Author Topic: Zeal’s Cables - [closed]  (Read 3374535 times)
Offline Zeal
  • * Moderator
    • Zeal Generation Inc.
......And Paracord colour #35. Rainbow/Black  :))
Fixed most of the bugs on my site, just need to figure out one last little bugger...
Offline tigersharkdude
Another beautiful coil that just got mailed out.   :cool:
kaotikb's Order: Frost Blue/Black coiled mini USB cable w/ gold plated ends & blue HS
that looks absolutely amazing
Offline kaotikb
Turned out great, cant wait to get it. I will probably order more later on when i am less poor. :)
Ducky 1087 (Green ALPS) |  CM QFR Stealth (MX Brown) | Unicomp Ultra Classic |Poker II (MX Brown)  | IBM 1391401 1991 | IBM 1391401 1989 | Ducky Shine 3 White Edition (MX Brown) | G80-3700(MX Black) | Corsair K70 (MX Brown) | Varmillo VA87MR (Gateron Red)
Pointing Devices:  Microsoft Trackball Optical (Ceramic bearings Installed)  | Sanwa MA-TB39BK (Larger Ceramic Bearings Installed) | Elecom M-XT2URBK | Kensington Slimblade | Logitech Trackman Wheel | Logitech Trackman Marble Plus
Offline Zeal
  • * Moderator
Yeah, striped sleeves give off a nice pattern when coiled.  :)
;D
Offline Zeal
  • * Moderator
Lots of coil love lately.  ;D I can almost taste the rainbows as well... :p
avtar's Order:
6ft coiled, Rainbow/Black Mini USB Cable w/ Gold Plated Ends & Purple HS
6ft Orange on White Paracord Mini USB Cable w/ Gold Plated Ends
3ft Aqua Blue on White Mini USB Cable w/ Gold Plated Ends w/ reversed USB A connector (HHKB -> Laptop port)
Offline Vibex
  • Love y'all
avtar's Order:
Damn that Black Rainbow coil is beautiful! I'm gonna need to grab me one of those. :p
Offline tbc
holy ****.  that's all i can say about the rainbow
Offline Zeal
  • * Moderator
When I was coiling it, all I could think it resembled were these lolies:
Offline kaotikb
Cable arrived today. Thank you.
Offline Zeal
  • * Moderator
Looks great!  :)
Offline Zeal
  • * Moderator
Someone's_order_that_I_don't_know_their_username_on_GH's_order  :))
Clear/Gold Green LED Cable w/ Gold Plated ends & Purple HS
Blue/Gold Blue LED Cable w/ Gold Plated ends & Blue HS
« Last Edit: Sun, 01 June 2014, 01:49:17 by Zeal »
Offline Zeal
  • * Moderator
First Ergodox connector completed! Testing is underway...! :cool:
~30" TRRS connector under Black/Copper Paracord sleeve.
« Last Edit: Sun, 01 June 2014, 01:48:49 by Zeal »
Offline avtar
Pictures don't do Zeal's cables justice and his customer service is second to none. I just received these three cables and the quality is beyond what I could have imagined! Order stuff from him :thumb:
Offline Zeal
  • * Moderator
[snip]
[snip]
Thank you for your kind words, avtar!
I treat all my customers the same way I would expect to be treated in any professional business  :thumb:
« Last Edit: Mon, 26 May 2014, 23:14:30 by Zeal »
Offline kaotikb
Cables are even taped down so they don't rattle around in the box.
Offline Zeal
  • * Moderator
Taped down in individually wrapped anti-static bubble wrap too.  ;)
Offline Latin00032
This looks nice.
I'd like in on a cable.
Offline Zeal
  • * Moderator
tbc...................................why did I say yes?!
Offline Zeal
  • * Moderator
Another ridiculously crazy one-offs that tbc requests again.  :))
1.5ft Goldenrod Paracord braided Mini USB cable with 16AWG wire...Yes, 4x 16AWG wires. Neverevereverdoingitagain.
