  ;D
