Author Topic: Key caps for Filco The & keypad  (Read 2240 times)
Offline soloz2
« on: Sun, 23 February 2014, 11:27:40 »
Hello,
I looking to upgrade from my WASD Abs key caps to some nice PBT for my Filco setup. The problem I'm running into is that the Filco keypad has separate 0 and 00 keys instead of the larger standard 0 key so I'm not finding key cap sets that accommodate this setup.
I just got the Filco keypad so I could return it and get maybe a Leopold, but I heard reports that they are configured to the number row instead of the number pad.
I was looking at possibly picking up the Ducky thick black on black PBT set, or the Vortex double shot in hopes that I could get a reverse set to match later on.
Does anyone know where I can get a complete set or at least separate keys?
Offline RESPRiT
  • HHKB = ❤
Re: Key caps for Filco The & keypad
« Reply #1 on: Sun, 23 February 2014, 19:14:18 »
You can get blank DSA PBT sets from Signature Plastics and also buy an extra 1x key for the 00 key.
Offline soloz2
« Reply #2 on: Sun, 23 February 2014, 19:33:38 »
Thanks I'll take a look. How about printed caps?
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #3 on: Sun, 23 February 2014, 19:53:42 »
Check out the black on black PBT group buy going on right now, run by Ivan. I believe it will end up higher quality and a better profile (IMO) than the Ducky caps you mentioned.
Offline soloz2
« Reply #4 on: Sun, 23 February 2014, 20:40:04 »
I was looking at those keycaps and they do look great, but again there is the double wide 0 key.  I'm a bit of a noob, so maybe I missed something?
Offline admiralvorian
  • DIY
« Reply #5 on: Mon, 24 February 2014, 22:52:48 »
I have a ducky thick pbt set and it's pretty nice
Darude Status:
☐ Not Sandstorm
☑ Sandstorm                                               wts wtt wtb
