Author Topic: Computer for my Mum  (Read 2826 times)
Offline tipo33
  • "Ski"
Computer for my Mum
« on: Fri, 21 February 2014, 15:49:23 »
So every 2 years or so I build a computer for my mum.  Every time I struggle, because I stopped using Windows around XPSP2 and I have no clue about the requirements, and what runs well.  I'm not on a budget, but my mum just needs Office, Skype, and a web browser.  Will the following run Windows 7 comfortably?
Antec ISK 300-150
ASRock FM2A78M-ITX+
AMD A4-5300
4 gigs of DDR3 I have lying around
a spare hard drive from a broken lappy ~500gigs
Thank you.
« Last Edit: Sat, 22 February 2014, 10:02:58 by tipo33 »
KM4COL    R.I.P.  SmallFry
Offline berserkfan
Re: Computer for my Mum
« Reply #1 on: Fri, 21 February 2014, 16:19:17 »
If you are using a mac, get her a mac also. Everything solved.
I most certainly do not think Windows8 is an improvement on Windows7 or even WinXP.
Offline user 18
« Reply #2 on: Fri, 21 February 2014, 17:42:47 »
It ought to do just fine for running Win 7 -- but if all she's doing is web browsing, skype and office, you'd probably be better served by just reformatting the drive on the old machine, and reinstalling the OS -- makes everything fresh and snappy, clears out junk, and is much cheaper -- particularly if you'd be going to a new machine anyway.
What I would maybe recommend beyond even that is adding a SSD using the money you'd save from not doing a hardware upgrade. For the low-stress tasks, an SSD can make everything seem much smoother.
What's your reason for upgrading, other than the simple fact of it being 2 years later?
Avatar by ashdenej
Offline tricheboars
  • Keyboards are Important!
« Reply #3 on: Fri, 21 February 2014, 18:26:17 »
Well apple machines are way way more expensive. So if it fits your budget do it if not... Nah.
As far as Windows 8 I really disagree. Windows 8 is fantastic for older folks if configured. I have it on my folks machine and they both really like it once they adjusted. Windows 8.1 is even better.
Your specs can run win 7 or win 8.1.  I have installed Windows 8.1 on 6 year old HP business boxes at work and they run perfectly fine.
« Reply #4 on: Fri, 21 February 2014, 18:29:05 »
I would say that your hardware looks entirely adequate.
Are you not specifying what keyboard you are providing? Shame!
- D Trump 2026-10-24
Offline tricheboars
« Reply #5 on: Fri, 21 February 2014, 19:38:46 »
Clearly your mom also needs a realforce 87u or an ergodox!
« Reply #6 on: Sat, 22 February 2014, 04:23:03 »
Would a tablet of some sort, say an iPad, suffice?
Pages, Numbers and Keynote all run on iPad.  Also rumours of MS Office for iPad soonish.
Offline tipo33
  • "Ski"
« Reply #7 on: Sat, 22 February 2014, 09:44:12 »
I don't want to get her a Mac, I'm not a Mac user, I use *nix.  I guess I should have made that clear.  lol.  Thank you for all the answers, as far as reformatting her current machine, the last one I built her was a barebones Shuttle, and the 40mm PSU fan after 2 years service, drives my Mum CRAZY...  She complains about it ALL THE TIME.  She already owns a Rosewill with browns, so the KB issue is solved.  :D
Thank you for all the answers,  I will go ahead with this build and see how long it lasts.....
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #8 on: Sun, 23 February 2014, 07:57:06 »
I would go with something like one of the new Atom Bay Trail quad ITX motherboard, with an ssd and a pico psu if the board dosen't have integrated power. Nothing nicer than a totally passive build with zero moving parts.
Offline vun
  • Just one more thing
« Reply #9 on: Sun, 23 February 2014, 08:01:51 »
What I do these days when relatives and computer illiterate people ask for computer advice is to just tell them to buy an AIO system, or a laptop if they need something more mobile. No complaints so far.
« Reply #10 on: Sun, 23 February 2014, 08:09:31 »
I do similar, but not AIO... go for those little nettop boxes instead. That way they can keep the display through at least 2 iterations of systems typically and save some money. Since most of them can vesa mount you end up with a very similar foot print too. Most of them are barebones so you can at least pick the memory and ssd/hdd used as well which is nice, and often end up with better components for far less money.