« Last Edit: Sun, 01 June 2014, 01:48:39 by Zeal »
Offline CK Briefs
  • formerly calvins1
Dat shrinkwrap bulge though LOL
Current Keyboards: Orion - 62g ergo clears;
A87 PS2AVR - 59g ergo clears; QFR - stock blues
Offline tbc
one....?  not sure where you got that idea :P
Mr. T approves
Offline Zeal
  • * Moderator
You have no idea... I used 16awg psu wire for a USB cable lol! I was afraid I wouldn't be able to solder on the Mini B side!
P.S. The bulge is even worse on the USB A end... I couldn't get myself to take a photo of it - - it's like a tumour! :eek:
TIL tbc likes shrink wrap bulge. Please tell me you're not going to make me make another cable that's that fat.  :'(
« Last Edit: Wed, 28 May 2014, 21:47:22 by Zeal »
Offline tbc
jeeze, that TRRS connector is gorgeous.  i feel like burning the one that massdrop ships.
Offline Zeal
  • * Moderator
Burnt rubber smells bad. Trust me, I know.  :))
It felt hefty too. :) If I recall correctly, that TRRS cable weighed almost 40g. :eek:
Offline Zeal
  • * Moderator
6ft Electric Blue Mini USB Cable w/ Gold Plated ends & White HS
I should really add a "GH username" field on my site. :o
« Last Edit: Sun, 01 June 2014, 01:50:23 by Zeal »
Offline Zeal
  • * Moderator
Some more coiled goodness~ :cool:
4ft Rose Pink Paracord w/ Gold Plated ends & White HS
6ft coiled Clear on Neon Orange Paracord Mini USB w/ Gold Plated ends
(3" uncoiled @ Mini USB, 8" coiled, ~21" rest uncoiled)
« Last Edit: Tue, 24 June 2014, 18:09:26 by Zeal »
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
So coiling doesn't change the end length of the cable? 3 ft regular is the same length as 3 feet coiled?
Offline Zeal
  • * Moderator
No, it doesn't work that way unfortunately. :(
When I say "6ft", it's the length of the raw cable that gets cut. Adding a coil will shorten the cable. To figure out your desired cable length, multiply your desired coil length by 6, and you'll solve for the length in inches required for said coil. :)
ie: 8" coil uses up ~48" of cable. Effective "loss" in length is 40". Hope that clears things up. :)
For reference, a 1ft coil requires 6ft of cable.
« Last Edit: Mon, 02 June 2014, 18:36:58 by Zeal »
Offline hwood34
  • underwater squad
  • #1 CL stan
alright, thanks, sent a pm
Offline Zeal
  • * Moderator
Already answered, and cable completed.  :thumb:
6ft coiled, Lime Green/Black on White Paracord Mini USB Cable w/ Gold Plated ends
(6" coil, 3" uncoiled @Mini USB end, ~33" uncoiled remaining length)
« Last Edit: Tue, 24 June 2014, 18:11:49 by Zeal »
Offline Zeal
  • * Moderator
I should also mention that my TRRS cables are good to go.  :cool:
Straight angled TRRS cables are $35, and right angled ones are $40. Only 19 straight TRRS cables & 10 angled TRRS cables available for now!
Only a few Paracord sleeves will fit my thicker cable though. (Rainbow, Black/Copper, Lime/Yellow) I'll have to test the rest of my colours.
Plastic sleeves have no problem fitting.
« Last Edit: Tue, 03 June 2014, 01:19:12 by Zeal »
Offline tbc
Re: Zeal’s Cables - [#LEGITBALLIN' ErgoDox cables now available!]
« Reply #532 on: Tue, 03 June 2014, 02:15:18 »
those trrs cables are frickin' legit.  like with lazerz and ****.
« Reply #533 on: Tue, 03 June 2014, 06:44:36 »
If your cables are legitballin, does that mean vtec just kicked in yo?
Offline hwood34
  • underwater squad
  • #1 CL stan
holy **** that was fast :eek:
Offline Eszett
« Reply #535 on: Tue, 03 June 2014, 06:59:36 »
One question. Even though it's mainly covered by the sleeve: Are there cables with white outer plastic instead of black? Or other colors?
