Author Topic: Custom keycap set  (Read 4420 times)
Offline bktlr
Custom keycap set
« on: Mon, 24 February 2014, 13:48:27 »
Hello everyone, this is my first post on this forum :D
I'm making a custom keyboard with my friend with this layout:
http://www.keyboard-layout-editor.com/#/layouts/93a1796de8593c80a5d07c1323ad273c
which will have these keycaps (the ones in blue): http://imgur.com/pZwDQ4R
Is there any shop where I can get only those keycaps and not a whole set? I emailed wasdkeyboards.com and asked them but I haven't gotten a response yet.
Little bit about the keyboard: It's going to be used for playing counter-strike. We wanted to make a smaller keyboard to make it easier and a bit cheaper so we came up with this idea. The case will be 2mm aluminium that we'll cut in a CNC machine.
Thanks! Hopefully I posted this in the right section.. :)
Corsair K90 (MX red)
Quick Fire TK Stealth (MX brown)
Re: Custom keycap set
« Reply #1 on: Mon, 24 February 2014, 15:05:35 »
Welcome to Geekhack.
For a small (or single) run with custom keycaps WASD is probably your best bet.
The keyboard you are designing sound interesting - perhaps you could post more details in the making stuff together! section.
Offline bktlr
« Reply #2 on: Mon, 24 February 2014, 16:11:28 »
Yeah it seems that WASD is the only way to go, except buying the 21 keys I need costs almost as much as getting a whole set of (cheaper) keycaps. For the first run I might aswell buy buy a whole set and use the rest for my own keyboard :)
I'll make sure to post pictures once we get started making something.
Offline Norz
« Reply #3 on: Mon, 24 February 2014, 16:16:23 »
Careful with WASD shipping fees to Europe though. I got raped.
Offline Broadmonkey
« Reply #4 on: Mon, 24 February 2014, 16:18:01 »
Just a quick note. It's better to use 1.5mm instead of 2mm for the plate. I can't remember who, but I remember someone who had bad results with 2mm as it doesn't fit the cherry switches as good as 1.5mm
Offline bktlr
« Reply #5 on: Mon, 24 February 2014, 16:25:35 »
According to the site it's estimated to 6$ to Sweden via USPS. Can anything extra be added to that? What happened with your shipping?
Thanks for telling me, 1.5mm should still be good and sturdy!
Offline pillows
  • soft as milk
« Reply #6 on: Tue, 25 February 2014, 00:57:41 »
Looks like Counter-Strike! Though I bind my talk/mic key on my mouse.
Yeah like what the general consensus of this thread says, your best bet is buying individual keys.
intel core i9 3333mhz twin turbo
Offline RESPRiT
  • HHKB = ❤
« Reply #7 on: Tue, 25 February 2014, 05:28:51 »
You can buy the keys from Signature Plastics individually for $1 each.
Offline bktlr
« Reply #8 on: Tue, 25 February 2014, 11:58:46 »
Yeah it's for CS:GO! Since you play CS (i assume), do you feel like any more keys are needed? (Look at the new design below) Console key maybe?
Thanks! I might buy these: http://keyshop.pimpmykeyboard.com/product/dsa-blank-numpad-sets and use them. The profiles wont be a problem since it's DSA! :D
Changed the layout a little bit to make it work: http://www.keyboard-layout-editor.com/#/layouts/ab0a6af11cbeccc3715be4fd20fee95d
Might try to get a spacebar and mic button but it isn't that necessary since mouse bindings can be used.
