Author Topic: ABB Automation DSiH 70F (RAFI mechanical switches?) $45 shipped  (Read 2177 times)
Offline jacobolus
« on: Fri, 21 February 2014, 23:15:14 »
http://www.ebay.com/itm/301082819710
I believe the switches are this kind http://deskthority.net/wiki/RAFI_RS_76M
Sounds like they’re fairly nice linear switches?
Offline berserkfan
Re: ABB Automation DSiH 70F (RAFI mechanical switches?) $45 shipped
« Reply #1 on: Fri, 21 February 2014, 23:42:55 »
another keyboard I can't get
The design screams "I'm ultra heavy and meant to be used in Dr. Strangelove's nuclear plant".
Shipping to where I am will probably be 3-4x the cost of the keyboard,  :confused:
« Reply #2 on: Sat, 22 February 2014, 14:18:50 »
seller has had these boards up on his ebay for several months now. I check back every once in a while to see if the prices go down or anything sells.
unbroken plastic means $55 and missing keycaps means $40
Offline jacobolus
« Reply #3 on: Sat, 22 February 2014, 15:15:02 »
Which missing keycaps? It says the *key* is missing. Like, there's a lock in the corner.
« Reply #4 on: Sat, 22 February 2014, 15:32:48 »
This is the version with "broken plastic"; the seller also has a listing for one with "missing keycaps" and a third listing for one that is in good condition.
so you have options if you want to pay more or less for a better or worse shape KB
Offline berserkfan
« Reply #5 on: Sat, 22 February 2014, 18:25:25 »
Oooh
If they were listed in Japan, I'd be wondering whether this was a Fukushima closing down sale.