Offline Zeal
  • * Moderator
« Reply #536 on: Tue, 03 June 2014, 09:28:59 »
I dunno, CPT, tbc says they're like lazers n ****.  :cool:
There are cables with all sorts of different exterior plastic colours, but my bulk cable uses a black exterior.
« Last Edit: Tue, 03 June 2014, 09:47:16 by Zeal »
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #537 on: Wed, 04 June 2014, 15:48:10 »
Just wanted to say I got my package today (super fast) and the cable looks awesome ;D
Offline Zeal
  • * Moderator
« Reply #538 on: Wed, 04 June 2014, 16:06:19 »
That moment when overnight courier is faster than ground courier service.  ;)
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #539 on: Wed, 04 June 2014, 16:17:36 »
Seriously. I almost didn't go out to see what my dog was barking at because I thought there was no way it had come already :p
Offline Zeal
  • * Moderator
« Reply #540 on: Wed, 04 June 2014, 16:31:42 »
Well, I did email you expected delivery date along with the tracking number. :p
All shipments to CONUS arrive next business day. :)
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #541 on: Wed, 04 June 2014, 16:35:28 »
Ah, guess I need to be more attentive
Offline Zeal
  • * Moderator
« Reply #542 on: Wed, 04 June 2014, 19:58:17 »
Double coils~ ;)
taylordcraig's order:
10ft coiled, Rainbow/Black Paracord Micro USB Cable w/ Gold Plated ends
10ft coiled, Silver Gray Paracord Micro USB Cable w/ Gold Plated ends
Both have a 1ft coil and 4" noncoil @ Micro USB end.
« Last Edit: Tue, 24 June 2014, 18:07:54 by Zeal »
Offline Zeal
  • * Moderator
« Reply #543 on: Wed, 04 June 2014, 20:14:42 »
Small update/note:
I've pretty much depleted my roll of USB cable... Only two individual 6ft strands and a 30" cable left.
I'm talking to my supplier to see if I can get some white bulk cable made.  :cool:
« Last Edit: Wed, 04 June 2014, 20:17:05 by Zeal »
Offline CK Briefs
  • formerly calvins1
« Reply #544 on: Wed, 04 June 2014, 21:41:10 »
Small update/note:
I will annoy you with many orders once you get the white cables: )
Offline Zeal
  • * Moderator
« Reply #545 on: Wed, 04 June 2014, 23:41:14 »
Bring it.  :cool:
Another Ergodox cable set going out tomorrow~
Fluctuation's order:
4ft Blue/Gold TRRS cable
10ft Blue/Gold Mini USB w/ Gold Plated ends & White HS
« Last Edit: Tue, 24 June 2014, 18:08:12 by Zeal »
Offline Zeal
  • * Moderator
« Reply #546 on: Thu, 05 June 2014, 00:56:37 »
Andddd stayed at my office late to finish up the last order today so you guys can receive your cables on Friday, and not wait over the weekend.  :thumb:
Suby4me's Order:  :)
3ft Clear/White on Blue LED Mini USB w/ Gold Plated ends & White HS
« Last Edit: Tue, 24 June 2014, 18:08:39 by Zeal »
Offline tbc
« Reply #547 on: Thu, 05 June 2014, 04:06:19 »
Small update/note:
pretty sure white cables are made of lazerz.
Offline suby4me
« Reply #548 on: Thu, 05 June 2014, 08:56:52 »
Suby4me's Order:  :)
Awesome Zeal! Thanks for going the distance and getting the cable done! It looks so beautiful, can't wait to get it.  :thumb:
current: poker 2 | HHKB pro2, Novatouch | off: das keyboard 4 | Ducky 3 TKL | death by coffee das keyboard mac ver. | razer blackwidow | whitefox | corsair K70 RGB
Offline Zeal
  • * Moderator
« Reply #549 on: Thu, 05 June 2014, 16:02:19 »
lazerz obzezzion? I think my order is also considered too small for custom white cables :'(
Not a problem! Never been a fan of having to wait over the weekend, especially when you know it could have arrived on Friday, if only the person had shipped it one day earlier. :P
