Author Topic: Researchers find ways to sniff keystrokes from thin air  (Read 4008 times)
Offline lexicon
    • http://www.word-detective.com
« on: Thu, 12 March 2009, 23:53:19 »
Bummer.  Now I'm gonna have to wrap the whole house in tinfoil.
March 12, 2009, 02:46 PM —  IDG News Service —
That PC keyboard you're using may be giving away your passwords. Researchers say they've discovered new ways to read what you're typing by aiming special wireless or laser equipment at the keyboard or by simply plugging into a nearby electrical socket.
Two separate research teams, from the Ecole Polytechnique Federale de Lausanne and security consultancy Inverse Path have taken a close look at the electromagnetic radiation that is generated every time a computer keyboard is tapped. It turns out that this keystroke radiation is actually pretty easy to capture and decode -- if you're a computer hacker-type, that is.
The Ecole Polytechnique team did its work over the air. Using an oscilloscope and an inexpensive wireless antenna, the team was able to pick up keystrokes from virtually any keyboard, including laptops. "We discovered four different ways to recover the keystroke of a keyboard," said Matin Vuagnoux, a Ph.D. student at the university. With the keyboard's cabling and nearby power wires acting as antennas for these electromagnetic signals, the researchers were able to read keystrokes with 95 percent accuracy over a distance of up to 20 meters (22 yards), in ideal conditions.
Laptops were the hardest to read, because the cable between the keyboard and the PC is so short, making for a tiny antenna. The researchers found a way to sniff USB keyboards, but older PS/2 keyboards, which have ground wires that connect right into the electric grid, were the best.
[more at link]
IBM Model M 1391401 (1989)
IBM Model M 52G9658 (1993) x2
Unicomp Customizer 101 (black)
Solidtek ASK-6600U
Dell AT101W (way too many)
Dell AT101W (black)
Silicon Graphics AT-101 (1993)
Cherry G84-4100
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
« Reply #1 on: Fri, 13 March 2009, 00:14:45 »
Well I feel better typing this on my only PS/2 keyboard ;)
